Hammerhead
Hammerhead
Nombre de messages : 435
Dico Traduction mots Anglais/Français modélisme MAJ 21/01/11 Empty Dico Traduction mots Anglais/Français modélisme MAJ 21/01/11
Ven 29 Aoû 2008 - 22:54
Alors voila j'ai trouver sa sur mmt et je le trouve super ce petit dico du modélisme.
Ne m'en vouler pas si ce n'est que du copier/coller (source)
Français-Anglais
A
Amortisseur = shock
angle de braquage = Steering Radius
accus = battery
aileron = wing
B
Barre anti roulis = Sway Bar
Bougie = Glow plug
boite de vitesses = gear shift ou gear box
Bouchon reservoir = Fuel cap
C
Cutter = Hobby knife
cloche embrayage= clutch bell
couronne =spur gear
chape direction = turnbuckle
culasse = cooling head ou Cylinder head
charbon = power brush ou motor brushes
Châssis = Chassis
Carburateur= carburator ou carbs ou carburetor
Chemise = cylinder
Bielle = connecting rod
Carter = casing ou crankcase
Carrosserie = body (peinte/painted), (perso/custom)
Cardans / Roues = Drive shaft / Driveshaft
Cardan / Central = Drive shaft Center / Driveshaft Center
D
Durite = Fuel Pipe
Disque de frein = brake disc
Direction=steering
Differentiel = differential ou diff
E
Ecrou = NUT
embrayage = clutch
F
Filtre a air= air filter
frein=brake
filtre à essence = fuel filter
G
Gras (reglage) = Richer
H
Heagone de roue= drive washer
I
Interrupter = Power switch
J
joint siliconne = manifold silicone
jante = Wheel rim
K
L
M
masselotte = clutch shoe
moteur electrique = motor
moteur thermique = engine
Marche arrière = Reverse shift
moteur noyé = flooding
N
O
Option = part
P
Pneu = tire
palonier = servo arm
Platine radio carbone = carbon fiber radio tray
Porte Fusée = Axle Carrier
Par-choc = Bumper
Pignon = Pinion
Q
R
Resonnateur= Exhaust ou pipe ou muffler ou tuned pipe
Roulement = Bearing ou ball bearing
Reservoir = fuel tank
Roue = wheel
Ressort = Spring
roue libre = fly whell ou ONE WAY
resistance = capacitor
recepteur = receiver
renforts chassis verticaux sur les TT et truggy = chassis Brace
Renfort chassis avant horizontal = front to plate
Renfort diff central = center brace
S
support moteur = engin mount / throttle arm / Mount motor
sauve servo = servo saver
Sec (reglage) = leaner
Soquet de demarrage = Glow Plug Starter
Supports d'amortos arriere et avant = rear and front shock tower
Servo direction = steering servo
T
tirette = pull start
Travail Fait main (perso quoi ...) = handmade work
train av/ar = front/rear drive train
Tournevis cruciforme = screwdrive
U
V
vilebrequin = crankshaft
Visse = screw
variateur = electric speed control ou ESC
Vis de reprise = low-speed needle
W
X
Y
Z
Thx. PreD / CHX MT PROD.
Vétéran Modo Jediwaa McGyver
Dico Traduction mots Anglais/Français modélisme MAJ 21/01/11 Empty Re: Dico Traduction mots Anglais/Français modélisme MAJ 21/01/11
Ven 29 Aoû 2008 - 23:17
Ah ça c'est bien !
Lun 1 Sep 2008 - 0:34
post-it
Très utile...pour moi c'est surtout de l'anglais au français... Embarassed
Dico Traduction mots Anglais/Français modélisme MAJ 21/01/11 Userba10
Hammerhead
Hammerhead
Lun 1 Sep 2008 - 10:31
mon premier post-it
merci chezoit
Baptiste
Baptiste
Nombre de messages : 1172
Jeu 11 Juin 2009 - 21:18
Question: kekcé le bash?
Jeu 11 Juin 2009 - 21:26
De Bashing = Frapper en Fr
>Donc ne pas pas trop prêter attention à Titine...et lui mettre des coups dure à la face...:cowboy:
CHX MT PROD
CHX MT PROD
Revoiste Jediwaaa IceMan
Nombre de messages : 790
Sam 7 Nov 2009 - 11:22
sinon il à
pushrods/knuckles/ball bearing/end rod/shaft/hex driver/remote control/blue groove/constant velocity drive/power wires/plugs/brushless Smile
je met les traduction ou .... pirat
Ven 21 Jan 2011 - 12:42
Mise à jour.
Correction : Cardan & Tournevis cruciforme
J'ai un doute sur la traduction de : Marche arrière > Reverse shift
@CHX MT PROD
Balance tes traductions. Wink
