[NEW]Boite en composite/alluminium Hot Racing 1/10 2WD VXL
Dim 16 Déc 2012 - 18:46
Boite en composite/Alluminium pour 1/10 2WD VXL
par Hot Racing
TE12GX01
Composite Gear Case W/Alum Motor Plate
Composite gearbox set with aluminum motor plate and arm mount for the Traxxas Rustler, Stampede and 2wd Slash
FEATURES:
Light weight graphite composite transmission case
Longer motor mounting slot for more gear ratio combination.
CNC 6061 Aluminum motor plate with added motor heat sink.
CNC 6061 Aluminum HD arm mount
More open area for a bigger motor heat sink.
Motor Plate with mounting for Slash stock rear bumper
YOU WILL RECEIVE:
One graphite composite transmission case with aluminum heat sink motor plate and arm mount
COMMENTS:
Best use with TE18L06
THIS IS A EMPTY GEAR CASE. This does not include any gears, shafts, or bearings.
Also works with electric Bandit, Rustler, or Stampede.
Lien Hot Racing
par Hot Racing
TE12GX01
FEATURES:
YOU WILL RECEIVE:
COMMENTS:
Lien Hot Racing
Re: [NEW]Boite en composite/alluminium Hot Racing 1/10 2WD VXL
Dim 16 Déc 2012 - 19:10
J'adore la petite touche HR avec les dissipateurs cylindriques
- [NEW] ALL RACING Frond Skid Plate for UDR / Ultimate Desert Racing
- [NEW] Pignons #7093 de boite 1/16 en acier par Hot Racing
- [NEW] Carter de Boite E-Revo Slash 1/16 par Hot Racing
- [NEW]Couvercle Aluminium boite de vitesse/Aluminum Upper Gear Box Cover X-Maxx Hot Racing XMX13M06
- [NEW] Bras RRVO21XG pour porte Fusée Hot Racing 5603 5605 5608 par Hot Racing
