[New] Triangles Dyable Delrin E-Revo 1/16 Driven Productions Empty [New] Triangles Dyable Delrin E-Revo 1/16 Driven Productions
Lun 22 Aoû 2011 - 1:03
Triangles Dyable en Delrin pour E-Revo 1/16
par Driven Productions
[New] Triangles Dyable Delrin E-Revo 1/16 Driven Productions 40749024
A gauche les triangles avant supérieur.
A Droite les triangles avant inférieur.
Driven Productions is pleased to release our white Dye-able arms for the 1/16th Mini Revo.
Our new arms are made out of DuPont Delrin for increase stiffness and manufactured by a cnc for precision.The arms are designed to fit the stock mini Revo components and mount by re-using the existing stock hardware. Almost 1/16th of and inch thicker than stock means a stronger arm that will hold up much better. Being that the arms are made from Delrin you can dye them any color that Rit clothing dye makes.
PLEASE NOTE:
These arms are much thicker than stock so a very small amount of fitting may be need to mount them.
Using aftermarket push rods may require using spacers and longer bolts on the lower DP arms.
[New] Triangles Dyable Delrin E-Revo 1/16 Driven Productions 23565556
A gauche les triangles arrière supérieur.
A Droite les triangles arrière inférieur.
Arrow Driven Productions
[New] Triangles Dyable Delrin E-Revo 1/16 Driven Productions Userba10
tibaja
Nombre de messages : 11
[New] Triangles Dyable Delrin E-Revo 1/16 Driven Productions Empty Re: [New] Triangles Dyable Delrin E-Revo 1/16 Driven Productions
Dim 25 Mar 2012 - 23:00
salut a tous qui a des retours sur ces triangle,
le derlin est tres costaud , cela est il plus costaud que les rpm?
Lun 26 Mar 2012 - 16:23
@Tibaja
Merci de passer par la case présentation.
