Juniortiti
Juniortiti
Nombre de messages : 852
Promo liquidrc Empty Promo liquidrc
Ven 12 Sep 2008 - 5:50
Voilà, je ne sais pas si vous l'avez eu aussi mais voilà le mail que j'ai eu dans la nuit de liquidrc, je vous en fait donc profiter, ça peut etre interessant pour faire du stock! Very Happy Wink
Select Traxxas parts 50% off retail.
We haven't sold these in a while, and it's time to move 'em out.
1526 Drive Gear: Villain retail: $3.00 now: $1.50
1533 Propeller Right: Villain retail: $3.00 now: $1.50
1534 Propeller Left: Villain retail: $3.00 now: $1.50
1539 U Joints: Villain Blast retail: $5.00 now: $2.50
1630 Suspension Arm Brace:R S H LS retail: $3.00 now: $1.50
1637 Steer Block/Spindles: R N LS NS retail: $6.00 now: $3.00
1718 Resistors:2818 Speed Control retail: $3.00 now: $1.50
1782 Gears Planet Sun/Shaft:S R H retail: $5.00 now: $2.50
1854 Hub Adaptors 12mm hex to 5 lug star retail: $2.00 now: $1.00
1873 Fr Wheel chrome: S H retail: $5.00 now: $2.50
1932 Pro Caster Blocks:RC retail: $4.50 now: $2.25
1935 Turnbuckles 36mm W/Spacers: E retail: $2.00 now: $1.00
1952 Stub Axle Housings: N Nru retail: $3.00 now: $1.50
1995 Top Gear: E retail: $3.00 now: $1.50
2335 Turnbuckles 72mm: Hawk 2 St retail: $2.00 now: $1.00
2339x Turnbuckles Titanium 105mm:TMX EM retail: $16.00 now: $8.00
2388 Planetary Gear Differential: St Ru retail: $12.00 now: $6.00
2437 Fr Axles: Ba retail: $3.00 now: $1.50
2637 chrome Suspn Pins 31.5mm retail: $2.50 now: $1.25
2721 Diff Shaft: Trx1/3 retail: $6.00 now: $3.00
2722 Diff Rings 19mm: TRX1/3 SS 4T retail: $1.50 now: $0.75
2731 Fr Suspn Arm Mount: T N Nb Ns retail: $3.00 now: $1.50
2747 Nylon Wheel Nuts 5mm: T N T3 retail: $1.50 now: $0.75
2818 Rotary Mechanical Speed Control retail: $26.00 now: $13.00
3126 Clutch Shoes W/Spring: N Nb Ns Nv retail: $7.25 now: $3.63
3141 Clutch Pilot Bushing: N NB NS retail: $4.75 now: $2.38
3151 Exhaust Tube & Strap:N NB NS retail: $2.50 now: $1.25
3154 Exhaust Tip Rubber: N NB NS retail: $3.25 now: $1.63
3454 32p Spur Gear 54t: Ns Nb retail: $3.00 now: $1.50
3527 Drive Shaft Coupler: Nitro V retail: $7.00 now: $3.50
3534x Propeller: Nitro V retail: $6.00 now: $3.00
3613 Decal Sheet: Stampede retail: $6.00 now: $3.00
3627 Battery & Receiver Hold Down Kit: Ns retail: $4.00 now: $2.00
3693 Spur Gear Adaptor: S R Ba retail: $3.00 now: $1.50
4019 Crankshaft Short: .15 retail: $20.00 now: $10.00
4029 Alum Head Gaskets: .15 retail: $2.50 now: $1.25
4070 Pull Start Assembly Trx .12 .15 retail: $18.00 now: $9.00
4076 Recoil Spring: .12 .15 retail: $7.50 now: $3.75
4111 Body: Nitro Stampede retail: $20.00 now: $10.00
4113 Nitro Stampede Decal retail: $6.00 now: $3.00
4144 Clutch Adaptor Nut: Nst Nru Nsp retail: $5.25 now: $2.63
4160 Engine Mount: Nru retail: $11.00 now: $5.50
4183 Throttle/Brake Rods/Lever: Nst retail: $2.50 now: $1.25
4324 Side Frames/Belt Tension:4t retail: $9.00 now: $4.50
4332 Upper Control Arms:4-Tec retail: $6.00 now: $3.00
4434 Gearbox Brace/Guard: Nru Nsp retail: $3.00 now: $1.50
4448 Fuel Tank 75cc W/Cushions retail: $12.00 now: $6.00
4460 Engine Mount Set: Nru Nsp retail: $12.00 now: $6.00
4580 Control Box: Ez-Start retail: $12.50 now: $6.25
4636 Springs White 1-5/8 retail: $2.50 now: $1.25
4640 Springs Red 2 retail: $2.50 now: $1.25
4819 Gear Clutch 2nd Spd 19t (4817) retail: $6.00 now: $3.00
4884 Brake Disc: N4-Tec retail: $3.00 now: $1.50
