Nombre de messages : 28136
>> New Servo Hitec HS-7985MG Coreless Digital. Empty >> New Servo Hitec HS-7985MG Coreless Digital.
Mar 22 Avr 2008 - 1:51
Nouveau Servo Hitec Coreless Digital.
HS-7985MG
>> New Servo Hitec HS-7985MG Coreless Digital. Hitech10
The new HS-7985MG High Torque Digital Servo has the added benefit
of our new G2 second generation programmable digital circuit.
This circuit has twice the resolution of our original circuit while adding
programmable overload protection. The technology doesn’t stop
at the circuit board, with a high performance coreless motor,
dual ball bearing suported output shaft, bushing supported
gear shafts and ourHeavy Duty Metal gear train the HS-7985MG was
designed to withstand the stress of larger high performance aircraft
and on/off road vehicles.
Detailed Specifications
Motor Type:Coreless
Bearing Type: Dual Ball Bearing
Speed: 0.16 / 0.13 sec @ 60 deg.
English
Metric
Torque: 144 / 172 oz.in (4.8v/6v)10.4 / 12.4 kg.cm (4.8v/6v)
Size: 1.57" x 0.78" x 1.45" 40.00 x 20.00 x 37.00mm
Weight:2.18oz 62.00g
Detailed Feature Descriptions
# G2 Digital Circuit
# Coreless Motor
# Dual Ball Bearing Supported Output Shaft
# Metal Gear Train (MK first gear)
Programable Features Include:
* Dead Band Width
* Direction of Rotation
* Speed of Rotation (slower)
* End Points
* Neutral Points
* Fail Safe On/Off
* Fail Safe Point
* Resolution* (default is high resolution)
* Overload Protection* (default is off)
*these features are only programable with the HFP-20 field programmer
>> New Servo Hitec HS-7985MG Coreless Digital. Userba10
Sehnsucht
Sehnsucht
Nombre de messages : 485
>> New Servo Hitec HS-7985MG Coreless Digital. Empty Re: >> New Servo Hitec HS-7985MG Coreless Digital.
Mar 22 Avr 2008 - 8:37
Coute combien cette merveille?
Mer 23 Avr 2008 - 12:56
Oucoune idi... pirat
Pas d'infos supplémentaire.
Mais pour le frein/Gaz...Il manquerait un poil de vitesse...
