[New]Chargeurs TP820CD/TP610C-ACDC/TP610C Thunder Power RC
Ven 19 Aoû 2011 - 15:53
Chargeurs TP820CD / TP610C-ACDC / TP610C
par Thunder Power RC
2 x 1S-8S / 20A / 400W
Specifications TP820CD:
Type: Dual Port Multi-Chemistry DC Charger/Discharger/Cycler with Integrated Balancers
Battery Cell Counts/Types (Per Port): 1-8S LiPo/LiIon/LiFe (A123), 1-24 cell NiCd/NiMH and 6-30V Pb (lead-acid)
Balancer (Per Port): Integrated for 2-8S LiPo/LiIon/LiFe (A123) with balance connector adapter board for Thunder Power and JST-XH connectors
Input Power: 10.5-28.0V DC (40 amps max)
Charge Power: 800 watts max (400 watts max per port) w/24.0-28.0V input (see manual for additional information regarding input and output power)
Charge Current (Per Port): 0.2 to 20 amps in 0.01 amp increments
Charge Voltage: 50% storage and adjustable end voltage for LiPo/LiIon/LiFe (A123), adjustable delta peak sensitivity and end voltage for NiCd/NiMH and end voltage for Pb (Lead Acid)
Discharge Power: 100 watts max (50 watts max per port)
Discharge Current (Per Port): 0.2 to 10 amps in 0.01 amp increments
Discharge Voltage: Adjustable low voltage cutoff for LiPo/LiIon/LiFe (A123), NiCd/NiMH and Pb (lead-acid)
Cycles: 1 to 15 times with data stored for all cycles
Memories: 24 user-programmable
Firmware: User-updatable using USB
Thunder Power RC
1S-6S / 10A max / 80W / ACDC
Specifications TP610C-ACDC:
Type: AC/DC Charger, Discharger and Cycler with Built-In Balancer
Input: 100-240V AC or 11-18V DC
# Cells: 1-6S LiPo/LiIon/LiFe (A123), 1-14 cell NiCd/NiMH and 6-12V Pb (lead acid)
Peak: Adjustable delta peak values for NiCd/NiMH charging
Charge Rate: Adjustable from 0.1 to 10 amps in 0.05 increments
Output Connector: Standard/4mm banana plugs
Discharge: Adjustable current rates and voltage cutoffs for LiPo/LiIon/LiFe (A123) cells
Thunder Power RC
1S-6S / 10A / 80W
Specifications TP610:
Type: All-in-one charger and discharger with built-in Li-Ion/Li-Po/A123 cell balancer
Number of Cells: 1-6 LiPo, 1-6 Li-Ion, 1-6 A123, 1-14 Ni-Cd, 1-14 Ni-MH
Charge Rate: Selectable (in 0.05V steps) charge rates from 0.25 up to 10.0 amps
Battery Type: LiPo, Li-Ion, A123, Ni-Cd, Ni-MH, Pb
Discharge: Max discharge current 2.0 Amps
Thunder Power RC
Thunder Power RC
Thunder Power RC
1S-6S / 10A / 80W
Thunder Power RC
