>>Old New Chassis True Dynamic V1 Empty >>Old New Chassis True Dynamic V1
Sam 2 Fév 2008 - 16:05
>>Old New<<
Voici La V2 du Chassis 3.3
by
>>Old New Chassis True Dynamic V1 Logotruedynamicqm7
>>Old New Chassis True Dynamic V1 01lw9
>>Old New Chassis True Dynamic V1 02fv0
>>Old New Chassis True Dynamic V1 03ue8
TrueDynamic / >>Old New Chassis True Dynamic V1 Carbon6vd7
Spécification :
There is a New Carbon Fiber chassis for the Revo 3.3 with a new design. It has features like a Lowered Engine mount and Fuel Tank mount for lower center of gravity, Gussets are added, to strengthen originally weaker areas on the "other" carbon Fiber chassis. Eyelets are rounded off to prevent cracking/breakage, as well as, more carbon fiber in the engine mount area. This chassis is Part #1 of multi-part synergistic system. The design and fiber layup have been optimized for strength and rigidity, and uses high pressure molding, programmed cure temperature management technology to produce the chassis.
We are estimating the availability of the chassis to be around December 1st 2006. (On attends toujours ! Wink)
Photos supplémentaires.
>>Old New Chassis True Dynamic V1 Ap1010081sp2
Photos de différent moulage pour l'épaisseur du chassis, d'ailleurs on peut comparer avec celui d'origine.
>>Old New Chassis True Dynamic V1 Adsc01776uz1.th
>>Old New Chassis True Dynamic V1 Adsc01762lj6.th>>Old New Chassis True Dynamic V1 Adsc01768ra4.th
>>Old New Chassis True Dynamic V1 Adsc01763mg2.th>>Old New Chassis True Dynamic V1 Adsc01764px8.th
>>Old New Chassis True Dynamic V1 Userba10
>>Old New Chassis True Dynamic V1 Empty Re: >>Old New Chassis True Dynamic V1
Sam 2 Fév 2008 - 16:07
Par contre pas de réponses du gars pour avoir plus d'infos... Neutral
Aricospeed
Aricospeed
Nombre de messages : 1267
Sam 2 Fév 2008 - 16:10
sa a l'air tres costaud ! j'aime bien les fusées arr a deport Smile
le nouveau chassis est celui du centre dans les photos ?
Sam 2 Fév 2008 - 16:16
aricospeed a écrit:sa a l'air tres costaud ! j'aime bien les fusées arr a deport Smile
Yes les Fusées spécifique de chez Qoncepts.
Pour les photo...j'espères ! Je n'ai pas plus d'infos.
Vétéran Modo Jediwaa McGyver
Sam 2 Fév 2008 - 16:20
les fusées ce sont des quoncepts et les photos sont toutes des photos du v2
Kake007
Kake007
Nombre de messages : 643
Sam 2 Fév 2008 - 16:37
cool...petite question le filtre qu'il y a sur le RB vous savez ou on peut le trouver??? car il a l'air énorme 👅 ... Wink
Sam 2 Fév 2008 - 16:41
chez fiorini il en font je crois
Sam 2 Fév 2008 - 16:47
C'est un Fiorini, existe en Bleu ou Noir.
Sam 2 Fév 2008 - 17:34
bien joué je trouvais pas de lien
Kake007
Kake007
Sam 2 Fév 2008 - 18:07
merci ^^ mais c'est bete car avec la boite de vitesse il faut un autre coude ou plutot tuyau! Wink
Sam 2 Fév 2008 - 18:08
un raccord d'échappement va très bien (diametre 1/10 °)
Sam 2 Fév 2008 - 19:50
EDIT. Spécifications
eric 94
eric 94
Nombre de messages : 139
Dim 3 Fév 2008 - 8:45
ce chassis est magnifique mais est t'il mieux que celui d'origine car le vantage avait des probleme de chauffe avec le carbon Rolling Eyes
Mais si il s'avere mieu que celui d'origine je pense que sa sera mon prochain achat I love you
Florianar
Florianar
Nombre de messages : 743
Lun 4 Fév 2008 - 23:00
le carbone creera toujours des problemes de chauffe, c'est un composite, mais certains moulages permette une conductivité de la chaleur...
en tout cas, je dois dire que ce chassis est superbe!!! il donne envie de l'acheter!
