[New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas Empty [New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas
Jeu 8 Avr 2010 - 2:47
Wheelie bar & Triangle arrière étendu
pour E-Revo 1/16
par Traxxas
[New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas 7184installed7107erevom
[New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas 7184installed7107erevom.th[New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas 7184wheeliebarfor7107er.th
Wheelie Bar
How do you like your wheelies? Whether you like to ride with the front wheels held high for
show-stopping stunt maneuvers or prefer to keep ‘em low for locked-in launches, Traxxas’ new
adjustable wheelie bar for the 1/16 E-Revo puts you in control. The wheelie bar’s unique,
patent-pending design is easy to install for controlled wheelies on demand. Four snap-in
adjustment positions allow you to choose how extreme you want your wheelie action to be.
When it’s time to head off road, the wheelie bar can be easily removed with just two screws.
Wheelie Bar Features:
* Installs easily in minutes
* Patent-pending design, rugged construction
* Four snap-in positions for variable wheelie angles
* Easily removed for off-road running
* Replaceable wheels
* Includes installation hardware and instructions
7184 - Wheelie bar, assembled (fits 1/16 E-Revo and 1/16 E-Revo VXL)
[New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas 7132rerevominilongwheel
[New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas 7132rerevominilongwheel.th[New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas 7132rlongwheelbasearmsi.th[New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas 7132rlongwheelbasearms0.th
Extended Wheelbase Suspension Arms
Add 10mm of wheelbase extension to 1/16 E-Revo in just minutes! Lengthening the wheelbase of your 1/16 E-Revo allows you to accelerate hard through the roughest track sections with increased stability and confidence. The longer wheelbase also helps keep E-Revo planted for holeshot launches and full-on power through the turns. Traxxas makes it easy by building the adjustment into the rear arms. Installation is a snap and the extended rear arms allow the wheelbase to be quickly tuned for various track conditions.
1/16 E-Revo Extended Wheelbase Suspension Arm Features:
* Lengthens wheelbase by 10mm
* Easy to install
* Increased stability over rough track sections
* Planted acceleration
* Genuine Traxxas precision and quality
7132R - Suspension arm set, rear, extended wheelbase (lengthens wheelbase 10mm and includes upper right & left and lower right & left arms)
[New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas Userba10
E-Revow04
Nombre de messages : 237
[New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas Empty Re: [New]Wheelie bar/Triangle arrière étendu 1/16 E-Revo Traxxas
Jeu 8 Avr 2010 - 15:56
Superbe la wheelie bar et pour les triangles arrières j'attends les Rpm'n'go !
Jeu 8 Avr 2010 - 16:13
si ca fait comme pour le 1/10, il y aura pas de triangles RPM déporté
Jeu 8 Avr 2010 - 18:04
Il n'y a jamais eu de triangle Déporté RPM.
Pour du triangle déporté 1/8 costaud, il y a les TeknoRC, mais attention > Fabrication arrêtée, mais apparemment Jejebrl à trouvé une adresse qui en vend toujours. Wink
coyote1311
Nombre de messages : 154
Jeu 8 Avr 2010 - 19:16
génial j'adore ce genre de news!!!
cpar contre sa sert a quoi les triangles déporté?
Nombre de messages : 1155
Jeu 8 Avr 2010 - 19:36
pour que ton e revo soit plus large donc plus stable mais plus ton chassi est large moin il tourne Wink il faut trouver Ton bon compromis
coyote1311
Jeu 8 Avr 2010 - 20:18
ok sa marche merci de l'info Wink
Jeu 8 Avr 2010 - 20:20
e-bline a écrit:pour que ton e revo soit plus large donc plus stable mais plus ton chassi est large moin il tourne Wink il faut trouver Ton bon compromis
large ?? ;S
Jeu 8 Avr 2010 - 20:21
de quoi sait pas vrai se que je dit???
Revoiste Jediwaaa CarbonMan
Nombre de messages : 1457
Jeu 8 Avr 2010 - 20:37
c'est plutôt long que large
ça augmente l'empattement
Smile
coyote1311
Jeu 8 Avr 2010 - 21:30
Ok sa marche merci beaucoup je comprend mieux
et avec un petit centimètre sa change beaucoup?
Ven 9 Avr 2010 - 0:41
Sur 1/8, j'avais remarqué la différence entre le Revo 2.5 et le 3.3 qui est de 3cm...alors un 1cm sur un 1/16 je pense qu'on la ressent bien. Very Happy
castek
castek
Nombre de messages : 227
Dim 26 Sep 2010 - 0:55
J'aimerais savoir vos retours sur la Wheelie bar, vu que j'ai un peu chercher dans le forum et, malheureusement, je n'ai pas trouvé d'avis sur le sujet. Au vu de son prix attractif, j'aurais aimé prendre celle-ci, mais j'aimerais d'abord avoir des retours, ou, si personne ne l'a déjà testée, l'essayer.
Merci,
Castek
Dim 26 Sep 2010 - 3:09
@ castek Merci Wink
Quand tu ne trouves pas quelque chose sur le forum en passant par le mode recherche, tu peux utiliser la méthode PIMAL (je ferais un lien sur pc)
Tu vas sur la page d'accueil de Google et tu saisies : site:www.revopowaaa.com (suivi de se que tu recherche, ici) Wheelie bar e-revo 1/16 (ou) Wheelie bar e-revo vxl
Avec cette méthode de retrouve des mots qui sont contenus dans les titres des sujets, mais également dans les messages du forum.
Si quelqu'un en parler tu devrais le trouver Very Happy
Je veux juste te dire que dans la vie en général, un peu de politesse et un petit sourire t'ouvriront toujours persque toutes les portes Wink Je dis presque parce que tu pourras sortir toutes les formules de politesse avec ton plus beau sourire à ton banquier qu'il ne t'ouvrira pas son coffre nan :mdr1:
castek
castek
Dim 26 Sep 2010 - 13:48
:lol2: :mortderire:
Mais en fait je pense que je ne prendrai pas cette Wheelie bar là car j'ai prévu de m'acheter prochainement le Bumper T-Bone.
D'après sa forme, elle ne passera jamais, à part si elle fusionne avec le Bumper, ce qui m'étonnerait fortement :lol2:
D'après [/b]patOff[b], la partie arrière du Bumper sert aussi de Wheelie "bar".
castek
Dim 26 Sep 2010 - 14:53
Je mettrais aussi un Bumper T-Bone quand je me deciderais à équiper le VXL Very Happy
Ray-mt
Ray-mt
Nombre de messages : 669
Dim 26 Sep 2010 - 16:23
alors si tu prend les par choc T-Bone tu peux auusi prendre la wheelie bar T-Bone
castek
castek
Dim 26 Sep 2010 - 19:44
Merci je ne l'avais pas vue.
Alors elle se visse sur le Bumper arrière c'est ça?
Dim 26 Sep 2010 - 19:57
raymy a écrit:alors si tu prend les par choc T-Bone tu peux aussi prendre la wheelie bar T-Bone
Je suis pas trop wheeling nan D'ailleurs j'ai acheté un diff central exprès, mais pour le moment en 2S, je n'en ai pas l'utilité Very Happy
