[NEW] Castle Creation Checker programmation Contro Mamba Bec Empty [NEW] Castle Creation Checker programmation Contro Mamba Bec
Sam 12 Déc 2009 - 10:49
Checker programmation Contro Mamba & Bec CC/Pro
par Castle Creation
Field Link Programming Cards for AIR and CAR Controllers
[NEW] Castle Creation Checker programmation Contro Mamba Bec Attachmentsl[NEW] Castle Creation Checker programmation Contro Mamba Bec Attachment2e.th
[NEW] Castle Creation Checker programmation Contro Mamba Bec Attachment1v
Arrow The Car Field Link is compatible with all Sidewinder, Mamba, and Monster controllers.
[NEW] Castle Creation Checker programmation Contro Mamba Bec Attachment3.th[NEW] Castle Creation Checker programmation Contro Mamba Bec Attachment5.th[NEW] Castle Creation Checker programmation Contro Mamba Bec Attachment4.th
Arrow The AIR Field Link is compatible with nearly all Phoenix, Phoenix HV, ICE, ICE HV and Thunderbird controllers as well as CC BEC and CC BEC PRO BECs.
Castle Creations Field Link Programming Cards for AIR and CAR Controllers
Name: Field Link ground-001.jpg Views: 904 Size: 280.7 KB
Castle is pleased to announce the release of our new Field Linkprogramming
cards for AIR and CAR controllers. These handy cards allow users to change
popular control settings quickly without a computer – great for the field box
or workbench! Field Link cards offer the simplicity of one button operation.
Click to move through the settings and hold/click to change the values.
It’s that easy!
Customers can also use the Field Link card as a USB adapter to connect
Castle Link compatible controllers to their Windows PCs for complete
access to all available programming options.
Card Dimensions:
L: 3.5” (89 mm)
W: 2.25”(57mm)
H: .1875 ” (5 mm)
Field Link CAR ESC Programmer
Part Number: 010-0063-00
Field Link AIR ESC Programmer
Part Number: 010-0063-01
Shipping Early January 2010
[NEW] Castle Creation Checker programmation Contro Mamba Bec Userba10
Nombre de messages : 1155
[NEW] Castle Creation Checker programmation Contro Mamba Bec Empty Re: [NEW] Castle Creation Checker programmation Contro Mamba Bec
Mar 12 Jan 2010 - 20:35
Salut je voudrai savoir si il est compatible MMM et ou pouvoir l'acheter car ça m'intéresse^^
Mar 12 Jan 2010 - 20:42
pour les lieux, je pense castle Smile
Mar 12 Jan 2010 - 20:43
Merci desoler je ne comprend pas du tous l'anglais! Tu pence que sa coute chers ou pas?
Mar 12 Jan 2010 - 20:50
Enfet pas encore sorti ^^ C'est pour ca que je ne le trouvait pas !
Mar 12 Jan 2010 - 20:51
dispo vers janvier 2010
et pas encore en vente
edit ben wala
Mer 13 Jan 2010 - 0:41
@ e-bline
Merci d'éditer tes messages à si peut d'intervalle.
Ven 15 Jan 2010 - 23:02
Le Field Link Programming Cards coutera apeut pres 26 dolars
http://www.horizonhobby.com/Products/Default.aspx?ProdID=CSEFPROAIR
Sam 16 Jan 2010 - 11:57
Ou chez Tower Hobbies sans oublié leur code réduc.
Pour la petite infos, eux l'auront courant Février.
Revoiste Jediwaaa TazMan
Jeu 21 Jan 2010 - 10:05
dispo à ce jour chez castle création
lien
Jeu 21 Jan 2010 - 13:01
Oui mais bonjour les frais d'envoi chez eux... :S
Jeu 21 Jan 2010 - 14:50
arf ils sonts un peu pareile que chez hobby...
si certains sont interessé.........
achat groupé les mec.....30 sur place 35E fdp in
Jeu 11 Fév 2010 - 0:16
salut à tous
important information de compatibillité
avec les mise à jour firmware inferieur à 2007 ca crée des disfonctionnement!
le firmware dois etre impérativement apres 2007
voici l'appareil en question:
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01616
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01617
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01618
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01619
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01620
premier test sous windows vista installation de pilote automatique sans soucis!!
shema des branchements
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01621
seconde étape test du field link en config USB.
ont constate la lumiere allumé au fix tout en haut à gauche
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01622
une fois le controleur connecter cligniottement vert rapide un peu comme le link usb standar (impossible à voir étan donné que c'est ne photo)
branchement...
