[NEW]Châssis carbon & Aluminium Slash/Rally 1/16 Hot Racing
Jeu 6 Sep 2012 - 19:58
Châssis carbon & Aluminium pour Slash & Rally 1/16
par Hot Racing
This is the Hot Racing optional Carbon Fiber Chassis Conversion Set
Change your 1/16 Traxxas to 200mm sedan
for use with Traxxas 1/16 Slash Rally VXL.
FEATURES:
Carbon fiber Chassis with CNC 6061 aluminum accessory
Can use popular 200mm sedan body
Can use stock servo or stranded servo.
Can use stock or standard 7.2 V Battery pack.
Front and rear Aluminum Multi mount shock tower
HR Super Sport Spring Set
Hot Racing
Super Sport cold-coiled Performance Spring
SPECIFICATIONS:
Gold (soft)
length: (27mm)
Inner diameter: (11mm)
Wire diameter: (1.3mm)
Silver (med)
length: 27mm
Inner diameter: 11mm
Wire diameter:1.4
Black (hard)
length: 27mm
Wire diameter:1.5
YOU WILL RECEIVE:
One carbon fiber chassis with all aluminum mount, Shock spring set and hardware.
(all item as in the picture)
REQUIREMENTS:
Remaining vehicle parts.
Front Body mount post.
Remove 7067 down stopper inside Traxxas stock shock
Châssis carbon Hot Racing
This is the Hot Racing optional Aluminum Chassis Conversion Set
FEATURES:
CNC 6061 Aluminum Chassis with accessory
Hot Racing
SPECIFICATIONS:
Gold (soft)
length: (27mm)
Silver (med)
length: 27mm
Wire diameter:1.4
Black (hard)
length: 27mm
Wire diameter:1.5
YOU WILL RECEIVE:
One Aluminum chassis with mount, Shock spring set and hardware.
REQUIREMENTS:
Châssis Aluminium Hot Racing
par Hot Racing
FEATURES:
Hot Racing
SPECIFICATIONS:
Gold (soft)
length: (27mm)
Silver (med)
length: 27mm
Wire diameter:1.4
Black (hard)
length: 27mm
Wire diameter:1.5
YOU WILL RECEIVE:
REQUIREMENTS:
FEATURES:
Hot Racing
SPECIFICATIONS:
Gold (soft)
length: (27mm)
Silver (med)
length: 27mm
Wire diameter:1.4
Black (hard)
length: 27mm
Wire diameter:1.5
YOU WILL RECEIVE:
REQUIREMENTS:
Re: [NEW]Châssis carbon & Aluminium Slash/Rally 1/16 Hot Racing
Mar 1 Jan 2013 - 15:47
Est-ce que je vois bien un espace pour y insérer un servo standard ?
Parce que les petits servo est un point faible des 1/16.
Mar 1 Jan 2013 - 17:07
Apparemment.
Il y a une différence avec le châssis MERV qu'il conseille spécifiquement ce châssis que pour Rally & Slash 1/16, à part l'empattement. D'ailleurs, avec ce châssis on peut utiliser les carros qui font 200mm ! Ca fait un sacré choix en touring.
Tiens une petite question pour toi qui est un Pro MERV.FEATURES:
Nombre de messages : 527
Mar 1 Jan 2013 - 17:36
Excellent châssis, mais vraiment trop cher à 140$, a moitié prix, j'aurai démonté mon carbone integy peu pratique pour celui-ci...
Mais pour le coup! ça refroidit...
Nombre de messages : 333
Mar 1 Jan 2013 - 17:56
@Chezoit ton lien pour le châssis aluminium et faux c'est celui-ci ICI
Mar 1 Jan 2013 - 19:48
Je crois que le châssis est trop large pour un MERV et ces "gros" pneus.
J'adore l'idée sur servo standard.
Il est dispendieux mais il vient avec le center drive shaft CVD
Nombre de messages : 1697
Mer 2 Jan 2013 - 1:00
Enfin un châssis avec un servo standard mais chers comme toujours.
- [OLD NEW]Châssis aluminium LCG Slash 1/10 4X4 par MonsterKingz Aluminum LCG Chassis
- [NEW]Direction Aluminium Slash & Bandit 2WD Exotek Racing - 1984 SLASH PRO STEERING SET 7075
- [NEW] Châssis Carbon pour XO-1 par Xtreme RC Racing
