>> New Radio Tactic TTX 240 2.4 Ghz
+3
Aricospeed
7 participants
Sam 21 Mar 2009 - 3:07
Voilà une radio 2.4GHz à petit prix !
Radio Tactic TTX240 2.4Ghz
et son Récepteur Tactic RX324 2.4GHz
An incredible value in 2.4GHz surface control!
Spread spectrum systems are all the rage – and Tactic is proud to offer a 2.4GHz pistol-grip radio for cars, trucks and boats that’s tops in simplicity, durability and affordability! Cutting-edge electronics make the TTX240 virtually “bulletproof” against interference and glitching, yet, priced to fit within almost any modeler’s budget. Spread spectrum technology eliminates crystals, frequency pins and waiting for a channel to become available. The super-small receiver locks onto the transmitter’s unique signal and won’t respond to signals from any other source. Compatible with a wide range of digital and analog servos, the Tactic TTX240 works well with both nitro and electric models. Binding the compact, quarter-ounce RX324 receiver to the transmitter is virtually as simple as turning them on. An internal receiver antenna makes old-fashioned antennas obsolete.
Available with all these great features:
• 2.4GHz transmitter
• 2.4GHz “binding” receiver
• Built-in fail safe
• Steering and throttle trims
• Steering and throttle servo reversing
• Steering rate adjustment
• Power LED
• 1-year limited warranty
ATTENTION LA RADIO ET LE RÉCEPTEUR SONT VENDU SÉPARÉMENT !
ET LA RADIO EST VENDU SANS NOTICE ! mais bon rien de bien méchant...
Lien Radio chez Tower Hobbie
Lien Récepteur chez Tower Hobbie
• Power LED
Re: >> New Radio Tactic TTX 240 2.4 Ghz
Sam 21 Mar 2009 - 10:11
Le fail safe c'est pas mal !
mais les fins de courses sont réglables ?
Sinon pour les petits budgets c'est cool !
Nombre de messages : 1267
Sam 21 Mar 2009 - 11:02
Un peut plastique à mon goût ..
Sam 21 Mar 2009 - 11:03
Oui faudrait changer le volant !
Nombre de messages : 3170
Sam 21 Mar 2009 - 11:08
oué trop plastique a mon gout aussi .... sa fait jouet Nikko ....
Sam 21 Mar 2009 - 11:36
Sans le volant noir elle aurait au contraire un look bien fini !
Sam 21 Mar 2009 - 11:40
ah bon ... moi c'est justement les boutons gris qui tournent qui me gene ... la poignet sans mousse ou caoutchouc.... le volant aussi comme vous dites ....
Avis perso
Avis perso
Sam 21 Mar 2009 - 13:40
J'ai trouvé ce tout petit manuel...
Sam 21 Mar 2009 - 15:08
En même temps il n'y a rien rien de plus à expliquer !
Sam 21 Mar 2009 - 16:41
héhéhé Tu m'étonne...
Sinon elle a des faux airs de M11
Sam 21 Mar 2009 - 23:08
Mouais, je trouve sa tres bien moi, je crois je vais en prendre une bientot,
Je veut juste la technologie 2.4g , j'ai pas les moyens d'avoir une spektrum!
Nombre de messages : 984
Dim 22 Mar 2009 - 0:15
tiens nous au courant des que tu l'as recois
Dim 22 Mar 2009 - 10:10
Oui, mais c'est pas pour tout de suite non plus, j'ai quelque frais a faire sur le revo!
Dim 22 Mar 2009 - 11:53
je sais plus si la 2.4ghz de traxxas est sortie deja ....
parce que je prefere la TRX que celle là
Dim 22 Mar 2009 - 12:01
avec la trx on peut regler les fin de course ?
Dim 22 Mar 2009 - 12:04
Dim 22 Mar 2009 - 12:38
revoman a écrit:avec la trx on peut regler les fin de course ?
non
mais esthétiquement et en fiabilité c'est un autre monde
rare sont les emmerdes avec les radio trx
mais bon on peut pas avoir tout les réglages sur des radio bas de gamme non plus
alors pour les radio 2.4 a moins de 80€ faut pas demander les fin de courses, dual rate, sub trim et tout le tsoin tsoin
je pense que c'est pas mal pour débuter en 2.4 sans être emmerdé
attention en revanche
le 2.4 a non changement de freq va bientôt être interdit en france
futaba a créée le système FASST pour palier a ça
mais pour le moment ce sont les seul
le FASST change de fréquence tout les 2secondes
Dim 22 Mar 2009 - 12:48
la TRX 2.4ghz peut régler les fins de courses non ?
Dim 22 Mar 2009 - 14:25
Flo65 a écrit:la TRX 2.4ghz oui
Oui quoi ? ^^
La tactic a un réglage de fin de courses juste pour la direction
Sinon Gilou les Radio en 2.4ghz sont toujours à la même fréquence, le 2.4ghz non !? Seul les nouvelles normes Wi fi pour ordi sont en 5 ghz.
C'est pas plutôt le codage qui change ?
Dim 22 Mar 2009 - 14:29
je croyais que la 2.4ghz de Traxxas peut régler la fin de course servo ...
Dim 22 Mar 2009 - 19:43
lepeople. a écrit:Flo65 a écrit:la TRX 2.4ghz oui
Oui quoi ? ^^
En fait je crois que c'est normal qu'il ne switch pas (et comment l'éméteur le détecte la coupure d'ailleur). Le principe est d'émettre sur toute la bande (toutes les fréquences un peut comme si il émettait sur toutes les fréquences de 41000 à 42000) et de multiplier à l'émission par un code orthogonal avec tous les autres codes (de la même race que le fameux code qui se perd avec futaba). En réception on reçoit tout de tout le monde, on re multiplie et il ne reste que les bonnes infos. C'est le principe de l'UMTS. Après ils ont peut être coupé la bande en sous bandes ... mais ils ne fournissent pas l'info. En tout cas en UMTS si on est perturbé, il n'y a pas de changement de fréquence ca c'est sur. Par contre une sous bande est fixée pour chaque antenne et le portable émet et reçois de plusieurs antennes (NodeB) simultanément.
Toujours si j'ai bien compris, avec futaba c'est le même genre mais ils ont coupé la bande des 2.4 en plein de sous bandes et ils sautent constamment de l'une à l'autre, le récepteur recevant constemment sur toutes à la fois (d'ou l'utilité du fameux code).
les radio spektrum etc ne change de freq que quand ya une merde et encore pas a chaque fois
les fasst changent quoi qu'il arrive
Dim 22 Mar 2009 - 20:14
Ok merci gilou, mais en fait pourquoi il veulent interdire le système classique ?
Dim 22 Mar 2009 - 20:24
pour éviter les interférences
le 2.4 est une freq poubelle
Dim 22 Mar 2009 - 21:55
Poubelle ?
Dim 22 Mar 2009 - 22:43
oui le 2.4 regarde bien sur gogol tu verra la bande wifi est une bande appelé poubelle
- [NEW] WFLY Radio X9 - 9 Ch with touch screen - Radio 9 Voies avec Écran tactile
- [NEW] RadioLink Radio RC8X - 8 Channels with Full Color IPS Touch Screen - Radio tactile 8 voies
- [OLD/NEW] Radio Step Up RZT 2.4GHz 2 Channel Radio System
- [FUTURE NEW] Radio Tactile QUASAR - OXIDEAN MARINE’S UPCOMING RADIO SYSTEM – THE QUASAR
- [NEW] MT-4/MT4 2.4Ghz par Sanwa
