[New] Chargeur Duo xMove 2.0Evo 2x 200W par Ansmann Racing
Mer 16 Fév 2011 - 9:47
2x 200W
par Ansmann Racing
Elegant, attractive design paired with touch controls and a piano finish are just a few of the visual highlights this charger has to offer.
The white two-line display shows users all the relevant data and defines parameters before, during and after charges. This dual device allows
you to charge two packs with up to six LiPo/Li-Fe or 18 NiMh/NiCd cells simultaneously, all with a charge current of 0.1 to 10A per output.
Hot keys make it easy to switch between the two charge outputs. The corresponding balancers work with an equalising current of 300mA.
The integrated model memory and USB interface combine the advantage of complex battery management systems with the simplest possible approach.
The designers focused on quiet, effective fans to create a device that is as universal as possible, making the xMove 2.0 Evo ideal for every type of use:
whether in the office, at home or in the workshop. Professional airplane, helicopter, boat and car modelling demands high-performance equipment
and the xMove 2.0 Evo is perfect for these applications.
Input voltage 11-18V DC
Performance Max. 200W x 2 for charging; max. 25W x 2 for discharging
Charging current 0.1 to 10.0A per output
Discharging current 0.1 to 5.0A
Battery types 1-18 NiCd/NiMH cells ** 1-6 Li-Ion/Li-Po/Li-Fe cells
Lead acid battery voltage 2 to 24V
Weight 930g
Dimensions 195 x 175 x 80mm
Lien Ansmann Racing
2x 200W
par Ansmann Racing
Weight 930g
Lien Ansmann Racing
