[NEW] Récepteur TFR4 4ch 2.4Ghz FASST par FrSky
Sam 10 Sep 2011 - 20:25
par FrSky
Compatibility:
FASST 2.4G: Air Systems (7CH Mode/Multi Mode) & Surface Systems (C1 Mode)
FrSky TF Modules: TF-8M, TF-14M
Specifications:
Number of Channels: 4
Operating Voltage Range: 3.5V~10V
Operating Temperature Range: -10℃~80℃
Dimension: 34*19*8mm
Weight: 6.2g
Features :
1) Compatible with FASST 2.4G: Air Systems (7CH Mode/Multi Mode) & Surface Systems (C1 Mode);
2) CPPM and RSSI (PWM) output - If CH3 and CH4 are connected by a jumper, CH1 will output CPPM for CH1~CH8, and CH2 will output RSSI (PWM);
3) Lighter weight and physically smaller;
4) Two selectable failsafe setting options.
Lien FrSky
par FrSky
Compatibility:
Specifications:
Weight: 6.2g
Features :
Lien FrSky
- [NEW] Radio Futaba 3PM-X 2.4GHz FASST
- Module 2.4Ghz FrSky/Fr Sky 8 voies/channel M11 Airtronics
- Compatibilité Radio Futaba et recepteur spektrum 2.4ghz
- [NEW] Eurgle 2.4Ghz 3Ch Qui a dit que le 2.4ghz etait chère?
- [NEW] FrSky Xact Brushless Servos High-Voltage - BLS5401H BLS5402H BLS5403H BLS5404H BLS5405H
