[NEW] Radio GT3C 8 voies/Channel !!! Customiser/Customized/Upgrader/Kit/DIY par DasMikro
Mar 26 Avr 2016 - 10:54
Radio GT3C 8 Voies
Customiser par DasMikro
Option:
Option A: 6 Channel
It uses 4 channel PPM expander PCB and keep the first channel and the second channel, add 4 channels from channel 3 to channel 6, in this case you could bind FLYSKY 6CH receiver to use all 6 channels. (channel 1 and channel 2 are from GT3C original, channel 3 and channel 4 are 3 position toggle switch, channel 5 and channel 6 are potentiometers.
Option B: It uses 4 channel PPM expander PCB and the third channel, add 4 channels from channel 4 to channel 7, in this case you could bind FLYSKY 8CH receiver to use all 7 channels. (channel 1, channel 2 and channel 3 are from GT3C original, channel 4 and channel 5 are 3 position toggle switch, channel 6 and channel 7 are potentiometers.
Option C: It uses 6 channel PPM expander PCB and keep the first channel and the second channel, add 4 channels from channel 3 to channel 8, in this case you could bind FLYSKY 8CH receiver to use all 8 channels. (channel 1, channel 2 are from GT3C original, channel 3, channel 4 and channel 5 are 3 position toggle switch, channel 6 , channel 7 and channel 8 are potentiometers.)
Radio Prête, vendu sans RX/Récepteur...82.99$ (Lien Banggood)
Article & Source Radio GT3C 8 Voies RC305.cz
Article & Source Kit DasMikro RC305.cz
Option:
Option A: 6 Channel
Nombre de messages : 714
Re: [NEW] Radio GT3C 8 voies/Channel !!! Customiser/Customized/Upgrader/Kit/DIY par DasMikro
Mar 26 Avr 2016 - 21:49
ça dit quoi cette marque ?
Ven 29 Avr 2016 - 11:57
FLySky est une très bonne marque qualité / prix.
Ma radio, c'est une FS-iTa. C'est cheap au niveau du design, mais je ne regarde pas ma radio pendant que je roule, par contre je peux voir mes paramètres en Live Tactile.
C'est à eux qu'on doit l'accessibilité des radios RTR de bonne qualité.
Pour revenir à la GT3, son seul problème, c'est le bouton on/off qui lâche assez rapidement.
Donc à remplacer par un interrupteur classique.
Source RC 305.
Source RC 305.
Ven 29 Avr 2016 - 13:37
ok, fly sky je connais maintenant que j'ai le vortex pro, j'ai une flysky taranis x9d pour le drone également, très bonne radio paramétrable dans tous les sens, en open tx, donc open source, impec
si c'est le cas pour celle là, c'est très bien
Dim 1 Mai 2016 - 23:57
et intéressant :-)
Lun 2 Mai 2016 - 10:01
Ohh mon Patoff, ça roule ?
Yes super new pour les crawler man & SummitMan qui veulent garde le volant.
ps. ton avatar est dead.
@Viceral Tek
Seul petit hic, comparé à ce que j'ai eu ou pu tester : Gâchette & Volant légèrement moins précis qu'une Sanwa /Futuba ou encore Ko Propo, mais rien de méchant.
Par contre, il faudrait vraiment qu'ils y pensent (FkySky), mettre un lock sur leur radio.
@Viceral Tek
- [NEW]Radio GT3C 8 voies PSX0.6.1 firmware/ChannelCustomiser/Customized/Upgrader par DasMikro
- [NEW] WFLY Radio X9 - 9 Ch with touch screen - Radio 9 Voies avec Écran tactile
- [OLD/NEW] Radio Step Up RZT 2.4GHz 2 Channel Radio System
- [NEW] RadioLink Radio RC8X - 8 Channels with Full Color IPS Touch Screen - Radio tactile 8 voies
- [NEW] Fly Sky FS-G7P - 7 channels Radio - 7 voies/Ch
