[NEW] Lipo HardCase/Hard Case Orion 1/8 & 1/16 Empty [NEW] Lipo HardCase/Hard Case Orion 1/8 & 1/16
Jeu 14 Jan 2010 - 15:11
Lipo HardCase Orion
pour 1/8 & 1/16
[NEW] Lipo HardCase/Hard Case Orion 1/8 & 1/16 Orion01
Now you can equip your E-Revo style car (1/10) with LiPo power!
Team Orion developed a special hardcase form to be able to put a
maximum of capacity into the battery compartment. Our battery
with the registered design of the carbon look hardcase enables you
to use the revolutionary Carbon Molecular LiPo technology with up
to 45C of discharge and 3C charge in your Truck.
Key Features:
* Carbon Molecular LiPo technology
* Registered Carbon-look hardcase design
* Up to 7000mAh of capacity
* Up to 45C
* Up to 11.1V of voltage
* 12AWG ultra flexible silicone wires
HOT!
3 different skins are delivered with the Carbon XX battery packs which
enables you to choose your style and replace worn labels!
Perfect shape - perfect fit!
The Team Orion Carbon LiPo high performance LiPo battery capacity is
maximized thanks to it's revolutionary shape which fills up all the available
space in the battery compartment.
>ORI14140 Hi-Output Carbon LiPo 6400 35C 7.4V
>ORI14141 Hi-Output Carbon LiPo 7000 35C 7.4V
>ORI14142 Hi-Output Carbon LiPo 5200 40C 7.4V
>ORI14143 Hi-Output Carbon LiPo 4000 45C 11.1V
>ORI14144 Hi-Output Carbon LiPo 4700 45C 11.1V
[NEW] Lipo HardCase/Hard Case Orion 1/8 & 1/16 Orion03z
Now you can equip your E-Revo style car (1/16) with LiPo power! Team
Orion developed a special hardcase form to be able to put a maximum
of capacity into the battery compartment. Our battery with the registered
design of the carbon look hardcase enables you to use the revolutionary
Carbon Molecular LiPo technology with up to 35C of discharge and 3C charge in your Truck.
Key Features;
* Up to 1950mAh of capacity
* Up to 35C
HOT!
available space in the battery compartment.
>ORI14145 Hi-Output Carbon LiPo 1600 35C 7.4V
>ORI14146 Hi-Output Carbon LiPo 1750 20C 7.4V
>ORI14147 Hi-Output Carbon LiPo 1950 20C 7.4V
>ORI14148 Hi-Output Carbon LiPo 1300 25C 11.1V
>ORI14149 Hi-Output Carbon LiPo 1100 35C 11.1V
[NEW] Lipo HardCase/Hard Case Orion 1/8 & 1/16 Orion02
[NEW] Lipo HardCase/Hard Case Orion 1/8 & 1/16 Userba10
carfnann
carfnann
Nombre de messages : 57
[NEW] Lipo HardCase/Hard Case Orion 1/8 & 1/16 Empty Re: [NEW] Lipo HardCase/Hard Case Orion 1/8 & 1/16
Mer 8 Déc 2010 - 11:05
Je remonte un peu le sujet car j'ai acheté ces LIPO :
3S CARBON XX 4000mAh - 45C (11.1V) ORION
Ca rentre (mais au chausse pied) en suivant les instructions, par contre pour les sortir ensuite... c'est une autre affaire.
Le seul moyen que j'ai trouvé c'est de tirer sur le cable mais je pense que ce n'est pas une bonne solution! Embarassed
Il y a t il des propriétaires de ce type de lipo (ou autre qui sont très juste)?
Comment faites vous pour sortir les accus?
on graisse le compartiment? lol
Cedleonr
Cedleonr
Nombre de messages : 535
Mer 8 Déc 2010 - 11:34
J'ai un Orion 1300 3s pour mon 1/16 meme probleme pour l'enlevé !!!
carfnann
carfnann
Mer 8 Déc 2010 - 11:37
Comment fais tu alors?
tu tires sur le cable?
Cedleonr
Cedleonr
Mer 8 Déc 2010 - 11:43
oui doucement ou sinon je passe un tournevis plat dans l'aeration
Mer 8 Déc 2010 - 11:47
met 2 bouts de rubans ou scotch transparent solide (1 de chaque coté) autour de l'accu et laisse dépasser le surplus coté "porte" du compartiment d'accu.
tu aura juste a tirer sur les languettes de surplus pour le sortir Wink
carfnann
carfnann
Mer 8 Déc 2010 - 11:49
bien vu :merci:
Par moment je me dis que je cherche compliqué, quand on peut faire simple...
Mer 8 Déc 2010 - 11:50
Wink
carfnann
carfnann
Mer 8 Déc 2010 - 11:53
est ce que le fait d'avoir tiré sur le cable a pu endommagé mes lipos qui a provoqué mon grillage d'ESC?
maintenant j'ai un peu peur de rebrancher mes lipos sur un nouveau ESC
Vétéran Modo Jediwaa McGyver
Mer 8 Déc 2010 - 15:25
Le système de ventilation ne sert plus a rien dans ce cas ... !
Kraoc
Kraoc
Nombre de messages : 595
https://j.mp/OlivierLeBris
Mer 8 Déc 2010 - 21:34
Revotom's a écrit:met 2 bouts de rubans ou scotch transparent solide (1 de chaque coté) autour de l'accu et laisse dépasser le surplus coté "porte" du compartiment d'accu.
Hey j'ai fais exactement la même chose lorsque j'ai lutté pour retirer mes lipos la première fois...
Pose de 2 attaches en scotch !
