[New] Chargeur Much More Cell Master Legend Black Empty [New] Chargeur Much More Cell Master Legend Black
Dim 31 Jan 2010 - 0:10
Chargeur Cell Master Legend Black 16A en LiPo
par Mush More
[New] Chargeur Much More Cell Master Legend Black Muchmore
 Much-More Racing own false-peak detection algorithm
 3 Kinds of charge cutoff system and display - Peak Cut(Lithum Volt cut), Capacity Cut, Temperature Cut
 Customizable Main Menu
 Blue back light LCD Display with 20x4 characters
 Quick setting button and up down scroll wheel
 16A Charging and 10A Discharging with high capacity LiPo, LiFe batteries
 Indivdual voltage balancer inside for Lithium batteries
 Real time individual voltage monitoring (charging and discharging for Lithium batteries)
 Normal, Storage, Race charge mode (1-2S) for Lithium batteries
 Lithium batteries condition view (Condition check mode: each cell volt, total volt, energy %)
 Easy setup cycling charging and discharging
 Simple UI menu and program
 Accurate volt reading, Muchmore Racing own output dual wire design for perfect charging
 Accurate current apply output gold plated clips
 Arrow state indicator
 Power master legend creative docking system
 Micro magnet temp sensor
 Output control pins port for Much-more Racing Battery warmer or Cooling fan stand
Specification:
 Dimension - 129 x 170 x 46mm
 Weight - 660g
 No. of cells - 1-14 (NiCd, NiMH) 1-6 (LiPo, LiFe, LiMn, Lilo)
 Pb Battery Voltage - 2-20V
 S-Linear & Easy NiMH, NiCd Charge Current - 0.2-10.0A (Adjustable) Max 250W
 LiPo, LiFe, Lilo Charge Current - 0.2-16.0A (Adjustable) Max 250W
 Discharge Current - 0.2-10.0A (Adjustable) Max 80W
 Cut-off Voltage - S-Linear 0.1-9.9V (adjustable) LiPo, LiFe, Lilo, Pb (Auto)
 Input Voltage - DC 10.0-15.0V
 Charging Capability - 0.9999mAh (adjustable)
 Charging Modes - S-Linear & Easy NiMH, NiCd Charge, LiPo, LiFe, Lilo, Pb
 Voltage Threshold/Delta Peak - S-Linear 3-99mV/Peak, Easy NiMH, NiCd / 3 Stage adjustable
 Thermometer Sensor - 15-70 degree Celsius
 Keys - 2 Button & 1 Up/Down Wheel
 Cooling - IC Controlled dual fans
 LCD Monitor - 20x4 lines Blue LCD Display
Arrow Lien Much More UK
[New] Chargeur Much More Cell Master Legend Black Userba10
