Vétéran Modo Jediwaa McGyver
>3 speed convertion kit for...Revo ! Empty >3 speed convertion kit for...Revo !
Mar 26 Aoû 2008 - 1:03
Votre Revo ne distance encore pas assez les pauvres truggy de vos amis ?!
Maître Chezoit finder pense toujours à vous et déniche un kit de conversion 3 vitesses pour revo
Photo:
>3 speed convertion kit for...Revo ! C8c9_110
Build your own 3-Speed creation with a Basic 3 speed kit.
This kit includes all of the parts you need to Convert your .15 engine or .18 Revo to a 3-Speed,
then you can your wheels & adapters, for your own custom setup!
This kit does NOT alter the function of the stock transmission. You will still have reverse!
Another Note: For use with the stock 2.5R and 3.3 engines only. Anything else and your
on your own, there are just too many engines out there, some with there own mounts
some without. If it has the same room behind the engine as the stock engine when bolted
up to our engine mount, then it may work as long as it's the same length to the front of
the crank. Also, the kit is designed for SG style cranks, we do not provide a clutch nut adapter.
Note: Using a big block with these kits is possible....however, you will need to slot your chassis where the transmission mounts and move the transmission forward. You also need to use the stock type clutch and the clutch bell we provide. We do not warranty any parts for use on big block kits.
L'annonce Ebay
Vendeur ebaysjallen_344
Chez 2cool RC !
A++ Like a Star @ heaven
Aricospeed
Aricospeed
Nombre de messages : 1267
>3 speed convertion kit for...Revo ! Empty Re: >3 speed convertion kit for...Revo !
Mar 26 Aoû 2008 - 9:41
Exelente newZ' !! Très bien pensé, utile, sa fait plaisir que y'en est qui soit toujours sur le coup pour des céations original..
Fier d'avoir un revo Laughing
skaterman
skaterman
Nombre de messages : 248
Mar 26 Aoû 2008 - 13:36
pas donné nonplus, a voir si sa se popularise
Aricospeed
Aricospeed
Mar 26 Aoû 2008 - 15:09
skaterman a écrit:pas donné nonplus, a voir si sa se popularise
Niveau matière .. c'est sure que c'est chère .. Mais pour l'utilité de l'options et la qualité Twisted Evil c'est le prix à payer !
Wink
skaterman
skaterman
Mar 26 Aoû 2008 - 16:42
Wink
tu as tout à fait raison... mais qd meme Laughing
skaterman
skaterman
Mar 26 Aoû 2008 - 18:15
par contre je comprends pas tres bien dans quels cas on peut l'utiliser
Sehnsucht
Sehnsucht
Nombre de messages : 485
Mar 26 Aoû 2008 - 18:28
ça va envoyé du steak avec ça....
Mar 26 Aoû 2008 - 19:57
Comme je disais à Chezoit ça ressemble à une boite de piste 1/10 eme ou 1/8 eme
Donc ça doit se placer à la place de la MA Parce que je trouve que l'axe avec les pignons blancs ressemble à l'axe tout en bas de la boite d'origine bien qu'il soit un peut court d'un côté..
Faudrait Mailer le gars pour les infos !
skaterman
skaterman
Mar 26 Aoû 2008 - 23:30
il me semble que ça se met directement sur la couronne d'attaque, comme sur les voitures piste, avec une double couronne et une double cloche
Mar 26 Aoû 2008 - 23:54
Ça m'étonnerai à cet endroit y a pas de place !
skaterman
skaterman
Mar 26 Aoû 2008 - 23:58
je sais bien mais regarde les 2 couronnes noirs posées l'une sur lautre, ainsi que la cloche demonté en haut a droite
Mer 27 Aoû 2008 - 14:57
Yep, la couronne classic est remplacée par cette double et on dirait aussi que la cloche à deux lignes de dents. le kit est monté à 89€ FDPO...pour l'instant... cyclops
>3 speed convertion kit for...Revo ! Userba10
Hammerhead
Hammerhead
Nombre de messages : 435
Mer 27 Aoû 2008 - 17:19
si j'ai bien compri pour avoir 3 vitesse avec se kit il faut suprimer la marche arrière ??
Aricospeed
Aricospeed
Mer 27 Aoû 2008 - 17:48
révo3.3 a écrit:si j'ai bien compri pour avoir 3 vitesse avec se kit il faut suprimer la marche arrière ??
Tu as bien compris Exclamation Exclamation
Mer 27 Aoû 2008 - 19:20
En fait peut être pas je vais Editer mon message
M'enfin impossible de passer cette double le couronne devant le moteur !
A moins qu'il y ai une pièce pour décaler la boite !?
A++Like a Star @ heaven
skaterman
skaterman
Mer 27 Aoû 2008 - 19:54
exactement, donc soit on supprime le slipper, soit les couronnes font 1mm d'epaisseur, soit cest la double cloche qui fait 1mm d'epaisseur, ou bien tout a été retravaillé pour que ça passe
c'est bien intriguent tous ça
skaterman
skaterman
Mer 27 Aoû 2008 - 21:04
aparament il semblerai que ça remplace le slipper, et que il y a certaine pieces qui permettent de reculer le moteur, c'est celon la taille
Revoiste Jediwaaa CarbonMan
Nombre de messages : 1457
Mer 27 Aoû 2008 - 21:34
Si c'est pas a l'interieur de la boite et que cela supprime le slipper
je n'y vois aucun intérêt
et cerise sur le gâteau c'est ce mag de m...e de 2coolrc qui le vend Evil or Very Mad
car qui saute
tiniboule
Nombre de messages : 47
Mer 3 Sep 2008 - 12:52
moi j avais vu un kit il y a bien longtemps mais je n ai jamais vu de retour
le liens:
3 speed
il se monte a la place de la marche arriere
tiniboule
Mer 3 Sep 2008 - 13:09
C'est le même.
Il faut vraiment compter plus de 100$ le kit....mMM pas beaucoup de testeur à ce niveau-là......des testeurs dans le coin ?
Juniortiti
Juniortiti
Nombre de messages : 852
Mer 3 Sep 2008 - 16:03
100$ pas pour le moment, n'abusons pas des bonens choses meme si c'est vrai que c'est tentant...
Si quelqu'un teste et que ça se vérifie, a voir encore que moi je n'ai pas d eproblème... avec la marche arrière qui marche nikel pour le moment donc je voudrais pas la supprimer...!
skaterman
skaterman
Mer 3 Sep 2008 - 18:03
si on finance je veux bien tester Razz
