[NEW] Moteurs/Moteur Brushless Sensored D8 par Epic Empty [NEW] Moteurs/Moteur Brushless Sensored D8 par Epic
Dim 18 Déc 2011 - 22:21
Moteurs Brushless Sensored D8
par Epic
[NEW] Moteurs/Moteur Brushless Sensored D8 par Epic Tep1300
[NEW] Moteurs/Moteur Brushless Sensored D8 par Epic Tep13002.th[NEW] Moteurs/Moteur Brushless Sensored D8 par Epic Tep13001.th
Epic has released a new 1/8 brushless D8 motor available in 4 different KV versions and each motor features a 5mm shaft,
heavy duty low drag ball bearings, and a sintered Neo 4 magnet rotor. Read the press release below for more info:
New brushless technology for more power than standard design motors.
New stronger sintered Neo 4 magnet rotor for more low end and overall power!
Features:
High temperature 12 pole multi wire wound stator
Heavy duty low drag ball bearings
5mm shaft
40mm dia., 42mm dia. with cooling fins
74.8mm long
Sensored
13.6 oz.
Dual bolt pattern
2-5 cell Li-Po use with correct gearing
Designed in the USA by Team Trinity
TEP1300 D8 4 X 12 Modified Motor 1750 KV
TEP1301 D8 4 X 12 Modified Motor 1950 KV
TEP1302 D8 4 X 12 Modified Motor 2100 KV
TEP1304 D8 4 X 12 Modified Motor 2400 KV
Arrow Epic Team Trinity
[NEW] Moteurs/Moteur Brushless Sensored D8 par Epic Userba10
