Nombre de messages : 675
Hyperion EOS720I ou Icharger 208B ??
Mar 26 Mai 2009 - 1:21
Tout est dans la question. Ils valent tous deux 200$ et ils semble que ce soient les références du moment. C'est pour charger des Hyperion Generation 3 en 2x2S et 5000Mah dans un premier temps.
HYPERION:
"NEW! Hyperion EOS 0720i NET 7S 16N CHARGER, with Integrated LBA10A balancer, TCS and 250W charger power. Network to 500W and 14S max(2x7S balanced) - See Details!
The EOS 0720i NET is an extremely powerful (250W, 20A), versatile, easy-to-use charger with special features for speed charging lithium packs up to 7S*. 2C rates are possible even with our largest 7S packs. Integrated LBA10+ balancer has 300mA balance power per cell. Terminal Capacity Selection, PS Load Control, PC Dataport (PC software coming soon!), and User-Upgradable firmware round out this fantasitic package. But don't stop there: *two of these chargers can be Networked to allow charging two similar packs as a single unit, up to 14S total at 500W charge power. Nothing else on the planet offers so much power for so few $$ out of your pocket. Output Charge Cord/Connector set and Hyperion Balance Multi-Adapter for 2S to 7S packs are included."
ICHARGER:
"Capable of handling up to 350W or 20A charge rates. Lipoly, LiFe and Lilo compatible as well as able to charge up to 8 cell packs.
The iCharger is famous for its ultra-accurate balancing feature. Each unit is calibrated at the factory prior to shipping!
This is a quality precision charger.
Spec.
Input voltage range: 4.5 – 32.0VDC
Charge current range: 0.05 – 20.0A
Discharge current range: 0.05 – 20.0A
Maximum charge power capacity: 350W @ input voltage > 18V
Maximum discharge power capacity: 30W
Maximum extern discharge power capacity: 600W @ 30V/20A
Current drain for balancing: <350mA
Balance accuracy: <10mV
Lithium (LiPo/LiIo/LiFe) battery cell count: 1 – 8 series (In non-balance mode, expand LiFe to 10s)
NiCd/NiMH battery cell count: 1 – 25 series
Pb battery cell count: 1 – 18 series (2 –36V)
Log Files storage: 16Mbit (36 hours)
Battery setup memories: 10
Intelligent temperature control: Yes
PC Connect: USB port
Weight: 420g
Dimensions (L X W X D): 143 x 97 x 26mm (5.63 x 3.82 x 1.02in)
Included.
208B Balance Charger/Discharger
2 Aligator clips
Banana leads
Temp Probe
CD
Note: Power supply not included."
Votre avis? Quelle alim est nécessaire pour l'un et pour l'autre?
Au minimum qu'est ce que vous conseilleriez pour charger/équilibrer assez rapidement du 2x2s 5000Mah?
Merci !
HYPERION:
ICHARGER:
Spec.
Weight: 420g
Included.
2 Aligator clips
Banana leads
Temp Probe
CD
Merci !
