[New] Axle Carriers/Porte-Fusée/TKR1014 par Tekno RC/TeknoRC
+11
Majestic3
Sharky38
mickael02
Nitrous
15 participants
Page 1 sur 2 • 1, 2 ![Suivant](https://2img.net/i/fa/modernbb/arrow_right.png)
Nombre de messages : 1457
Jeu 30 Oct 2008 - 7:29
Porte-Fusée pour 1/8
Par Tekno RC
![[New] Axle Carriers/Porte-Fusée/TKR1014 par Tekno RC/TeknoRC Tkr1014](https://2img.net/h/i99.photobucket.com/albums/l318/chezoit/New%20RP/tkr1014.jpg)
quelques news de chez tekno rc
et celle la vraiment terrible
Je cite :
Once again Tekno RC brings you a quality product to easily add functionality and durability to your RC vehicle. And they bring it to you at a great price - check the competition.
These heavy duty axle carriers and 17mm adapters are nearly bulletproof and are loaded with features that racers and bashers have been asking for:
* Heavy duty axle carriers with additional Ackerman locations*
* Industry standard 17mm hex adapters - specially designed to have the least amount of slop of any competing 17mm adapter on the market
* 8mm stub axles and bearings - the industry standard
* Aluminum retainer rings
* Set screws help to keep the pillowball caps in place where they belong
* mates to stock driveshafts
Contents:
* (2) Tekno RC axle carriers
* (2) 17mm hubs
* (2) 17mm wheel nuts
* (2) 8mm stub axles
* (2) 8x16x5 bearings
* (6) retainer rings (see instructions for mounting locations)
* all necessary hardware and instructions
* shorter toe links are required to use additional (non-stock) Ackerman locations.
@+ Edit:Lepeople.
Par Tekno RC
Je cite :
Contents:
* (2) 17mm hubs
@+ Edit:Lepeople.
Re: [New] Axle Carriers/Porte-Fusée/TKR1014 par Tekno RC/TeknoRC
Jeu 30 Oct 2008 - 10:59
Le skid c'est sympa ! J'ai vu sur le forum traxxas que les mecs l'use à fond à cet endroit !
Les porte fusée ont l'air de bonne qualité mais je vois pas l'intérêt ! Sauf les positions d'ackerman en plus mais ça il suffit de percer un autre trou !
A++
A++
Jeu 30 Oct 2008 - 11:18
les portes fusées
axe 8mm
systeme anti deboitement
et différent effet akerman
axe 8mm
Jeu 30 Oct 2008 - 11:24
jejebrl a écrit:les portes fusées
axe 8mm
Oui l'axe de 8mm j'ai après c'est vrai que c'est bien ça
Pour l'antidéchappage ça peut servir en mode bash
Jeu 30 Oct 2008 - 11:31
Tres bonne news... Tekno Rc nous propose des pièces intelligentes bien adaptées à l'usure de nos Revo, c'est top! ![Very Happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png)
Nombre de messages : 28087
Jeu 30 Oct 2008 - 14:15
Fusées commandées ! Olé ! Enorme !
Pour la skid plate arrière, j'ai installé récemment les integy Titane...et je peux vous dire que c'est vraiment top !..oui oui j'ai bien dit Integy !![Laughing](https://2img.net/i/fa/i/smiles/icon_lol.gif)
Nombre de messages : 3170
Jeu 30 Oct 2008 - 15:10
(javais posté deja mais mon message a du etre supprimé ....)
je disais donc que j'aime bien ce systeme pour les fusées moi jarretais pas de déchapper avant !
Ven 2 Oct 2009 - 11:13
Juste un p'tit retour que j'avais complètement oublié de donner concernant les fusées TeknoRC.
>Aucune déformation emplacement et sortie axe de rotule.
>Pas-de-vis un peu light, attention quand vous visez les bloques rotules.
>Petit conseil changer les bloques rotules par des Hot Racing, ils sont plus long.
>Attention si vous avez des cardans autres que ceux d'origine....pas compatible.
Il vous faudra acheter des roulements spécifiques à vous axe de cardan et surtout les hexa 17mm fournis dans le pack seront inutiles...
Sinon Super costaud !
Ven 2 Oct 2009 - 13:16
perso je les est eu, et j'en suis deçue: les rotule titane HCR passe mal dedans, pour elles sont a la taille d'origine. les rotule biellette sont aussi monter vachement serré, faut forcer un peu pour les mettres, ou limer... perso, je suis repasser a celle du révo plat'!
Ven 2 Oct 2009 - 15:46
Yes j'ai eu ce problème avec des rotules GPM en titane....sur des fusées RPM et les TeknoRC.
Je les ai remplacés par des MIP et je ne te dis pas la différence poids/finition !
Depuis ça ne "coince" plus. Je les ai testés aussi sur les Fusées RPM et idem, nickel !
