[NEW] ESC Xerun V3 120A / 760A 3s par Hobbywing
Sam 31 Mar 2012 - 16:54
ESC Xerun V3 120A/760A 3s
par HobbyWing
Specification XERUN-120A-V3
Current Continuous: 120A, Burst: 760A
Input * Note #1 4-9 cells NiMH/NiCd or 2-3S LiPo
Built-in BEC 6V@3A (linear mode)
Resistance 0.0003 Ohm
Motor Supported Sensored and sensorless brushless motor
Suitable Motor With 2 Lipo or 4-6 NiMH
1/10 on-road: >=3.5T, 1/10 off-road: >=5.5T
With 3 Lipo or 7-9 NiMH
1/10 on-road: >=5.5T, 1/10 off-road: >=8.5T
Suitable Car 1/10,1/12 all competitions
1/10,1/8 rock crawler
Cooling Fan 5V
Size 37.5mm(L) * 31mm(W) * 29.5mm(H)
Weight 93g
2.1 All in One. Up to ten profiles can be stored in the memory and imported or exported easily. Factory pre-set profiles include:
Blinky mode, Modify Mode, Stock mode, Practice mode, Offroad mode, Drift mode, Crawler mode.
2.2 Built-in Electronic Switch, long life and high reliability, also saves space on the chassis.
2.3 Aluminum Upper Case with optional colors, giving better heat dissipation, and allowing higher current.
2.4 External Programming Port (EPP), easy to connect and also a power port for additional fan.
2.5 Advanced Dynamic Timing technology, providing more customization possibilities for highest level competitions.
2.6 Precise throttle and brake control, setting of drag brake and brake strength with more options, new punch and brake rate control functions, and throttle and brake curves through the PC client.
2.7 Integrated Data logger, recording the maximum temperature of ESC and motor as well as the maximum RPM, using LCD Programming box to check easily in the pits.
2.8 Multi Protection Functions, making your running safe with ESC and Motor overheat protection, low voltage cutoff and throttle signal loss protection.
2.9 Easily programmed with the Professional LCD Program Box and USB Link Software.
2.10 New USB LINK Software graphic interface, providing extra parameters for advanced settings.
2.11 ESC firmware can be updated through the USB adapter in the LCD Program Box.
Hobbywing
par HobbyWing
Cooling Fan 5V
Weight 93g
Hobbywing
- toitoinouRevoiste Padawaaa super motivé
- Nombre de messages : 67
Re: [NEW] ESC Xerun V3 120A / 760A 3s par Hobbywing
Lun 9 Avr 2012 - 14:13
Hi all!
Ca se met sur un 1/16?
Lun 9 Avr 2012 - 14:20
Oui.
Pour l'adaptation je laisse la parole aux Pro 1/16.
Oui.
Mar 10 Avr 2012 - 22:21
hello !!!
et qu'est ce que ca vaut?ce machin?
REEEEEVOOOO POWWWAAAAA
Mer 11 Avr 2012 - 10:02
C'est un ESC, un contrôleur.
HobbyWing est une marque, maintenant, qui est à égalité comparo à Castle.
Chez HobbyWing, leur gamme Xerun est une gamme au dessus de leur gamme EZRun.
Tout comme le MMP ou le Sidewinder, il faut juste lui trouver une bonne place pour l'installer.
Mer 11 Avr 2012 - 10:18
Avec le moteur d'origine cet ESC est completement inutile sur un 1/16.
Vas-y avec le EZRun 60A.
En passant, j'ai eu la version 2 du XERUN 120A SD sur mon ancien Team Durango DEX410r et j'en ai été très satsifait.
Jeu 3 Mai 2012 - 16:03
Premier rebadgage par Yokomo.
- [NEW] Contro/ESC 1/10 XERUN-120A V3.1 par HobbyWing
- [NEW] HobbyWing 1/6 - 1/8 CRAWLER ESC XERUN AXE PLUS R3 FOC & Motor XERUN AXE 4274 R3 1700KV FOC
- MECHANT Rebadgage du ESC 1/00 Xerun 120A v2.1 (Waterproof) / v3.0 Sensored / HobbyPower Fire Phoenix
- [FUTURE NEW] ESC Xerun XR8 Plus 1/8 par HobbyWing
- [New] Hobbywing Xerun 150A
