[New] Steel Center One-Way 1/16 by Hot Racing/HotRacing
Mer 27 Juil 2011 - 1:56
by Hot Racing
This is the Hot Racing center one-way differential transfers power to the front differential
under acceleration but allows it to "freewheel" while decelerating or braking.
Unlike a front one-way differential, a center one-way allows front differential action.
Result: you can steer while the brakes are on.
FEATURES:
light weight steel shaft 6x10mm one way bearing
YOU WILL RECEIVE:
One Center One Way Diff with Pre-installed Bearing One light weight steel shaft Three M3x5mm Screw Comment: One-way mode for racing tight tracks where maximum off-power steering is needed.
Hot Racing
by Hot Racing
FEATURES:
YOU WILL RECEIVE:
Hot Racing
- [NEW] GPM Racing ALUMINUM CENTER DRIVE SHAFT WITH HARD STEEL JOINTS X-MAXX - Cardan / Axe central
- [NEW] GPM Racing 4140 CARBON STEEL CENTER DOG BONE - Cardan centrale en Acier carbone 4140 Sledge
- [NEW] Cardan Roue/Steel Cv with Steel Hub pour Latrax 1/18 par Hot Racing
- [New] Clips Carro Body Hot Racing HotRacing
- [NEW] Rocker/Basculateur Multi LT 1/8 v2 par HotRacing/Hot Racing