4960x Engine Mount Mach Alum: Tmx.15 2.5 3 retail: $42.00 now: $21.00
4985 Spur Gear Assembly 38t: Tmx.15 2.5 retail: $4.00 now: $2.00
4986 Gear Hub Assembly: Tmx.15 2.5 retail: $22.00 now: $11.00
4990 Clutch Bell Forward Rev: Tmx.15 2.5 retail: $32.00 now: $16.00
4991 Fr & R Gearbox Halves Plug: Tmx 2.5 retail: $10.00 now: $5.00
1529 Outdrive Housing: Nitro V retail: $3.00 now: $1.50
1549 Washer 4x6x.5mm retail: $2.00 now: $1.00
4883 Brake Pads: N4-Tec retail: $3.00 now: $1.50
1528 Drive Shaft Housing: Villain (2) retail: $4.00 now: $2.00
4994r 26t Machine Gear:4994x Tmx.15 2.5 retail: $7.00 now: $3.50
4911x Prographix Body: Tmx .15 2.5 3.3 retail: $34.99 now: $17.50
5140 Alum. Header: R Exhaust Eng Tmx 2 retail: $20.00 now: $10.00
4966x Brake Adapter Hex Blue: Tmx.15 2.5 3 retail: $4.75 now: $2.38
5167 Slide Carb Linkage: Tmx2.5 retail: $2.75 now: $1.38
5273 Cush-Drive Elements: Ez2 Sly retail: $2.50 now: $1.25
5191x SporT-Maxx 4wd Upgrade Modules retail: $50.00 now: $25.00
2519 Diff Dear 60T For SRT retail: $5.00 now: $2.50
3296 Inlet Fittings: Tmx 2.5 3.3 (2) retail: $2.75 now: $1.38
5231 Wrist Pin & Clips: Trx 2.5 (2) retail: $3.00 now: $1.50
5192 Drive Gear Single-Speed 22T retail: $6.00 now: $3.00
5287 Alum Header Bl: Nru N4-Tec Trx 2.5 retail: $20.00 now: $10.00
1531 Trim Adj Bracket: Villain Ex retail: $5.00 now: $2.50
1583 Propeller Right 4mm: Villain Ex retail: $3.00 now: $1.50
1584 Propeller Left 4mm: Villain Ex retail: $3.00 now: $1.50
2062 Gear Set Micro Servo: Revo Sly retail: $4.00 now: $2.00
4025 DISC BY TRA Piston/Sleeve Sport: retail: $35.00 now: $17.50
5342 Tuned Pipe Blue Alum: Sly retail: $46.00 now: $23.00
5356 Rocker Arm Set Long: REVO retail: $8.00 now: $4.00
5466x Gtr Shock Body Anodized: Revo Sly retail: $10.00 now: $5.00
5477 Flat Wrench Blue Alum 5mm retail: $4.00 now: $2.00
1539r U Joints 3mmgrugscrews: Villaine retail: $5.00 now: $2.50
5431 Rear Spring Shock GTR Silver (Pr): J retail: $5.00 now: $2.50
5433 Rear Spring Shock GTR Pink (Pr): Jat retail: $5.00 now: $2.50
5520 Rear Bumper: Jato retail: $4.00 now: $2.00
5532x Blue Alum. Caster Blocks Left & R retail: $38.00 now: $19.00
5536r Blue Alum. Steering Blocks Left & retail: $28.00 now: $14.00
5536x Blue Alum. Caster Blocks Left & R retail: $38.00 now: $19.00
5548 Complete Fuel Tank Assembly: Jato retail: $16.00 now: $8.00
5555x Stub Axle Carriers Blue Alum.: Ja retail: $40.00 now: $20.00
5571 Front Tires Victory 2.8 (2): Jato retail: $17.50 now: $8.75
5574 Front Wheels Twin-Spoke 2.8 (2): Jat retail: $8.00 now: $4.00
5589 Anti-Roll Bar & Linkage: Jato retail: $19.50 now: $9.75
3146 Paper Filter for Old Nitro Hawk retail: $2.00 now: $1.00
49165 Special Edition T-Maxx Body Silver retail: $34.99 now: $17.50
5327 Suspension Arms Right: Revo REVO 3.3 retail: $7.50 now: $3.75
5328 Suspension Arms Left: Revo REVO 3.3 retail: $7.50 now: $3.75
4976 Wheels Axles: Wheelie Bar retail: $5.00 now: $2.50
4918a Servo Mounts Steer Grey: Tmx3.3 retail: $3.50 now: $1.75
4919a Servo Mount Throttle Grey : Tmx3.3 retail: $3.50 now: $1.75
5183 Gear Idler: Tmx 3.3 retail: $6.50 now: $3.25
4968x Linkage Shift: Tmx 3.3 retail: $5.00 now: $2.50
4923a Chassis Braces Low Grey: Tmx3.3 retail: $8.00 now: $4.00
5565x Brake Disc-hub: Revo 3.3 retail: $7.00 now: $3.50
4920 Decal Sheet: Tmx 2.5R retail: $8.00 now: $4.00