Concernant les rotules des biellettes, c'est vrai qu'il faut forcé un peu pour les faire entrer à leur emplacement....mais rien de bien méchant.
Sinon oui, j'avais oublié de parler des différents emplacements biellettes, c'est vraiment top.![:sup:](/users/3215/32/39/59/smiles/864918.png)
Personnellement je ne pourrais pas revenir à celle d'origine...j'en ai déjà explosé 3...![:cowboy:](/users/3215/32/39/59/smiles/269829.gif)
![affraid](https://2img.net/i/fa/i/smiles/affraid.gif)
Nombre de messages : 277
Mer 18 Nov 2009 - 12:43
Salut a tous,
Je n arrète pas de déchapper et sa me saoule grave
Ces portes fusées sont elles les meilleurs pour arreter de tout le temps tout remonter
Pour info j ai des portes fusées RPM depuis peut et c est comme celles d origines
déchappage a gogo
Merci @ plus mickael![Wink](https://2img.net/i/fa/i/smiles/icon_wink.gif)
![Evil or Very Mad](https://2img.net/i/fa/i/smiles/icon_evil.gif)
![Question](https://2img.net/i/fa/i/smiles/icon_question.gif)
Mer 18 Nov 2009 - 14:50
Depuis que je les ai, je n'ai plus de problème de déboitement.
Sinon les allu tout confondus ont aussi de bons retours.
Lun 24 Sep 2012 - 14:59
ok , si je me trouve au bon endroit , concernant les PORTE fusée tkrc , on ne parle pas du roulement interieur de 21x17x5 , il ne rentre pas dans la fusée , je ne pense pas q il faut monter le cardant sans roulement , il fournisse le roulement exterieur , mais pourquoi pas l interieur ?
Lun 24 Sep 2012 - 15:04
Parce que le roulement interne est identique à l origine.
Lun 24 Sep 2012 - 15:50
ouai , ok , mais le roulement pour les porte fusée rpm , ne sont pas les meme que pour l origine , ca ne risquai pas de rentrer , origine en 12x18x4 , rpm en 12x21x5
donc je dois me commander les roulement origine trx
- Sharky38Revoiste Padawaaa super motivé
Nombre de messages : 141
Mer 10 Avr 2013 - 13:18
Hello JeJebrl,
Où as tu trouvé tes soufflets de protexion, stp?
thanks!
thanks!
Nombre de messages : 439
Mer 10 Avr 2013 - 13:32
C'est d'origine sur le 1/8
Mer 10 Avr 2013 - 19:55
ok!
Oui j'ai vu qu'il en existait pour les 1/16, ça fera parti d'un prochain voyage!!!
Jeu 11 Avr 2013 - 1:29
Pour info, ça ne sert à rien du tout.
Jeu 11 Avr 2013 - 9:49
Ah oui?
Pourtant sur les bécanes, ça sert bien mais on a les joints spies et pas là...
Ok!
Thanks!
Ok!
Thanks!
Jeu 11 Avr 2013 - 10:05
Non ça sert à rien. Ça fait des années qu'ils se sont coupé et que je n'ai pas de problèmes.
La preuve ils n'y sont même pas sur les 1/16 d'origines.
Mais dis moi, tu n'aurais pas l'intention d'aller mettre de la graisse derrière ces joints que tu voudrais monter ???
Jeu 11 Avr 2013 - 23:04
Ou là là non!!!!!Gsxzera a écrit:Mais dis moi, tu n'aurais pas l'intention d'aller mettre de la graisse derrière ces joints que tu voudrais monter ???
Là tu te moques!!!
![Suspect](https://2img.net/i/fa/i/smiles/suspect.gif)
Jeu 11 Avr 2013 - 23:39
Non, je moque pas ![Very Happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png)
Mais je préfère te demander, on sait jamais
Jeu 11 Avr 2013 - 23:47
Mais j'ai bien compris!
C'est bon la dérision (dans le sens moquerie taquine et non malsaine!)
Ven 12 Avr 2013 - 0:14
Il n'y a pas longtemps j'ai vu que quelqu'un avait mis de l'huile de silicone pour amortisseurs dans la boite à vitesse.
Donc tout est possible
- [NEW] Porte-Fusée pour X-Maxx par RPM Racing - Oversized Front Axle Carriers #80662
- [NEW]Porte-fusée arrière aluminium X-Maxx/ALUMINUM REAR AXLE CARRIERS FullForce RC XMX005
- [News] Tekno RC Axle Carriers and 17mm Adapters
- [NEW] Dhawk Racing CNC Aluminum 7075-T6 Rear Carriers For Sledge - Porte-fusée arrière
- [OLD NEW] Porte-fusée/Cardan 1/10 2WD Tekno RC TKR1951X TKR2210
