[NEW]Solution pour nettoyer jante avant collage - X-Factory Empty [NEW]Solution pour nettoyer jante avant collage - X-Factory
Dim 18 Déc 2011 - 22:16
Solution pour nettoyer les jantes avant collage
par X-Factory
[NEW]Solution pour nettoyer jante avant collage - X-Factory 1006003vvu
X Factory releases the answer to your tire gluing problems, a cleaner formulated to remove mold release and general dirt from both the tire’s bead and the wheel. Removing this grease and dirt is crucial to a good strong glue job. X Factory’s cleaner evaporates quickly leaving no residue, so tires can be mounted soon after use.
Apply liberally with a clean lint-free cloth similar to X Factory’s Big Blue Towel, wipe off the dirt, and let dry. You’ll see a black spot on the towel from all the junk you removed.
Arrow X-Factor
[NEW]Solution pour nettoyer jante avant collage - X-Factory Userba10
