[NEW] Ofna Picco JL .28 Team Turbo 51234 Empty [NEW] Ofna Picco JL .28 Team Turbo 51234
Lun 21 Sep 2009 - 6:43
Comme si, seul, la puissance .28 ne suffisait pas ! pirat
[NEW] Ofna Picco JL .28 Team Turbo 51234 Ofn51234
OFNA is proud to introduce the latest offering from Picco in Italy:
The JL .28 TEAM TURBO. The latest member in OFNA's line of successful competition engines.
This engine has been built with a new crankshaft and sleeve designed to broaden the power band.
Modifications to port size, design, and crank timing allow for higher RPM's and increase in TORQUE.
These modifications have given the engine more corner exit power and seemingly endless top speed
on long straights. Designed for the Truggy and GT applications, this engine gives the racer the
performance to take his skills to the next level.
Arrow FEATURES
>14mm Crankshaft
>7 Ports
>Hard Chromed Brass Lapped Liner
>Piston CNC Machined from Billet High Percentage Silicone Alloy
>Swiss Quality Ball Bearings
>Separate Large Size Combustion Chamber Insert
>Composite Slide Carburetor Pro Carb
>New 8mm Composite Carburetor
>Larger Intake Port (More Torque)
>Modified Exhaust Port (More RPM)
Arrow ENGINE SPECIFICATIONS
>CLAIMED HP: 3.8
>DISPLACEMENT: 4.60cc
>STROKE: 17.6
>BORE: 18.35
>RPM 37,000
>CARB TYPE: SLIDE
>CRANK: SG
>CONSTRUCTION: ABC
>ENGINE SIZE: .28
>WEIGHT: 350grams
[NEW] Ofna Picco JL .28 Team Turbo 51234 Ofn512341.th
Turbo cut crank to allow fuel to flow faster through the engine for more power and torque.
[NEW] Ofna Picco JL .28 Team Turbo 51234 Ofn512342.th
Larger 3-port exhaust and larger 7-port intake for more speed and torque.
Arrow Vue sur Revo / Support Traxxas Big Block
Arrow Actuellement dispo seulement sur Ebay.
[NEW] Ofna Picco JL .28 Team Turbo 51234 Userba10
