[NEW] Carter de différentiel pour 2WD 1/10 par Hot Racing
Ven 28 Déc 2012 - 12:30
pour 2WD 1/10 : Stampede, Rustler, Slash et Monster Jam
par Hot Racing
#TE38CH
Sealed differential case Stampede Rustler Slash
This is an Aluminum and hardened steel Sealed differential case for Stampede Rustler, 2WD Slash, and Monster Jam
FEATURES:
CNC Aluminum and Steel Gear Sealed differential case
Sealed differentials allow it to tune to current track conditions by changing the weight of the diff oil.
Four O-Rings that seals against fluid leakage result in a very smooth differential that improves the performance of your vehicle.
YOU WILL RECEIVE:
One Sealed differential case (no gear in side)
REQUIREMENTS:
Filling Diff FLUID and assembling the diff case with stock Traxxas diff gear
Installation on the vehicle
SPECIFICATIONS:
Outside diameter: 37.5mm (1.48")
Shaft diameter: 5.10mm (.200")
Overall thickness: 21.2mm (.834")
Lien Hot Racing
par Hot Racing
#TE38CH
FEATURES:
YOU WILL RECEIVE:
REQUIREMENTS:
SPECIFICATIONS:
Lien Hot Racing
- [NEW]Carter de Diff/Différentiel 1/10 2WD VXL par Hot Racing
- [OLD NEW] Déco Carter et filtre moteur pour 1/10-1/8 par RPM Racing
- [NEW]Carter d'Essieu arrière aluminium pour UDR GDS Racing - Aluminum Rear Axle Housing
- [New] Graisse au Teflon pour Différentiel Ultimate Racing
