[New]Servos Hitec HS-7980TH/HS-M7990TH Coreless/Magnetic Empty [New]Servos Hitec HS-7980TH/HS-M7990TH Coreless/Magnetic
Mer 21 Avr 2010 - 22:01
Servos HS-7980TH Coreless Pignon Titanium
& HS-M7990TH Magnetic Encoder Pignon Titanium
par Hitec
[New]Servos Hitec HS-7980TH/HS-M7990TH Coreless/Magnetic Attach13
[New]Servos Hitec HS-7980TH/HS-M7990TH Coreless/Magnetic Attach15
HS-M7990TH Mega Torque HV Magnetic Encoder Servo
Hitec's most technologically advanced servo, the "Monster Torque"
HS-M7990TH features an ultra precise high resolution magnetic encoder
instead of a conventional mechanical potentiometer. Designed to operate
on a two cell LiPo Pack the HS-M7990TH features our newest high resolution
"G2.5" 12 bit generation programmable digital circuit and our indestructible
Titanium gears. Other features of the HS-M7990TH include a 7.4V optimized
coreless motor, integrated heat sink case, and a top case with two hardened
steel gear pins supported by brass axialbushings.
Features
* High Resolution Magnetic Digital Ecoder
* G2.5 12 bit Digital Brogrammable Circuit
* Titanium Gear Train (MK first gear)
* Ultra Performance Coreless Motor
* Integrated Heatsink Case
* ( 8 ) O-Rings for Water/Dust/Fuel protection
* Dual Ball Bearing Supported Output Shaft
* 10% larger than a HS-7955TG
Programmable Features Include:
- Dead Band Width
- Direction of Rotation
- Speed of Rotation (slower)
- End Points
- Neutral Points
- Fail Safe On/Off
- Fail Safe Point
- Resolution* (default is high resolution)
- Overload Protection* (default is off)
*These features are only programmable with the HFP-20, HPP-20 or HPP-21 programmers.
Arrow Lien Hitec
HS-7980TH Mega Torque HV Coreless Titanium Gear Servo
Hitec's strongest servo period, the "Monster Torque" HS-7980TH is designed
to operate on a two cell LiPo Pack. Featuring our newest high resolution
Titanium gears, The HS-7980TH has the performance and durability you've
come to expect from a Hitec servo. Other features in the HS-7980TH include
a 7.4V optimized coreless motor, integrated heat sink case, and a top case with
two hardened steel gear pins supported by axial brass bushing.
Applications for the HS-7980TH include high performance Giant Scale Aircraft,
Truggies and Buggies, Fast Power boats, the largest aircraft, monster trucks or
anywhere else you can use 600+ inch ounces of torque.
Features
* G2.5 12 bit Digital Programmable Circuit
- Dead Band Width
- End Points
- Neutral Points
- Fail Safe On/Off
- Fail Safe Point
Arrow Lien Hitec
[New]Servos Hitec HS-7980TH/HS-M7990TH Coreless/Magnetic Userba10
Invité
Invité
[New]Servos Hitec HS-7980TH/HS-M7990TH Coreless/Magnetic Empty Re: [New]Servos Hitec HS-7980TH/HS-M7990TH Coreless/Magnetic
Jeu 22 Avr 2010 - 9:15
es-ce les mêmes que les HS-7950TH et HS-7940TH ?
Jeu 22 Avr 2010 - 10:17
Même spécificité que le HS-7980TH (HV moteur Coreless pignon en Titane).
Le HS-7950TH est axé couple, le HS-7940TH axé vitesse.
EDIT. Lien
Invité
Invité
Jeu 22 Avr 2010 - 10:39
pour un Revo 2,5
le HS7950TH à la direction et le HS-7940TH à l'accelérateur se ne serait pas suffisant ?
Jeu 22 Avr 2010 - 12:52
Plus que parfait ! Cool
Je suppose que tu es en 6V d'origine sur ton 2.5.
Rien qu'en 6V 29.016Kg/cm-0.15s/60° à la direction et 13.032Kg/cm-0.07s/60° au Gaz/Frein...J'en connais plus d'un qui voudrait avoir ces ratios-là ! Very Happy
Maintenant personnellement je ne connais pas cette gamme-là.
Je te conseillerais aussi de lire ces deux posts :
Arrow Servo/Servos Direction 12/20/30 Kg-Cm pour 1/8
ArrowServo/Servos Gaz/Frein rapide/speed pour 1/8
Invité
Invité
Jeu 22 Avr 2010 - 17:19
@chezoit sur mon 2,5 j'ai un HS-5955TG à la direction et un HS-645MG à l'accélérateur et effectivement je suis en 6 volts, mais je désirerais passer aux lipos et en 2,4 Ghz d'où ma question de savoir s'il faut que je prenne les 7990 et 7980 ou les 7850 et 7940 car je ne connais pas la puissance et la vitesse des deux premiers
Jeu 22 Avr 2010 - 17:49
Tu veux passer ton Revo en B-Revo ou juste l'accu du récepteur ?
Le Couple et la Vitesse du 7990 et 7980 sont juste notés sous leur image en haut. Wink
Invité
Invité
Jeu 22 Avr 2010 - 21:33
merci mais les OZ correspondent à quoi en Kg
car le HS-7950TH à pour caractéristiques
Couple : 29kg.cm(6V) 356kg.cm(7.4V)
Vitesse : 0,15s/60°(6V) 0.13s/60°(7.4V)
Taille : 40x20x38mm
Poids : 68g
Pignons Titane
et le HS-7940TH
Couple : 13kg.cm(6V) 16kg.cm(7.4V)
Vitesse : 0,07s/60°(6V) 0.06s/60°(7.4V)
Taille : 40x20x38mm
Poids : 68g
Pignons Titane
il me semble que ceux en début de post ne sont pas aussi rapide et puissant que les 50 et 40
Jeu 22 Avr 2010 - 23:31
Voilà un p'tit truc utile pour calculer le Oz-in en Kg-cm, pour les servos. Wink
Un p'tit swf que j'ai extrait d'un site.
Arrow Tu cliques sur Torque position Oz-in ou Kg-cm et tu appuis sur Calculate Very Happy
