[New] Jante/Spinner alu Series 40/Oversize/3.8"  Empty [New] Jante/Spinner alu Series 40/Oversize/3.8"
Mar 14 Juin 2011 - 12:54
[New] Jante/Spinner alu Series 40/Oversize/3.8"  Jantes02
[New] Jante/Spinner alu Series 40/Oversize/3.8"  Jantes01
ONE OFF DESIGNED
SERIES 40 LIGHTWEIGHT ALLOY WHEELS CAN BE IN USE WITH OR WITHOUT THE ALLOY SPINNER
SERIES 40 MACHINED BILLET ALUMINIUM WHEELS & FULLY INTEGRATED RECESSED WEIGHTED ALUMINIUM SPINNERS SITS WITHIN THE ALLOYS X4 THE SET
THESE BRAND NEW ALLOY SERIES 40 WHEELS WITH AND A FULLY INEGRATED SPINNERS ARE MACHINED BILLET WITH AN AGGRESSIVE OFFSET GIVING UR TRUCK A WIDER STANCE AND BETTER HANDLING AT SPEEDS AND CONTROL AND CORNERING NO MORE EATING DIRT
14MM HEX
THE RECESSED SPINNERS ARE FULLY INTEGRATED WITH A SEALED BEARING SYSTEM FOR A FLAWLESS SPINNING MOVEMENT ONCED GREASED GIVING AN OPTIMAL MOVEMENT AS THE SPINNERS ARE RADICALLY WEIGHTED GIVES A NOT MOVING LOOK AS IN PICTURE 4
THESE ALLOYS ARE POLLISHED ALLOY AND FINSHED TO VERY VERY HIGH STANDARDS TO DETAIL WHICH IS TOTALLY UNBELIEVABLE AND THE MIND BLOWING DETAIL AND SHINE FINISH FOR AN RC WHEEL AS THE PICTURES SHOWN..... ACTUALLY LOOK LIKE A REGULAR FULL SIZED PIMPED OUT ALLOY WHEEL AND SPINNER ......ALTHOUGH THESE SERIES 40 RC ALLOYS LOOK TOTALLY UNBELIEVABLE U REALLY WOULD EXPECT A FULL SIZED PIMPED ALLOY WHEEL AND SPINNER.......... ( YOU WILL RECIEVE SET X4 ALLOY SERIES 40s WITH ALLOY SPINNERS)
MACHINED BILLET ALLOYS SERIES 40
SET CONTAINS X4 ALLOY WHEELS X4 ALLOY SPINNERS WITH A SEALED BEARING SYSTEM
Arrow Lien Vendeur Ebay
[New] Jante/Spinner alu Series 40/Oversize/3.8"  Userba10
seb
seb
Revoiste or Not ?
Revoiste or Not ?
Nombre de messages : 1
[New] Jante/Spinner alu Series 40/Oversize/3.8"  Empty Re: [New] Jante/Spinner alu Series 40/Oversize/3.8"
Mar 14 Juin 2011 - 19:40
bonjour
tes jantes on l air bien mais l hexagone est trop grand moi c 12mm
au cas ou j en recherche 4pour thermique 1/10
merci d avance
Mar 14 Juin 2011 - 19:47
@ Seb Merci de passer par la case présentation avant de poster
:gne: :clavier:
Mar 14 Juin 2011 - 21:25
@Seb
Bah oui, un peu de politesse dans ce monde de brute ! Very Happy