5589x Sway Bar Kit Front & Rear: Jato retail: $19.50 now: $9.75
5513x Decal Sheet: Jato 3.3 retail: $11.00 now: $5.50
5597 Rear Sway Bars: Jato 3.3 retail: $7.00 now: $3.50
4813x Decal Sheet: N4-Tec 3.3 retail: $9.00 now: $4.50
4864 Belt Fr Drive : N 4-Tec 3.3 retail: $7.50 now: $3.75
4865 Belt R Drive : N 4-Tec 3.3 retail: $7.50 now: $3.75
1530 Wire Whip Antenna retail: $2.00 now: $1.00
3148x Fuel Tank 75cc retail: $11.00 now: $5.50
3152 Exhaust Pipe Rubber: N Nb Ns retail: $5.75 now: $2.88
3224 Rod Connecting: .12 .15 retail: $13.50 now: $6.75
3235 G Clip Spring Retains.12 .15 retail: $1.50 now: $0.75
3724 Mount Plate Speed Control: R retail: $2.50 now: $1.25
4028 Brake Support Bracket: .12 retail: $4.00 now: $2.00
4030 Cylinder Sleeve/Piston: .15 retail: $40.00 now: $20.00
4031 Wrist Pin/Retainer: .15 retail: $3.00 now: $1.50
4154 Rubber Exhaust Tip: Nst retail: $4.00 now: $2.00
4262 R Shock Shafts chrome: SS 4t retail: $3.00 now: $1.50
4451 Exhaust Rubber Pipe: Nru Nsp retail: $4.50 now: $2.25
4452 Tuned Pipe Assembled: Nru Nsp Tmx retail: $15.00 now: $7.50
4576 Gear Set/Gear Shafts: Ez-Start retail: $6.00 now: $3.00
4820 Gear Clutch 2nd Speed 20t retail: $6.00 now: $3.00
4831 Fr Suspension Arms: N4-Tec retail: $6.00 now: $3.00
4862 R Drive Belt 50 Htd: N4-Tec retail: $7.50 now: $3.75
4863 Mid Drive Belt 121 Htd: Nitro N4-Tec retail: $9.00 now: $4.50
4885 Spur Gear Std 41t: N4-Tec retail: $4.00 now: $2.00
4967 Brake Cam Blue: Tmx.15 2.5 3.3 retail: $6.25 now: $3.13
4988 Drive Hub Assembly: Tmx.15 2.5 retail: $16.00 now: $8.00
4992 Drive Gear 2-Speed: Tmx.15 2.5 retail: $6.00 now: $3.00
4993 Gear Shaft Primary: Tmx.15 2.5 retail: $3.00 now: $1.50
4996 Idle Gears: Tmx.15 2.5 retail: $5.00 now: $2.50
4946 Hangar Pipe: Tmx retail: $2.00 now: $1.00
3624 Mount Plate Speed Control: St retail: $2.50 now: $1.25
2638 Sup Pins 39mm chrome (2) retail: $2.50 now: $1.25
3153 Baffle Cone Exhaust retail: $2.25 now: $1.13
4450 alum header mount retail: $15.00 now: $7.50
4413x Decal Sheets: Nru 2.5 retail: $11.00 now: $5.50
4433a Mounting Plate Receiver Grey: Nru Ns retail: $2.00 now: $1.00
3613r Decal Sheets: Stampede Vxl retail: $11.00 now: $5.50
3715 Prographix Body: Rustler Vxl retail: $34.99 now: $17.50
5162 DriveCup(1)ScrewPin(1) Sleeve(1) retail: $9.00 now: $4.50
5165 Alum. Brake Adapter Blue: Tmx retail: $6.00 now: $3.00
3840 DRV SHFT RUBB GROMMET BLS retail: $2.50 now: $1.25
3019 Evx-2 Foward/Reverse Speed Control retail: $180.00 now: $90.00
3997 Motor Plate: Emx retail: $10.00 now: $5.00
3925 Seal Kit For Receiver Box: Emx retail: $4.00 now: $2.00
2063 Servo-Case/Gaskets: Tra2065 retail: $5.50 now: $2.75
4962 Bigbore Shock W/Spring: E/Tmx 2.5 retail: $99.99 now: $49.99
3973 Gear Set Close Ratio: Emx retail: $6.00 now: $3.00
3988x Linkage Shift: Emx retail: $5.00 now: $2.50
5522g Exo-Carbon Kit: Jato retail: $75.00 now: $37.50
5533g Exo-Carbon Rear Suspension Arms(Left retail: $17.00 now: $8.50
5535g Exo-Carbon Front Bumper: Jato retail: $9.00 now: $4.50
5493 Tuned Pipe Resonator R. O.A. R Legal retail: $55.00 now: $27.50
5625 Seal Kit Receiver Box: Slash E-REVO retail: $4.00 now: $2.00
5629 Battery Retainer Clip (1fr & 1r): E- retail: $3.00 now: $1.50
5813 Decal Sheet: Slash retail: $11.00 now: $5.50
Quick Links...
LiquidRC.com
Promo liquidrc Empty Re: Promo liquidrc
Ven 12 Sep 2008 - 10:04
Excellent ! king
Promo liquidrc Userba10
