>>New Servo Airtronics 94780M 30.5Kg/cm - 15s/60°
Lun 27 Oct 2008 - 20:41
Après Hitec et son HS-7950TG à 29 Kg/cm - 15s/60°
Airtronics 94780M contre attaque avec
30.5Kg/cm - 15s/60°
New from Airtronics:
After more than a year of development, Airtronics is now releasing its newest digital servo, the 94780M. This servo truly leads the industry with the highest rated torque of any standard servo we could find on the market today.
The servo case has a metal middle section for strength and cooling, the servo is held together with 6 screws instead of the normal 4 to prevent warping under stress, and internally, the gears are supported on shaft with brass plain-bearings built into the case to hold them straight and true. The gear train is all metal and the output is double ball bearing supported.
The "M" in the name is the Airtronics abbreviation for "all metal gears" but it could stand for "Monster" because this servo truly has Monster-Torque! The 94780M produces an industry leading amount of torque for a standard size servo at 423 oz/in (with 6.0V). Our test servos have been cycled more than 50,000 times pulling various weights of 100 ounces or more through their entire 60 degree movement. This servo is proving to have amazing longevity as well as amazing holding power. It will suspend a 6 pound weight, at any position in its travel, and will hold it precisely with no fade indefinitely. Most standard size servos will not even move 6 pounds!
Perhaps more amazing than the weight is the speed. This servo was not simply re-geared to get the higher torque! It's rated speed is still .15 seconds/60 degrees of travel @ 6.0V making it as fast or faster than most other 300+ oz/in servos from competing brands.
This servo is an industry leading digital servo in price as well. Most companies now use some sort of "suggested street price". Comparitively, our competition has an "ssp" of anywhere from $125 to $150 and this is for servos that are the same speed yet with less torque! When we designed this servo, we not only made sure it had industry leading power, longevity, and service-ability, we also made sure it had an Industry Leading Low Price!
That's right, the SSP on this servo is only $119.99 making it 5 to 25% LOWER than our competition.
Get Airtronics, Get the Advantage.
Published Specifications:
Weight: 2.33 oz - 66 grams
Dimensions: 1.6x.83x1.5 in - 4.06x2.11x3.81 cm
Torque: 361 in-oz/26 cm-Kg @ 4.8V; 423 in-oz/30.5 cm-Kg @6.0V
Speed: .19s/60 degrees @ 4.8V; .15s/60 degrees @ 6.0V
30.5Kg/cm - 15s/60°
- RicoSavagiste Jediwaaa SnakeMan
Nombre de messages : 506
Re: >>New Servo Airtronics 94780M 30.5Kg/cm - 15s/60°
Lun 27 Oct 2008 - 21:12
et bien voila , le cap des 30 kg est passé , 24 , 29 , 30 et maintenant 30,5 kg , bon pour le trois derniers l'écart est faible ,mais maintenant il y a 3 marques dans la catégorie poids lourds , alors qui passera le cap pour cette nouveautée
Rico
Rico
Lun 27 Oct 2008 - 21:42
Personnelle je voudrais bien mais mon Mon Ds8711 n'est pas près de lâcher.
Lun 27 Oct 2008 - 22:43
Chezoit a écrit:Personnelle je voudrais bien mais mon Mon Ds8711 n'est pas près de lâcher.
je suis dans le même cas que toi , mais de toute façon a ce niveau de gamme , c'est a peut pret la même qualitée , plus une histoire affective avec une marque ou une autre , mais j'imagine rien que pour le fun sur mon Revo trial deux servo comme ceux la , et hop 61 kg a la direction
Rico
Lun 27 Oct 2008 - 23:09
Mer 29 Oct 2008 - 19:29
J'avais vu sur un forum, un parano qui avait mis deux Ds8711...Mais je ne me rappelle plus où !?
Jeu 30 Oct 2008 - 12:07
Ven 31 Oct 2008 - 9:22
8717, pas 8711 , ils sont plus rapides mais moins coupleux, on utilise ça sur nos hélicos taille 50 à 90,
je crois qu'ils font 0,07 sec et 13kg de couple en 6v, mais je suis pas sûr,
ps: juste pour infos, il fonctionnent jusqu'en 8,4V.
Ven 31 Oct 2008 - 10:43
Oups...
deux fois 85€.....8711 108€...On n'est plus à quelques euros près...
