[NEW] Porte-Fusée/Portes-Fusées RPM pour 1/16
+16
Mini-e-revo
Revers-76-
toitoinou
Legnathead
Quadman
vini der el diablo
St33v3
jploi
bouda
20 participants
Page 1 sur 3 • 1, 2, 3
Lun 13 Sep 2010 - 23:35
Portes-Fusées pour 1/16
par RPM
1/16th Scale Axle Carriers for the Traxxas mini E-Revo and mini Slash
#73162 Black Axle Carriers
UPC #672415731628
#73165 Blue Axle Carriers
UPC #672415731659
#73169 Red Axle Carriers
UPC #672415731697
There is very little that can be as frustrating on an R/C vehicle as slop in the suspension system. In the case of the 1/16th scale mini E-Revo and mini Slash, there is absolutely no slop adjustment for the suspension pivot balls. Once the axle carriers begin to wear at those balls, the camber, toe and caster angles don’t stay true, causing the vehicle to wander, making it very difficult to control.
That is where RPM steps in. Our new 1/16th scale mini E-Revo and mini Slash Axle Carriers have a unique pivot ball retention system that locks the pivot ball in place, yet still allows for adjustment due to wear. Our system is based on a cap design, held in place with a pair of small screws. Simply slip the caps in place, tighten the flathead screws until the free play of the pivot ball is eliminated and you’re ready to go!
RPM Axle Carriers have been completely redesigned for added durability and crash-survivability. RPM engineers found that the stock pivot ball opening could be reduced in size to help support the pivot ball better, meaning a significantly lower chance of pulling the ball through the hole. The redesigned overall shape and superior materials that go into our version make them the best alternative at the lowest price available! And to top it off, RPM axle carriers are marginally lighter than the stock versions!
RPM Axle Carriers for the 1/16th scale Traxxas mini E-Revo and mini Slash are molded in three color options – black, blue and red, perfectly matching our already well-known and respected set of mini E-Revo A-arms. Designed, manufactured and molded right here in our facility in sunny Southern California! At RPM, we bring pride to the expression “Made in the USA”!
Lien RPM Racing
par RPM
UPC #672415731628
UPC #672415731659
UPC #672415731697
Lien RPM Racing
- boudaRevoiste Padawaaa super motivé
Nombre de messages : 50
nouvelle fusée rpm ?
Dim 19 Sep 2010 - 17:12
y'a t'il quelqu'un qui a essayer les nouvelles fusées de RPM.
je cherche aussi des photos de mini qui ont des pneus badland comme pneu.
Re: [NEW] Porte-Fusée/Portes-Fusées RPM pour 1/16
Dim 19 Sep 2010 - 17:17
Les produit RPM ont très bonne réputation... je ne serais pas inquiet.
Je ne connais personne mais tu pourrais être notre "testeur"
fusée rpm
Dim 19 Sep 2010 - 20:50
[quote="patoff"]Les produit RPM ont très bonne réputation... je ne serais pas inquiet.
bon enfin ,,,,ca va ètre a mon tour de tester des upgrades.
c'est fait , je l'ai est commander, je vais les recevoirs vendredi ou samedi matin.
je vous reviens la dessus des que je l'ai est.
Nombre de messages : 398
Dim 19 Sep 2010 - 21:25
oui RPM a bonne reputation mais ce que j aime pas avec ces fusées c'est que les boules sont bloqués par les petits embouts plastiques des fusées traxxas d origine. Enfin c est ce que j ai cru comprendre.
- St33v3Revoiste Padawaaa qui powaaaAA
- Nombre de messages : 237
Dim 19 Sep 2010 - 21:28
C'est quoi le terme anglais pour les fusées?
Bouda, tu peux me donner un lien en MP pour me montrer c'est quoi cette pièce là?
Lun 20 Sep 2010 - 0:01
Sujet fusionnés.
Fusée en anglais > axle Carrier
Lun 20 Sep 2010 - 13:58
je sais pas si elles sont bien, mais en tout cas
quesqu'elles sont moches
Mer 22 Sep 2010 - 0:31
Comparé au HT, oui c'est sûr c'est autre chose.
So qui les teste !?
So qui les teste !?
Nombre de messages : 1561
Mer 13 Oct 2010 - 0:35
@ bouda :
Les RPM, elles sont bien ou pas alors
@jploi:
non, les "embouts" qui bloquent les boules sont fournis avec
ils sont visibles sur les photos des rouges et noires, déjà vissés/installés sur les bleues,
Donc, pas besoin des ceux d'origine !
