>> New Toute une gamme CNC by St Racing Empty >> New Toute une gamme CNC by St Racing
Sam 1 Mar 2008 - 4:14
Toute une gamme CNC by St Racing !
Sympatoch la famille...
>> New Toute une gamme CNC by St Racing Singlearmsee8
>> New Toute une gamme CNC by St Racing Servosaver0yr5
Part #
STP6037B/S Aluminum Single Servo Saver Arm for Traxxas Revo 3.3
ST5344B/S Aluminum Heavy Duty Complete Steering Servo Saver Set for Traxxas Revo 3.3
Machined from high quality aluminum, our Complete Steering Servo Saver set adds great look, improves durability and reduces flex over the stock plastic unit. Featuring machined delrin inserts to accommodate the steering bell crank bearings for a solid tight fit and smooth operation. Direct bolt on with no modification necessary. Available in royal blue or racing silver. Also available is our single servo saver arm (STP6037B/S) for those that use a single high-torque servo on the Traxxas Revo 3.3. Works with stock plastic steering servo saver or with our ST5344B/S Aluminum Steering servo saver set.
MSRP:
STP6037B/S: $15.99
ST5344B/S: $35.99
>> New Toute une gamme CNC by St Racing Bracketmb7
Part #
ST5344AB/S CNC Machined Aluminum Steering Servo Saver Assembly Bracket
>> New Toute une gamme CNC by St Racing Frontrockerjm6
>> New Toute une gamme CNC by St Racing Rearrockerkp9
Part #
ST5358FB/S CNC Machined Aluminum Precision 90T Adjustable Front Rocker Arms for Traxxas Revo 3.3
ST5358RB/S CNC Machined Aluminum Precision 90T Adjustable Rear Rocker Arms for Traxxas Revo 3.3
Precision CNC Machined from high quality aluminum, our precision 90T Front and Rear Rocker arms for your Traxxas Revo 3.3 features weight reduction cut outs and extra push-rod mounting hole for adjusting progressive/linear suspension feel. Solid in design and CNC machining. Direct bolt on with no modifications necessary. Available in royal blue or racing silver anodizing. Sold in pairs (two rocker arms per package)
MSRP:
ST5358FB/S: $22.99
ST5358RB/S: $22.99
>> New Toute une gamme CNC by St Racing Knuckleswj2
Part #
ST5334B/S Precision Machined Aluminum Steering Knuckles with oversized 6x15mm bearings (included) for Traxxas Revo 3.3/T-Maxx 3.3/new E-Maxx
Precision CNC Machined from high quality aluminum, our steering knuckles for the Traxxas Revo features all the details of the stock plastic pieces faithfully CNC machined, and with improved durability with the larger 6x15mm outer bearing (included). Also compatible with the new E-Maxx and the T-Maxx 3.3. We believe this is arguably one of the best CNC machined, high quality steering knuckle on the market for your Traxxas monster trucks. Available in royal blue or racing silver anodizing.
MSRP: $39.99
>> New Toute une gamme CNC by St Racing 17mmhexqr8
Part #
STST4954-17B/S 17mm Truggy Wheel Hex Adapter conversion kit for Traxxas Revo 3.3/T-Maxx 3.3/new E-Maxx
17mm hex adapter have now become the standard in 1/8th truggy racing scene, with the best combination in strength and weight between the stock 14mm hex and the overweight 23mm hex adapters. Our 17mm hex adapter conversion kit allows Traxxas Revo 3.3, T-Maxx 3.3 and the new E-Maxx owners to bolt on the latest truggy rims and tires combinations, like the new Proline LPR tires and rims. Featuring captured drive pin design and light weight CNC machined wheel nut, this is a must have for all serious racers of Traxxas monster trucks. Available in royal blue or racing silver anodizing. Sold in complete set of 4 (enough for one truck)
MSRP: $29.99
>> New Toute une gamme CNC by St Racing Shocktowersto9
Part#
ST5317FB/S CNC Machined Aluminum Front Shock Tower for Traxxas Revo 3.3
ST5317RB/S CNC Machined Aluminum Rear Shock Tower for Traxxas Revo 3.3
CNC Machined from high quality aluminum, our front and rear shock tower for Traxxas Revo 3.3 improves the strength and reduces the flex in the upper shock mount area over the stock plastic pieces and also adds great factory look to your Traxxas Revo 3.3. Direct bolt on with no modifications necessary. Available in royal blue or racing silver anodizing. Sold in single piece.