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01623
test une fois prog lancé....
ca reconnais et lis la prog sans soucis! nikel
second test!
connection sans usb donc accu nécessaire.... ont constate que les diodes sonts d'une autre couleurs
branchement à noté que pour que ca fonctionne une fois branché vous devez allumé l'interrupteur
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01624
troisième et dernier test modification du punch control!
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01626
ont constate donc que punch control est selectionné (diode) ont voi ensuite les lumières en haut qui correspond au pourcentage!
avec la programmation actuel ont obtien ensuite ceci sous castle link usb celui de la carte de programmation"field link":
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01627
......expliquation de programmation!
voici Smile la seul et unique touche qui sert a programmer tout le controleur au bout de la clef....ont fait avec se qu'ont as....pauvre de moi Neutral
[NEW] Castle Creation Checker programmation Contro Mamba Bec Dsc01628
ont appuie 1 fois pour changer le parametre à modifier et ont reste appuyer pour choisir le pourcentage ou autre!
expliquation diode reglage...
en haut les pourcentages :
1ère diode = off (0%)
1ère et 2ème = 10%
2ème = 20%
2ème et 3ème = 30%
3ème = 40%
3ème et 4ème = 50%
4ème = 60%
4ème et 5ème = 70%
5ème = 80%
5ème et 6ème = 90%
6ème à 100%
hormis le pourcentage le restan des parametres correspond à la fonctionnalité indiquer
éteigniez l'interuppteur débranchez et envoyez la sauce Wink
franchement!!!!!!! je vous interdit de dire que vous avez pas compris ou que vous y arrivez pas Laughing
_David
_David
Nombre de messages : 669
http://www.tram-riders.com
Jeu 11 Fév 2010 - 8:39
super ton post c est pas mal cette carte.
Par contre au niveau de "l'emballage" ca laisse à désirer, on dirait un vieux bout de papier collé sur le pcb.
Jeu 11 Fév 2010 - 9:21
c'est précisément cà ont dirai du carton bidon plastifier mais bon simple et rapide d'utilisation puis le faite que cà aient un aspect carton.......ca rentre dans le porte feuille Wink
XDG 71
XDG 71
Nombre de messages : 964
Mer 10 Mar 2010 - 23:17
ou a tu achetez ta carte merci de ta réponse ?? Very Happy
Mer 10 Mar 2010 - 23:33
XDG 71 a écrit:ou a tu achetez ta carte merci de ta réponse ?? Very Happy
Je répond a ca place car il est pas connecter Wink! Il a acheté sur Liquid RC voila mais attention au stock sa par comme du petit pain et il est pas cher (il est a 25-30 euro fdpi je crois;))
XDG 71
XDG 71
Jeu 11 Mar 2010 - 1:28
Merci toi ^^
Flogda
Flogda
Nombre de messages : 759
Mar 18 Mai 2010 - 22:44
Petite question.
Est ce que ça remplace completement le logiciel PC + Castle link?
Est ce que ce simple appareil suffit pour toute la Prog d un ERBE?
Merci d avance
Mar 18 Mai 2010 - 22:47
Cela remplace seulement la carte!
Il y a les principaux réglages utile pour régler un MMM (simplifiée)
Flogda
Flogda
Mar 18 Mai 2010 - 22:49
La carte?
Dsl mais je suis en train de tout prévoir pour l achat de mon ERBE la semaine prochaine,
Qu est ce que cette carte dons tu parles?
Mar 18 Mai 2010 - 22:51
Bein oui c'est une carte a puce....
Lits bien le post
Je suis désolé je vois pas se que tu veux en faites désolée
Flogda
Flogda
Mar 18 Mai 2010 - 23:06
En fait, je vais au states après demain pour 5 jours,
J ai prévu de m offrir Un E-Revo Brushless.
Je ne sais pas du tout ce qui est livré avec.
Je me renseigne pour savoir quoi acheter en même temps.
J ai déjà un chargeur équilibreur
J ai déja commandé un lot de Lipo 2S
Mar 18 Mai 2010 - 23:08
Personnellement je trouve que tu est parée pour un truc rtr!!!
Après des option qui serve.. triangle rpm et autres déjà citées sur le fofo)
Après si tu n'a pas de PC il te faut cette carte sinon pas utile obligatoirement!!!
Mar 18 Mai 2010 - 23:24
ou Window sous Mac Intel.
