[New] Outil pour suspensions par Arrowmax Empty [New] Outil pour suspensions par Arrowmax
Mer 24 Nov 2010 - 9:42
par Arrowmax
[New] Outil pour suspensions par Arrowmax 20101110182426985
Code:AM-190017
Name: MULTI SHOCK-CAMP
Description:
The newest tool of Arrowmax is this Aluminium Multi-Shock Camp.
Suitable to different scale on road, off road, buggy and truggy and
monster truck’s shock absorber set, this multi-tool with 7075 CNC
machining, light weight, convenient carrying admission.
the specialized tools selection with purple and black color.
A1. For shock body,different shaped shock cap nut varied from 8mm to 15mm can be claped tightly
A2. For shock body,different shaped shock cap nut varied from 15mm to 25mm can be claped tightly
B. Specialized designed for installing 4mm to 7mm pivot ball and composite shock part without surface damage
C. Specialized designed multi-functional clamp handle, good looking and use comfortably
D. For Serpent car series in installation of RCC Alu. shock cap nut. And while has a 9mm wrench
E1. Shock rod varied from 2mm to 3mm can be clasped tightly,easily setting up shock shaft and composite shock part without surface damage
E2. Shock rod varied from 3mm to 5.5mm can be clasped tightly,easily setting up shock shaft and composite shock part without surface damage
Arrow Lien Freemaxmp
[New] Outil pour suspensions par Arrowmax Userba10
Legnathead
Legnathead
Nombre de messages : 554
[New] Outil pour suspensions par Arrowmax Empty Re: [New] Outil pour suspensions par Arrowmax
Mer 24 Nov 2010 - 20:51
pardonnez mon ignorance.. qui peut m'expliquer son utilitée :honte: ?
Nombre de messages : 1111
Mer 24 Nov 2010 - 21:11
Je miserais que c'est pour faciliter le demontage d'un amortos mais je suis pas sur du tout! :siffle:
Mer 24 Nov 2010 - 22:24
oui
c'est pour démonter les amortisseurs au complet
chapes, tiges, joins, corp, bouchon et même les chapes etc
Mer 24 Nov 2010 - 22:25
Ca marche tu en 1/16?
Mer 24 Nov 2010 - 23:03
je ne pense pas Sad
c'est fait pour les 1/8 et 1/10 a la base
Mer 24 Nov 2010 - 23:10
Zut!
Legnathead
Legnathead
Mer 24 Nov 2010 - 23:23
Oki, merci =)
