[NEW] Cardans/Cardan pour Slayer Summit par MIP
+6
Padbol
10 participants
Lun 1 Mar 2010 - 12:38
Cardan pour Slayer & Summit
par MIP
# #9168 MIP Spline CVD Kit for Traxxas Summit #5610 $65.00
# #9169 MIP Spline Bone, Traxxas Summit $15.00
# #9170 MIP Spline CVD Kit for Traxxas Slayer $65.00
Pour Summit.
MIP have released a number of new products for the Traxxas Summit and Slayer,
starting with these spline and center CVD kits, which replace the plastic drive shafts
with hardened high strength alloy, used for high power electric systems. MIP Spline
technology accommodates both long and short travel suspensions and comes with
6mm bores for new style output shafts. MIP have also introduced an adjustable 2
hole clutch kit for the Traxxas Slayer that has two sets of holes for light or heavy
setting and are pre-cut to ensure symmetrically even wear. Easy installation and
operation, they offer great durability and wear resistance.
# #9173 MIP Spline Center CVD Kit for Traxxas Slayer $65.00
# #9174 MIP 6mm Drive Hub, Traxxas Slayer (1) $10.00
# #9175 MIP 6mm Brake Drive Hub, Traxxas Slayer (1) $10.00
Pour Slayer.
Source RedRC
Lien MIP
par MIP
Pour Summit.
Pour Slayer.
Source RedRC
Lien MIP
Nombre de messages : 1124
Re: [NEW] Cardans/Cardan pour Slayer Summit par MIP
Mer 3 Mar 2010 - 21:17
Enfin des cardans option pour Summit ! Reste à voir le prix ...
Mer 3 Mar 2010 - 21:43
Du MIP...ca ne va pas être donné.
Mer 3 Mar 2010 - 22:44
Question les cardan option summit vont pas sur le e-revo donc pourquoi pas metre pour summit et e-revo?
Mer 3 Mar 2010 - 22:49
Les options Cardan E-Revo sont un poil courtes.
Mer 3 Mar 2010 - 22:51
a d'accord peut être a cause de la hauteur de caisse plus haut que le e-revo nan?
Mer 3 Mar 2010 - 22:52
Yes, Billettes/Rockers plus longs.
Mer 3 Mar 2010 - 22:53
Cool bon a savoir ca pour ma conversion e-revo et summit
merci du tuyaux! @+
merci du tuyaux! @+
Jeu 4 Mar 2010 - 16:56
Non !
Les cardans sont plus courts du côté du T-lock, il y a une bonne 15aine de mm d'écart !
Jeu 4 Mar 2010 - 18:18
Non !?
Si tu installes des cardans option Revo/E-Revo sur le Summit...et que tu pousses son débattement à fond, les cardans vont se déboiter (discutions entre E-Bline et moi). C'est pour cela que MIP a créé des cardans à allongement variable.
Il faut suivre Padbol.
Jeu 4 Mar 2010 - 18:21
et si tu prend les triangle normal du e revo et tu les met sur le summit (vue que la différence majeur entre triangle SUM' et REV' donx just des triangle désaxée ? (2 troux de fixation horizontaux pour les boule des fusée)
Jeu 4 Mar 2010 - 18:26
C'est les mêmes triangles.
C'est le big débattement qui créer le problème avec des cardans classiques.
Je suis désolé je n'ai pas compris ton second point :
e-bline a écrit:.... (vue que la différence majeur entre triangle SUM' et REV' donx just des triangle désaxée ? (2 troux de fixation horizontaux pour les boule des fusée)
Jeu 4 Mar 2010 - 18:39
Yes c'est les triangles arrière qui viennent sur le Summit.
Qu'est ce que tu voulais savoir sur ces triangles ?
Jeu 4 Mar 2010 - 18:40
c'est la version extendend pour revo, elle était faite pour le platinium a la base
pour rallonger l'empattement et avoir un châssis plus stable et moins cabreur
Jeu 4 Mar 2010 - 18:41
bein même en mettant les triangle d'origine du e revo ou revo,les cardan se déboitent?
Jeu 4 Mar 2010 - 18:44
A moyen débattement non mais à fond oui.
C'est juste une question de longueur de cardan.
Jeu 4 Mar 2010 - 18:46
D'accord merci pour la réponse;) (poste peux etre nettoyée;) Car je panse pas que j'aide avec mes question
Jeu 4 Mar 2010 - 18:48
Si justement, ca va expliquer pourquoi cette option niveau cardan.
Jeu 4 Mar 2010 - 20:04
Si, les cardans ont des tailles différentes sur le Summit ... Il n'existait aucune option montable dessus pour le moment jusqu'à ces cardans !
Jeu 4 Mar 2010 - 22:05
Oui, ne t'inquiète pas on l'a compris !
C'est justement ce que j'ai expliqué à E-Bline.
Mer 17 Mar 2010 - 15:33
Magnifiques ces cardans Une super alternative à ceux d'origine je pense
Mer 17 Mar 2010 - 18:32
Juste pour avoir confirmation, il me semblait avoir vu quelque part que les cardans d'origine summit étaient super pour le revo, dans ce sens là ça marche.
Donc pour reprendre le soucis de Truggy P, les cardans option de summit doivent être impec aussi sur le revo, me trompe-je?
Jeu 18 Mar 2010 - 4:50
Sur un véhicule qui prend beaucoup de tours. Je ne pense pas qu'il faille mettre des cardans "modulables " niveau extension. Le faite qu'il ne soit pas d'un seul "bloc", ca va surement faire le même effet que ceux d'origine > Vibration > déstabilisation du train, etc.
A tester sur Revo/E-Revo...
Jeu 18 Mar 2010 - 13:56
Autant pour moi, plus de rotation, donc plus de centrifugation, donc plus de chance que ça bouge, merci pour cet info
