[FORUM] Tout Petit jeu Revopowaaa Empty [FORUM] Tout Petit jeu Revopowaaa
Mar 13 Oct 2009 - 1:28
Salut à tous,
Je lance un p'tit jeu.
Celui qui me trouve un lien avec toutes les spécificités du MMMv3, du moins le liens le plus complet;
Je lui offre un T-Shirt Revopowaaa v2 FPDI que je suis en train de terminer... :siffle:
UN LIEN COMPLET !
[FORUM] Tout Petit jeu Revopowaaa Userba10
[FORUM] Tout Petit jeu Revopowaaa Empty Re: [FORUM] Tout Petit jeu Revopowaaa
Mar 13 Oct 2009 - 1:48
si je trouve ca m'en fera 2 alors :BD:
jeffbusa
jeffbusa
Nombre de messages : 214
salut chezoit
sa peux tu etre bon !!!!!!!!!!! il y a bonne info sur se lien....
http://www.castlecreations.com/support/faq.html#esc1
All ESCs
1. Why is it the more batteries I use, the less servos the BEC can handle?
The BEC converts the excess voltage from the power battery down to 5 volts by turning the excess voltage into heat. The higher the power battery voltage is, the more heat the BEC needs to dissipate. Making sure there is airflow over the BEC, which is on the LED side of the controller, helps with BEC heat dissipation and is important to BEC operation. The BEC is thermally protected and will shut down, then immediately come back on without being damaged, if the servo load is too much.
Mar 13 Oct 2009 - 17:32
Mouep mouep... Wink
Baptiste
Baptiste
Nombre de messages : 1172
Mar 13 Oct 2009 - 18:53
Alors il a gagné?
Mar 13 Oct 2009 - 19:33
Je pense qu'on peut trouver facilement plus complet. pirat
Nombre de messages : 3170
Mar 13 Oct 2009 - 19:34
exact ! Wink
Namzar
Namzar
Nombre de messages : 615
Mar 13 Oct 2009 - 19:49
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUWH2
This is the Castle Creations Mamba Monster Version 3 Speed Control.
FEATURES: Designed for extreme 1/8 scale monster truck applications Profiles can be custom designed on a PC Infinitely adjustable throttle and brake curves with timing advance Punch Control allows dialing in horsepower where needed Brake Strength allows straight tracking under hard braking Drag Brake helps entry into corners Start Power for smooth launches Programmable cutoff voltage for LiPo usage
INCLUDES: Castle Creations Mamba Monster speed control with 6.5mm bullet motor connectors, pre-tinned battery leads, ON/OFF switch with Universal receiver connector
REQUIRES: Installing in vehicle Brushless motor such as the Castle Creations NeuMotor 1512 or the NeuMotor 1515 USB cable
SPECS: Cells: 18 NiCd/NiMH, 6 cell LiPo Continuous: N/A Resistance: .0003 Ohm Brake: Proportional with adjustable curve Reversible: Yes, with lockout Low Voltage Cut-off: Programmable Size: 2.2 x 1.9 x 1.4" (56 x 48 x 35mm) Weight: 4.3oz (121g) Connector Type: 6.5mm
-jml- 6.20.08 ir/jxs
– If you need more information, use these Castle Creations resources –
E-mail: support@castlecreations.com
Web Site: http://www.castlecreations.com/
Phone: 913-390-6939
Postal Address:
Castle Creations
235 S KANSAS AVE
OLATHE, KS 66061
hihi ^^
Dernière édition par Namzar le Mar 13 Oct 2009 - 19:55, édité 1 fois (Raison : ^nouveau lien^)
Mar 13 Oct 2009 - 19:50
peu bcp bcp mieux faire ! ! !
Baptiste
Baptiste
Mar 13 Oct 2009 - 21:34
Tu veux pas me lacher le tee-shirt Chezoit?^^
C'est pour la FDH... :siffle:
Mer 14 Oct 2009 - 1:29
Ce n'est pas le but du jeu. Il faut un échange. Wink
jeffbusa
jeffbusa
Mer 14 Oct 2009 - 2:51
jai trouver ce lien , qui est les info qui vient avec le kit mamba monster...
http://www.castlecreations.com/support/documents/drivers_ed_guide.pdf
neuf cube
Nombre de messages : 18
Mer 14 Oct 2009 - 4:14
_David
_David
Nombre de messages : 669
http://www.tram-riders.com
Mer 14 Oct 2009 - 11:27
Mer 14 Oct 2009 - 11:46
@jeffbusa
C'est le manuel Général. Rien de spécifique. nan
@Neuf Cube...tu t'es pas foulé toi ! Very Happy
Ok mais où sont les spécificités ?