MSRP:
ST5317FB/S: $17.99
ST5317RB/S: $17.99
>> New Toute une gamme CNC by St Racing Servoguardsuu0
Part #
ST5315B/S CNC Machined Heavy Duty Aluminum Steering Servo Guards for Traxxas Revo 3.3
CNC Machined from high quality aluminum material, our Steering Servo Guards for Traxxas Revo 3.3 offers greater protection over the steering servos and also with reduced material on the inside of the guards for more steering throw. Adds great factory look to your Traxxas Revo 3.3 especially when combined with our machined aluminum skid plate sets. Direct bolt on with no modifications necessary. Available in royal blue or racing silver anodizing.
MSRP: $24.99
>> New Toute une gamme CNC by St Racing Frontmidskidlrlm3
Part #
ST5337FMB/S Aluminum Heavy Duty Front + Mid Skid plate for Traxxas Revo 3.3
Machined from high quality aluminum, our Front + Mid skid plate combines the stock two piece Front and Middle skid plate into one durable unit. Heavy duty in construction and design, ready to take on the roughest terrain. Direct bolt on, no modification necessary, and adds awesome factory look to your Traxxas Revo 3.3. Available in royal blue or racing silver.
MSRP: $39.99
>> New Toute une gamme CNC by St Racing Centerskidlrmv6
Part #
5316B/S Aluminum Center Transmission Cover/Skid Plate for Traxxas Revo 3.3
Made from high quality aluminum and CNC machined for weight reduction, our Center Transmission Cover/Skid plate protects the center transmission while the extended cover piece covers and protects the center rear driveshaft. Available in royal blue or racing silver.
MSRP: $19.99
>> New Toute une gamme CNC by St Racing Rearskidlrfj1
Part #
5337RB/S Aluminum Heavy Duty Rear Skid Plate for Traxxas Revo 3.3
Machined from high quality aluminum, our heavy duty rear skid plate is ready to take on the toughest bashing and rough landings. Solid in construction and machined for weight reduction. Combine with our other high quality skid plate for the ultimate protection for the underside of your Traxxas Revo 3.3. Available in royal blue or racing silver.
MSRP: $24.99
>> New Toute une gamme CNC by St Racing Rearbumpersw9
Part #
ST5335B/S Precision Machined Super Heavy Duty Aluminum Front Bumper for Traxxas Revo 3.3
Precision CNC Machined from high quality aluminum, it doesn’t get any stronger than our Super Heavy Duty Aluminum front bumper for your Traxxas Revo 3.3. Solid in design and CNC machining. Featuring a 2 piece design of a wide front bumper and one piece bumper support/mount. One look and you know this bumper means business and it is ready to tackle the roughest tumbles and rumbles any bashers can dish out. Available in royal blue or racing silver anodizing.
MSRP: $28.99
>> New Toute une gamme CNC by St Racing Frontbumperqz4
Part #
ST5336B/S Precision Machined Super Heavy Duty Aluminum Rear Bumper for Traxxas Revo 3.3
Much like our front bumper, our Super Heavy Duty Aluminum rear bumper is ready for the toughest terrain out there. Precision CNC Machined from high quality aluminum, featuring a 2 piece design of a wide front bumper and one piece bumper support/mount. Available in royal blue or racing silver anodizing.
Combine with our front bumper for the ultimate protection front to rear on your Traxxas Revo 3.3
MSRP: $28.99
>> New Toute une gamme CNC by St Racing Userba10
