[NEW] Option ST Racing Concepts STRC pour 1/16
Mer 15 Juil 2009 - 20:38
STRC Repart à l'assaut de Traxxas
et dessine des options pour les 1/16.
Voici le Rendu Final des D.A.O (pour Pulse )
STRC toujours au taquet niveau finalisation !
Aluminum Front and Rear Shock Towers for Traxxas mini Slash and mini E-Revo
CNC Machined from high grade aluminum, these shock towers for the Traxxas
mini Slash and E-Revo will strengthen the upper shock mounting and offers
great looks for your new Mini Slash or Mini E-Revo. Made with the same quality and
precision you have come to expect with ST Racing Concepts products.
Available in anodized blue, red, and silver.
ST7043FB/R/S CNC Machined Aluminum Front Shock Tower: MSRP $8.99
ST7043RB/R/S CNC Machined Aluminum Rear Shock Tower: MSRP $9.50
Aluminum Front and Rear Rocker Arms for Traxxas mini Slash and mini E-Revo
Increase the strength and add great looks to your Traxxas Mini Slash and
mini E-Revo’s suspension with our CNC Machined Aluminum Rocker Arms.
These rocker arms not only look great, but also take out any flex from the
plastic stock rocker arms. Available in anodized Blue, Red and Silver.
ST7158FB/R/S CNC Machined Aluminum Front Rocker Arms (1 pair): MSRP $14.99
ST7158RB/R/S CNC Machined Aluminum Rear Rocker Arms (1 pair): MSRP $14.99
Aluminum Large Finned Motor Mount and Motor Heat Sink Plate
Greatly reduce the heat from your Traxxas Mini Slash and Mini E-Revo’s high power brushless motor with our CNC Machined Aluminum Large Finned Motor Mount and Motor Heat sink plate. The ST7060 large finned motor mount is lighter than the stock piece and machined with longer heat sink fins to receive more air-flow and reduce more heat from the motor, while our ST7077 Motor heat sink plate with a finned design is not only light weight, but also further reduces heat from the motor. When the two are used in combination, the heat is greatly reduced from the motor, keeping you running stronger longer. Available in anodized blue, red and silver.
ST7060B/R/S CNC Machined Alum. Large Finned motor Mount. MSRP: $12.50
ST7077B/R/S CNC Machined Alum. Finned Heat sink motor plate MSRP: $8.99
Aluminum threaded shock bodies and CNC Machined Aluminum Hex Adapters
Increase the smoothness of your Mini Slash or Mini E-Revo’s suspension with our
CNC Machined aluminum shock bodies while adding great factory looks to your
vehicle as well. Available in anodized blue, red and silver.
Our CNC Machined Aluminum hex adapter uses a set-screw over drive pin design that
keeps the hex adapter in place so you don’t loose the drive pin when you remove your
tires off the Mini Slash or E-Revo. The strength of aluminum also prevents hex from
rounding itself out inside the wheel from the high-power brushless system.
ST7066B/R/S CNC Machined Aluminum threaded shock bodies (4pcs) MSRP: $15.99
ST7154B/R/S CNC Machined Alum. Hex Adapters (4 pcs) MSRP: $13.99
STRC
STRC
Re: [NEW] Option ST Racing Concepts STRC pour 1/16
Lun 3 Aoû 2009 - 23:32
Rendu final !
- PierreRevoiste Dr Tong
- Nombre de messages : 370
Mar 4 Aoû 2009 - 2:56
Ca équivaut quelle marque ces pièces en terme de solidité ?
Mar 4 Aoû 2009 - 4:24
et on les trouve ou sur le marché
car introuvable sur leur site !!!
c'est le bordel, il est pas clair du tout
Mar 4 Aoû 2009 - 11:35
A Main Hobbies en vendent.
Pour ce qui de leur qualité, les retours sont "normal".
