[NEW] Radio DX3R Pro par Spektrum
+3
Nitrous
7 participants
Mer 11 Aoû 2010 - 11:14
Voici la nouvelle DX3R Pro, vu sur le stand de Mike Truhe
DX3R Pro
par Spektrum...of course !
DX3R Pro
Re: [NEW] Radio DX3R Pro par Spektrum
Mar 24 Aoû 2010 - 21:01
d'autre info sur cette "nouvelle" radio?
Mar 24 Aoû 2010 - 23:05
Nop rien pour l'isntant, c'était une photo volée.
Mar 24 Aoû 2010 - 23:15
dommage. en tout cas, up grade rc est deja sur le coups j'ai l'impression
Mer 13 Oct 2010 - 9:19
Jeu 13 Jan 2011 - 12:31
La DX3R Pro ne devrait pas tarder.
Horizon Hobbies (Alias Spektrum / Team Losi) l'a mis en Backorder.
Voici un complément d'information :
DX3R PRO 3CH DSM2 Racing System
Key Features
* 50-model memory
* Selectable frame rate (5.5, 11 and 16ms)
* Backlight LCD
* Drop down steering wheel and other improved ergonomics
* Servo speed
* Real-time Integrated Telemetry (rpm/speed, temp),
* Right- and left-hand compatible
* Vibrating and tone alerts
* DSM2 2.4GHz second-generation technology offers the fastest possible response rate
* Automatic Braking System (ABS) and Traction Control
* One-touch, easy-to-use programming
* Programmable Steering Rate override
* On-the-fly throttle and steering exponential adjustments
* All switches can be programmed to operate in either direction
* Four programmable timers: Up, Down, Integrated and Rolling Lap
* 128 x 64 high-resolution dot-matrix screen
* Graphically supported Travel Adjust and Expo curves
* Two programmable mixes
* Adjustable trim steps
* Digital servo monitor displays graphic and digital servo positions
* Calibration screen allows recalibration of steering and throttle positions for the ultimate in accuracy
Overview
High-End Software. Drive Like an Expert.
The DX3R PRO is packed with first-class software, including servo speed adjustment, ABS, traction control and 50-model memory. It’s marine-compatible and comes with four timer functions—including a rolling lap timer. When it's time for software updates, the DX3R PRO's SD card functionality makes it simple.*
*SD card not included.
Advanced Ergonomics. Designed to Fit the Way You Drive.
The Spektrum DX3R PRO is an advanced-level surface transmitter system. So naturally it comes with advanced-level ergonomics. Everything about the DX3R PRO is made to fit the way you drive, from the optional dropdown steering wheel to the easy-to-read backlit screen to the large grip. Right- and left-hand settings are also included.
Built-In Telemetry: Check temp, speed and voltage in real-time.
Drive smarter with the DX3R PRO. You can monitor your engine or motor temperature, keep tabs on your engine rpm's or vehicle speed, track battery voltage, and check your lap time. The DX3R PRO and integrated telemetry let you do all this right from the large LCD readout. Transmitter also includes vibrating and audible alerts.
Spektrum TM SR3100 DSM2TM 3-Channel Receiver
The SR3100 is specifically designed to take full advantage of the DX3R PRO’s advanced DSM2 spread spectrum. This technology provides glitch-free performance and the fastest response of any spread spectrum receiver. It’s all yours in a package that can easily fit on a 1/18-scale chassis.
Lien Spektrum
Key Features
* 50-model memory
* Backlight LCD
* Servo speed
Overview
Lien Spektrum
Jeu 13 Jan 2011 - 12:52
Elle a l'air pas mal.
Nombre de messages : 822
Ven 14 Jan 2011 - 23:27
Elle a vraiment bien, niveau ergonomie de la télécommande est puissance de l’émetteur, grand écran, même si il est préférable de regarder la voiture qui roule est fais des sauts au lieu de l’écran si non elle risque de se retrouver dans un mur
Elle me plairait bien
Dommage que noël est déjà passé
Mer 16 Mar 2011 - 17:44
la premiere spektrum pro est en france
http://offroadsaillanais.forumpersos.com/t817-presentation-de-la-spektrum-dx3r-pro
- vinxoRevoiste Padawaaa super motivé
Nombre de messages : 133
Mer 16 Mar 2011 - 18:39
ca ne serait pas millenium ton revendeur?nitrous a écrit:y'en a 50 chez mon revendeur a nantes
Mer 16 Mar 2011 - 18:54
oui. a mon avis, elles doivent bien se vendre ces radios.
- bomeRevoiste Padawaaa qui powaaaAA
Nombre de messages : 268
Mer 16 Mar 2011 - 19:59
Grave, quand j'y suis allez, il finissait de tout ranger.
Elle est hors budjet pour moi :s
Mer 16 Mar 2011 - 21:51
Mon vendeur en a aussi.
