[NEW] ESC Brave & Yong Wolf Waterproof 180/150/120/80A 1/10 1/8 par FVT/Favourite Empty [NEW] ESC Brave & Yong Wolf Waterproof 180/150/120/80A 1/10 1/8 par FVT/Favourite
Mar 10 Mai 2016 - 15:59
180/150/120/80A - 1/5 1/8 1/10
par FVT (FaVouriTe)
[NEW] ESC Brave & Yong Wolf Waterproof 180/150/120/80A 1/10 1/8 par FVT/Favourite ESC%20FVT%20WP%202
Spec 180A.
NOTE: NOT recommended for use with 6-pole motors.
Output: Continuous 180A, Burst 1260A
Input: 6-18 Cells NiMH/NiCd or 2-6S LiPo
(When using 2S lipo or 6 cells NiMH, an UBEC or seperate battery is strongly recommended to supply the receiver)
BEC Output: 5V/6V/7.4V/8V@9A (Switching Mode)
Resistance: 0.0002 ohm
Motor Supported: Sensored/Sensorless Brushless Motor
Suitable Motors: Brushless sensored/sensorless KV<=2500
Suitable Car: 1/8 1/5
Size: 64.8mm(L) x 41.8mm(W) x 42.8mm(H)
Weight: 112g (without wires)
Spec 150A.
Output: Continuous 150A, burst 1080A.
Input: 6-18 cells NiMH/NiCd or 2-6S LiPo.
BEC: 5.75V/9A (Switching Mode)
Resistance: 0.0002 ohm.
Motor Supported: Sensorless brushless motors.
Suitable Motor: KV<=2500. * Note #1
Suitable Car: 1/5 and 1/8 scale on-road or off-road sport.
Size: 64.8mm(L) x 41.8mm(W) x 42.8mm(H).
Weight: 110g (Without wires)
Spec 120A.
Output: Continuous 120A, Burst 640A
Input: 5-18 Cells NiMH/NiCd or 2-6S LiPo
BEC Output: 6V/3A (Switching Mode)
Suitable Motors:
With 6 cells NiMH/NiCd or 2S LiPo: KV≤6000
With 7-9 cells NiMH/NiCd or 3S LiPo: KV≤4000
With 10-12 cells NiMH/NiCd or 4S LiPo: KV≤3000
With 13-18 cells NiMH/NiCd or 5/6S LiPo: KV≤1500
Suitable Car: 1/10, SCT
Size: 56.5mm(L) x 38mm(W) x 32mm(H)
Weight: 108g (Without wires)
Spec 80A.
Output: Continuous 80A, Burst 540A
Suitable Motors:
Boitier de programmation et USB LINK (ce dernier pour le 180A&150A)
[NEW] ESC Brave & Yong Wolf Waterproof 180/150/120/80A 1/10 1/8 par FVT/Favourite FVT%20ACC
QUICKLY AND EASILY ACCESS THE FOLLOWING SETTINGS:
Motor Timing: Very Low, Low, Normal, High, Very High
Acceleration: Low, Medium, High, Very High
Running Mode: Forward/Brake, Forward/Reverse/Brake, Forward/Reverse
Brake Force: 10%, 20%, 30%, 40%, 50%, 60%, 70%, 80%, 90%, 100%
Drag Brake: 0%, 5%, 10%, 15%, 20%, 25%, 30%, 35%
Cut-Off Voltage: 2.6V/cell, 2.8v/cell, 3.0v/cell, 3.2v/cell, 3.4v/cell
Max Forward Force: 20%, 40%, 60%, 80%, 100%
Max Reverse Force: 20%, 40%, 60%, 80%, 100%
Motor Rotation: Normal, Reverse
Neutral Range: 3%, 5%, 7%, 9%
Battery Type: NiMh, LiPo
Arrow USB Link Software/Instructions
Arrow Dispo sur Ebay (Paypal) / Aliexpress / Banggood (Paypal)
[NEW] ESC Brave & Yong Wolf Waterproof 180/150/120/80A 1/10 1/8 par FVT/Favourite Userba10
