Vétéran Modo Jediwaa McGyver
Nouveau TRX 3.4 par Losi... Empty Nouveau TRX 3.4 par Losi...
Jeu 25 Juin 2009 - 11:30
Voici le nouveau small block de Losi qui n'est autre qu'un TRX:
Nouveau TRX 3.4 par Losi... LOSR2100-450
Displacing a category-leading .20 cubic inches, the Losi 3.4 Performance Engine packs big block torque into a small block footprint. The result is unmatched power for an engine this size, offering outstanding acceleration from a standstill all the way up to the top end. Developed from the ground up with inspiration from some of the most potent race-proven engine designs, the Losi 3.4 has a wide RPM range for more torque wherever you need it.
Features
Most displacement of any small-block nitro engine
ABC Piston and sleeve construction
Anodized cooling head with built-in head protector for style and protection
Brushed T6 aluminum connecting rod
Solid SG-style crankshaft
Designed for speed and power for small-block applications
6.9mm Slide carburetor with dual mounting position high-speed needle
Composite carburetor body reduces the risk of vapor lock
Product Specifications
Displacement:.20 cubic inches
Bore:16.90mm
Stroke:15.30mm
Engine (Only) Weight:220.40g
Benchmark Prop:34000rpm
Fuel:10-30% Nitro
HP:1.8
