[New] Moteur RAZER PRO BL 1/8 & RAZER BL 1/8 par Robitronic Empty [New] Moteur RAZER PRO BL 1/8 & RAZER BL 1/8 par Robitronic
Sam 6 Aoû 2011 - 21:36
Moteurs RAZER BL 1/8 & RAZER PRO BL 1/8
par Robitronic
[New] Moteur RAZER PRO BL 1/8 & RAZER BL 1/8 par Robitronic Rd22407tpic2hiresweb
RAZER 1/8 brushless car motor is specially developed to supply stable and strong power for R/C model cars.
The casing adopts high quality aluminium material which is high strength and light weight.
There are M3 and M4 two specifications of the screws fixing in the front covers.
The magnetic is slotted inside the rotor, which is different from traditional structure.
This unique structure has higher security to protect the rotor from cracking at a high speed.
__________________RD2240-7T____RD2240-8T
RPM / V (kV)__________2150__________1900
Max. Voltage (V)_______24,5___________28
Max. Current (A)_______100___________88
Number of Pole_________6_____________6
Max. RPM (U/min)_____60000_________60000
Max. Power (W________2200__________2200
Weight (g)____________375___________375
Diameter (mm)________42_____________42
Length (mm)_________68,5___________68,5
Shaft (mm)____________5_____________5
[New] Moteur RAZER PRO BL 1/8 & RAZER BL 1/8 par Robitronic Rd2240p6tpic2hiresweb
The RAZER Pro is designed with 16 slots for more power,
the motor can work at a higher efficiency before over heated.
__________________RD2240P-6T____RD2240P-7T
RPM / V (kV___________2100____________2400
Max. Voltage (V)________21_____________24,5
Max. Current (A)_______190_____________160
Number of Pole__________6______________6
Max. RPM (U/min______60000__________60000
Max. Power (W)_______ 3500___________3500
Weight (g)____________375____________375
Diameter (mm))________42_____________42
Length(mm)___________68,5___________68,5
Shaft (mm)____________5______________5
Arrow Lien Robitronic
[New] Moteur RAZER PRO BL 1/8 & RAZER BL 1/8 par Robitronic Userba10
