[New] Moteur Sensored BigBlock 540 pour 1/16 par Hobby King
Jeu 24 Mar 2011 - 17:55
The HobbyKing X-Car Sensored Brushless Motors offer outstanding performance at an incredible price.
Featuring a quality anodized CNC finish these motors look as good as they go! The adjustable timing
allows for fine tuning the performance of your motor while the sensor ensures smooth startups and
acceleration. The HobbyKing X-Car Brushless motors make a great upgrade for 1/10th Short Course
Trucks, Buggies or Touring cars.
HobbyKing X-Car Sensored Brushless Motor 13.5 Turn/2600kv
Specs:
Can Size: 540
Turns: 13.5
RPM/v: 2600kv
Sensored: Yes (Standard 6 pin harness)
Pole: 2
Max voltage: 7.4~14.8v (2S/4S)
Max Current: 19A
Max Watts: 500w
Resistance: 0.0361ohm
No Load Current: 0.6Amp
Shaft Size: 3.175mm
Weight: 167g
HobbyKing X-Car Sensored Brushless Motor 10.5 Turn/3200kv
Specs:
Can Size: 540
Turns: 10.5
RPM/v: 3200kv
Pole: 2
Max voltage: 7.4~11.1v (2S/3S)
Max Current: 24A
Resistance: 0.0213ohm
No Load Current: 0.8Amp
Shaft Size: 3.175mm
Weight: 168
HobbyKing X-Car Sensored Brushless Motor 8.5 Turn/4000kv
Specs:
Can Size: 540
Turns: 8.5
RPM/v: 4000kv
Pole: 2
Max Current: 32A
Max Watts: 500w
Resistance: 0.0142ohm
No Load Current: 1.3Amp
Shaft Size: 3.175mm
Weight: 163g
HobbyKing X-Car Sensored Brushless Motor 5.5 Turn/6000kv
Specs:
Can Size: 540
Turns: 5.5
RPM/v:6000kv
Pole: 2
Max voltage: 7.4 (2S)
Max Current: 48A
Max Watts: 500w
Resistance: 0.0064ohm
No Load Current: 3.5Amp
Shaft Size: 3.175mm
Weight: 160g
Specs:
Can Size: 540
Turns: 13.5
RPM/v: 2600kv
Pole: 2
Max Current: 19A
Max Watts: 500w
Shaft Size: 3.175mm
Weight: 167g
Specs:
Can Size: 540
Turns: 10.5
RPM/v: 3200kv
Pole: 2
Max Current: 24A
Shaft Size: 3.175mm
Weight: 168
Specs:
Can Size: 540
Turns: 8.5
RPM/v: 4000kv
Pole: 2
Max Current: 32A
Max Watts: 500w
Shaft Size: 3.175mm
Weight: 163g
Specs:
Can Size: 540
Turns: 5.5
RPM/v:6000kv
Pole: 2
Max Current: 48A
Max Watts: 500w
Shaft Size: 3.175mm
Weight: 160g
- djimbowRevoiste Padawaaa super motivé
Nombre de messages : 145
Re: [New] Moteur Sensored BigBlock 540 pour 1/16 par Hobby King
Ven 25 Mar 2011 - 12:31
Je m'y intéresse car je suis en cours de négociations pour reprendre un 1/16°
Je suppose que le meilleur compromis est le 4000 kv ?
Enfin je pense pas mais j'ai peut être tord.
Autant de puissance que le 6000 kv au final par rapport au voltage, simplement en 3S ça consomme moins qu'en 2S ? dîtes moi si je me trompe.
Ven 25 Mar 2011 - 13:36
500Wmax, c'est moins puissant que le Velineon380(550Wmax)
Le 2600Kv pourrait être intéressant pour un mini Summit crawler comme celui de Quadman.
Je ne vois pas l'intérêt sur un MERV
- [NEW] MonsterKingz King-Hobby Aluminum Motor Mount Traxxas MAXX - Support moteur Big Bloc pour MAXX
- [NEW]Moteur Sensored 4274 G3 2250KV par HobbyWing - Hobby Wing Motor 30405001
- [NEW]Cardan Central CVD pour Rustler 4X4 VXL par MonsterKingz / King Hobby - Center Drive Shaft
- Support moteur BigBlock 540 550 pour 1/16 par Hot Racing
- Support Moteur/Plaque BigBlock/Big Block pour 1/16
