Traxxas REVO Supercharger for REVO 2.5/3.3 Empty Traxxas REVO Supercharger for REVO 2.5/3.3
Sam 16 Juin 2012 - 15:13
Traxxas REVO Supercharger for REVO 2.5/3.3 Sans_t11
The RB Nitro Super-Charger is the ultimate engine upgrade component available in the RC industry. This patented, compact design consists of aluminum and thermoplastic construction. This lightweight construction minimizes engine power required to drive the Super-Charger turbo impeller system. This precision turbo impeller is enclosed in a micro-polished aluminum housing which has been machined from solid billet aircraft aluminum. This provides maximum strength and durability while providing superior air flow from the turbo impeller into the engine's carburetor. The heart of the Super-Charger's drive system is a custom composite drive belt that withstands the toughest environments. The Super-Charger's drive system incorporates a lightweight flywheel, idler pulley system, and a 30% overdrive Super-Charger pulley. The Super-Charger also includes an optional auxiliary pressure output port for boosting fuel pressure to levels not reached by the standard exhaust pump system. This allows maximum nitro and air mixture which boosts engine horsepower. This product was designed and manufactured using one the most state of the art CAD/CAM systems available. All rotating parts within the supercharger are extremely lightweight thus drawing very little power from the engine.
Traxxas REVO Supercharger for REVO 2.5/3.3 Empty Re: Traxxas REVO Supercharger for REVO 2.5/3.3
Sam 16 Juin 2012 - 15:41
je ne sais pas lire anglais , Wink on dirait un compresseur sur ce moteur , ;S ca existe en RC !!
Sam 16 Juin 2012 - 15:51
Google traduction. Wink
Le Nitro RB Super-Chargeur est le composant de moteur ultime mise à jour disponible dans l'industrie du CR. Cette brevetée, design compact est composé d'aluminium et la construction thermoplastique. Cette construction légère minimise la puissance moteur nécessaire pour faire fonctionner le système Super-Chargeur turbohélice. Cette roue de précision turbo est enfermé dans un boîtier en aluminium micro-poli qui a été usinés en aluminium aéronef solide. Cette fournit la force et une durabilité maximales tout en fournissant un flux d'air supérieure de la turbine turbo dans le carburateur du moteur. Le cœur du système d'entraînement du Super-Chargeur est une courroie d'entraînement personnalisé composite qui résiste aux environnements les plus difficiles. Le système d'entraînement de Super-Chargeur intègre un léger volant, système de poulie de renvoi, et un 30% overdrive Super-Chargeur poulie. Le chargeur Super-comprend également une option port auxiliaire de sortie de pression pour stimuler la pression du carburant à des niveaux jamais atteints par le système de pompe d'échappement de série. Cela permet au maximum nitro et le mélange de l'air qui augmente la puissance du moteur. Ce produit a été conçu et fabriqué en utilisant l'un des plus état ​​de l'art systèmes CAD / CAM disponibles. Toutes les pièces rotatives au sein de la suralimentation sont extrêmement légers attirant ainsi très peu d'énergie du moteur.
Revoiste Jediwaaa LiONMan
Nombre de messages : 1983
Sam 16 Juin 2012 - 16:11
ouaip en gros c'est l'équivalent du 6s avec slipper serrer.
toute la transmission est a renforcé avec ce truc :siffle:
Sam 16 Juin 2012 - 16:18
Je ne sais pas du tout ce que sa vaut...
Je ne connaissais pas, je suis tombé la dessus par hasard sur ebay.
Arrow Lien RBINNOVATIONS
Sam 16 Juin 2012 - 18:25
C'est fixé dans cette position ? Si oui, bonjour le centre de gravité et les accrochages sur le toit :S
Sam 16 Juin 2012 - 18:28
Sam 16 Juin 2012 - 18:33
OK, c'est quand même haut moins que l'impression que ça me laissé sur ta photo.
Par contre, vu le prix, ce n'est pas plus judicieux d'acheter un moteur plus robuste et plus fiable directement. La courroie, on dirait un élastique de La Poste Laughing
Sam 16 Juin 2012 - 19:24
lol!
Je ne compte pas l’essayer, mon moteur me conviens très bien (OS.30). Smile
XDG 71
XDG 71
Nombre de messages : 965
Dim 1 Juil 2012 - 18:37
Qui a déjà test les supercharger pour picco 26 ??
Lien pour vous: http://www.rbinnovations.com/PhotoDetails.asp?ShowDESC=N&ProductCode=RBK10550