@_David
Tu peux retrouver ton lien dans le lien de Neuf cube...juste au dessus de ton poste. Very Happy
Personne d'autres ? Very Happy
_David
_David
Mer 14 Oct 2009 - 12:07
la page du constructeur : http://www.castlecreations.com/products/mamba_monster.html mais c est trop facile...
du coup : http://www.beatyourtruck.com/prodreview-monstermamba.html
google c est plus ce que c etait ! Smile
Mer 14 Oct 2009 - 14:24
Mouep, les infos officielles...et le test de Beatyourtruck...
Apparemment on ne trouvera pas plus d'info !!?? drunken
Mer 14 Oct 2009 - 14:49
En même temps tu veux plus d'infos sur quoi ? tu veux faire quoi ?
Padbol
Padbol
Revoiste Jediwaaa SummeurMan
Nombre de messages : 1124
Mer 14 Oct 2009 - 16:08
Tu veux quoi au juste ?
Je voit pas comment mieux faire que la page du constructeur ...
Mer 14 Oct 2009 - 16:12
c'est clair ... tu veux un plan détaillé ? tous les composants présents ?
tu veux les faire galérer !
Mer 14 Oct 2009 - 18:26
MMmmMM Qu'est ce que je veux...C'est bon ça ! Very Happy
Toutes les spécificités de l'ensemble du contro en lui même.
ex. Ouput sur récepteur (comme dernièrement), Courant en crête, etc.
Je ne sais pas si ce lien existe...mais personnellement j'aime les challenges ! héhéhé Very Happy
Et si personne ne trouve, je filerais quand même un T-Shirt à la personne du lien qu'on (Staff Revopowaaa) trouvera le plus complet.
Nitrous
Nitrous
Nombre de messages : 598
http://centralemaxx.keuf.net/
Mer 14 Oct 2009 - 18:37
Mamba Monster ESC
Retail Price: $199.00
Cells: 6s LiPo
Continuous: 120A*
Resistance: 0.0003 ohms per phase
Reversible: Yes - with lockout
Low Voltage Cutoff: Programmable
Size: 2.2" x 1.9" x 1.4"
Weight w/wires: 121g (4.26 oz)
Connector: 6.5mm bullet
Please note that our dyno is a Magtrol -- reports about 5%-6% lower efficiency than hobby dynos.
This is the Castle/Neu 1515/1Y - 2200Kv at 16V input
[FORUM] Tout Petit jeu Revopowaaa 1515_16V
I love you
http://www.rc-monster.com/forum/showthread.php?t=16101
Mer 14 Oct 2009 - 19:15
et voila ! Wink
Heureusement que CM est la ...
Mer 14 Oct 2009 - 19:54
Je ne vois rien de plus que les lien précédent...
Les spécifications "poussé" du contro Mamba Monster Mamba..v3 si possible. Wink
Padbol
Padbol
Mer 14 Oct 2009 - 21:01
ESC:
- BEC récepteur débrayable de 6V
- 2 à 6 éléments LiPo
- 7 à 20 éléments NiMH (!)
- Résistance interne de 0.0002 Ohm
- Courant en continu >175A (!)
- Courant en crête >1000A (1 sec) ; >2000A (10 µsec) (!)
- Connection au PC via Castle Link
- Dissipateur anodisé noir aéré par un ventilateur
- Dimensions 5.07cm*4.55cm
MOTEUR :
- Design par Steve Neu
- 2200Kv ou 2600 Kv
- Puissance de 3HP (!) en continu avec un LiPo 6S (2400 watts avec refroidissement), 6HP en crête (+ de 4800 watts en entrée)
- Température d'utilisation sûre: jusqu'à 150°C
- Axe de 5mm
http://www.maximummt.com/forum/brushless-f54/news-specs-du-mamba-monster-max-ca-va-faire-mal-t40331.html
