Nombre de messages : 28044
[StyleS] E-Revo Racing 1/8 GT - Alias "E-Revo XO-1 Killer"
Lun 5 Oct 2015 - 17:50
Voici un Pure E-Revo style Racing On-Road !
[Vous devez être inscrit et connecté pour voir ce lien].
@zbeast942011
This Traxxas E Revo was a bit of a mad scientist creation. It started off as a brushless E Revo and was narrowed lowered and had the power system reconfigured. It was built to compete with the Traxxas XO one, and does quite nicely. The power system consists of a castle creations XL 2, a leopard 1000 KV brushless boat motor with cooling jacket and two 5000 mA 4S lipo batteries run in series, Not included. Yes this E Revo runs on 8s. I have engineered a cooling system that consists of a 40 x 80 mm radiator twin 40 mm fans a pump and reservoir to circulate water. The pump runs on a separate 300 mA 2S lipo, included. The suspension consists of XO1 shocks, hot racing springs, atomic RC rocker arms. Hot racing front and rear sway bars, Hot racing aluminum steering bellcrank. Traxxas aluminum turnbuckles and tie rod ends and rocker arm pushrods. Hot racing aluminum steering knuckles, hot racing mock vented disc brakes with Calpers. Hot racing brushed motor mount to reposition the brushless motor for equal weight distribution. Traxxas steel center drive shaft links. Steel halfshaft links front and rear. SP belted tires and wheels, and 17 mm Traxxas hub adapters. The gearing in it is about .9 to 1 with a steel 40 tooth integy spur gear attached to the motor by way of a spur to Pinion adapter. The Hot racing steel 34 tooth spur gear was attached to transmission by slipper clutch eliminator. The servo is a futaba S9352HV(not cheap) Kyosho Aston Martin body. All this is protected by a handbuilt steel roll cage.
With all that being said this project was quite an undertaking and is one of a kind. It took months of engineering fabricating and tracking down parts to complete this project. What The starting bid for this true one of a kind Traxxas XO one killer is A bargain.
I have had my fun with it and have proved my point at the local hobby shops. Time for someone else to enjoy it and turn heads.
This comes with a TQI five channel Traxxas receiver only.
[Vous devez être inscrit et connecté pour voir cette image]
@zbeast942011
On. [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien]
Off. [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien] / [Vous devez être inscrit et connecté pour voir ce lien]