@jploi:
axle carrier
Mer 13 Oct 2010 - 2:42
je les attends encore.
Nick le proprietaire du hobbyshop ou je fait affaire,
m'as dit qu'il a appeller sont fournisseur pour savoir la raison de cette attente.
on attent la reponse.
(j'ai hate que ca débloque)
Mer 13 Oct 2010 - 15:33
Ok, pas top tout ça ! (ça fait environ 3 semaines que tu les a commandées,non ?)
-tient nous au parf car j'aimerais bien savoir si le système de blocage des boules est fiable,
sans trop de jeu et rattrapable au-cas-où car je fait faire un régime à mon mini et elles me branchent bien
- Nombre de messages : 554
Mer 13 Oct 2010 - 16:06
justement je suis tombé dessus, je me demandais si a valais le coup. Je crois que je vais tenter, elle sont sur thetoyz.
Mer 13 Oct 2010 - 16:31
Mer 13 Oct 2010 - 17:00
je connaissais pas ce shop, il livre rapidement ? les fdps sont correct ?
Mer 13 Oct 2010 - 17:15
oui, méme pas 1 semaine
Livraisons très raisonnables (env. 8/10 jours pour les "lettres-max" =petites pièces)
et FDP aussi = 3.37$ pour les 4 RPM (First Class) ,env 1$ de + pour pièces supplémentaires
et ils sont sur la côte Ouest !
fusée rpm
Sam 30 Oct 2010 - 5:13
ca fait 2 semaines que j'ai installer les nouvelles fusées rpm .
je les aimes biens
bien mouler,facile a installer,enleve tout le "lousse" des triangles.
mes 2 mini en sont maintenant equiper. (revo et slash )
pour l'essai a long terme,bien le temp nous le diras.
je les aimes biens
Sam 30 Oct 2010 - 12:30
Y a pas de jeu avec les boules de fusées a la longue?
les goupilles se serrent comment sur les boules? par vis?
Dim 7 Nov 2010 - 20:20
J'ai commandé les mienes aussi,
J'attends une grosse livraison de chez thetoyz =)
Dim 7 Nov 2010 - 20:42
j aimerais bien avoir un retour. est ce qu il y a du jeu avec les boules apres plusieurs runs ?
gpm
Dim 7 Nov 2010 - 23:21
désolé pour le delai.
ca fait 5 semaine qu'il sont installer sur mon mini e-revo.
je roule environ 3 a 4 fois par semaine pour un durer d'environ 2 hrs a chaque fois.
(roule dans toute sortes de terrains.)
jusqu'a maintenant tout va bien, pas de jeu encore.
et oui on ce sert des vis pour enlever le jeu.
je roule mon mini slash (on road ) avec ca aussi.
moi je l'aime bien.
moi je l'aime bien.
Mar 9 Nov 2010 - 16:08
Cool ! c'est une bonne chose !
Merc pour ton retour =)
Mer 24 Nov 2010 - 9:31
Grosse commande recu ce jour,
Les fusées sont dedans ! hate de les monter. Vivement ce soir !
edit : Ca y est, j'ai monté les 4 fusées, je vous ai fait quelques photos j'éditerais le post pour les posters.
Attention par contre, les petites visses pour fixer les pivotballs ne sont pas au pas des clefs traxxas, mais bien plus petites. Prévoir une petite clef ! tres petite !
edit2: hop, voici les photos des fusées, désolé pour la qualitée un peut sombre ^^"
Jeu 25 Nov 2010 - 13:38
Bon ben pour ma part... déja un retour... "négatif"
Pourquoi entre guillement ? parce qu'elle n'a pas cassée. Je me suis pris une tole ondulée de coté, et les pivots balls sont carément sortie de la fusée (les deux)
Pourtant j'y allais pas fort.. alors j'imagine quand je vais recommencer à envoyer avec le mini =S
- [New]Portes Fusées Arrière pour X-Maxx par RPM /Oversized Rear Axle Carriers 81732
- [NEW]Etrier - Porte fusée - Fusée 1/10 2WD FastLaneMachine FLM27600 Caster Blocks-Steering Knuckle
- [NEW] Porte-fusée Alu/Carbon pour 1/8 par Hot Racing
- [NEW]Porte Fusée avant/Arrière/Etrier Hot Racin pour X-Maxx
- [NEW]Porte-fusée arrière & Cardan pour 1/10 2WD FastLaneMachine FLM26700 Rear Hub Carrier & CVD
