Page 3 sur 3 • 1, 2, 3
Re: E-Jato en attente d'un kit pour le brushlessiser - EJato Brushless Electric
Ven 17 Sep 2021 - 12:04
Ah oui pas un train av complet donc.
En Stadium, je conseillerais des Portes fusée alu et fusée en plastique.
- Nombre de messages : 5570
Ven 17 Sep 2021 - 18:01
Ça me fait cagé de couper dans un porte fusée alu
Lun 20 Sep 2021 - 10:53
""de couper ?" (de taper ?)
Lun 20 Sep 2021 - 11:07
Faut couper une parti de l'étrier pour passer le triangle
Lun 20 Sep 2021 - 12:01
Là, tu parles de l'adaptation de ceux du rustler ?
Sur les modèles pour Jato spécifique, je n’ai pas eu vent d'une modif quelconque.
Lun 20 Sep 2021 - 12:39
ok, mais du coup il me faut des jantes proline a roulement
Rustler caster mod on a Jato (Better Pics) - Traxxas Jato hex Front 12mm - Jaco 12mm Avant
Lun 20 Sep 2021 - 15:20
Ah bah il fallait le dire !
Attention déterrage. Post forum Traxxas de 2010.
Ca fonctionne aussi sur le porte fusée alu TRX of course.
jjlogue3 a écrit:I did this mod about a year or so ago and took all the pictures with my cell phone and the pics were horrible! Here is an updated version of it and I can say that I have been running this mod for a while and have no complaints. It works awesome and wheels and tire choices are awesome! I am currently running the Proline Titus beadlocks (p/n-2713-1x) with Dirt Hawg tires (p/n-1071-00) or as a combo (p/n-1071-13) but I haven't really ran them yet as I am still in the break in stage of my new TRX 3.3.
Here is the shopping list-
RPM Electric Rustler Caster Blocks 30 Degree p/n 80712
RPM Electric Rustler Front Bearing Carriers p/n 80372
Traxxas Suspensionn Pins 2.5x31.5mm w/ e-clips p/n 3740
Traxxas Electric Rustler Front Axels p/n 3637
Traxxas Hexes and Axel Pins p/n 3654
5x11x4mm Bearings
Ok now with the mod!
Here is the before picture with the stock setup-
Pic with replaced parts removed-
Difference between the two spindles-
Drilling out the bottom of the new caster (where a-arm connects) with a 1/8" drill bit-
Installation pics-
Finished product-
Lun 20 Sep 2021 - 15:27
Effectivement l’étrier RPM a l'air plus épais au niveau de l'axe, celui du rustler d'origine et beaucoup plus fin, j'ai eu peur de le fragiliser en le perçant
Lun 20 Sep 2021 - 15:33
Prends de le porte-fusée en alu, d'une pierre deux coups, tu seras tranquille.
Lun 20 Sep 2021 - 15:38
celui du 4X2?
Lun 20 Sep 2021 - 16:32
Oui, il y a des gars qui avaient pris les options TRX Rustler BL #3632A / 3632T / 3632P / 3632G / 3632X et avaient appliqué la modification.
Après tu peux toujours t'amuser sur des versions moins cher. Perso j'ai les HR.
Je n'avais pas développé, du pourquoi ce mélange d'alu et de plastique à cet endroit.
Ca t'apportes plus de rigidité à haute vitesse et la fusée en plastique quant a-t-elle c'est une pièce qui va, d'une pierre deux coups, absorber les vibrations et faire fusible. Bref une direction qui tient droit.
Petite info qui a son importance, j'ai remarqué que la fusée Pro-lIne, en plastique, était plus rigide que celle de RPM, donc encore plus de stabilité, mais toujours assez flexible.
