[Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Empty [Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies
Ven 8 Juil 2011 - 16:54
Vario Brushed 2s-6s TorqueMaster BR-XL
Programmable via Castle Link / Version WaterProof.
par Holmes Hobbies
[Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Holmeshobbies[Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Holmeshobbieswaterproof.th
This is the Holmes Hobbies Torque Master BR-XL Brushed ESC. Designed and manufactured in the U.S.A.! The TorqueMaster BR-XL is the hottest brushed motor ESC for rock crawling applications. With a 80 amp continuous rating and a huge input voltage rating of 28.8V, this ESC has been designed from the ground up to meet the rigorous demands of low speed control and high speed power giving even the most power hungry drivers what they want. A 5 amp, 6 volt on board switchmode BEC delivers unbelievable servo power at any input voltage.
The TorqueMaster arrives factory programmed with auto lipo LVC, full drag brake, instant reverse, and 100% reverse throttle settings. These settings can be easily altered with stick programming, and are fully computer programmable via Castle Creations Castle Link with instant firmware upgrades.
Spec.
-2s to 6s lipo input
-onboard 6v 5a switchmode BEC
-46x34x20mm
-38 grams (with battery wires)
-Brushed only
-80A continuous, no single 540 motor limit
-Super easy Stick programming
-Computer programmable via Castle Creations Castle Link with instant firmware upgrades!
-Reverse and brake adjustment
-Regenerative Drag Brake
-Active Hold Brake (The Holmes Hold!)
-Quiet mode
-1 year warranty for classique version.
-60 day warranty for Waterproof version.
Arrow Holmes Hobbies
Arrow Installe par Charly 76
[Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Userba10
[Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Empty Re: [Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies
Ven 8 Juil 2011 - 19:27
Le sidewinder. :siffle:
Ven 8 Juil 2011 - 19:35
J'ai ça...............pas encore essayé !!! :honte:
J'ai vu que ça ressemblait étrangement à un sidewinder ... mais , je n'ai pas trouvé de sidewindre qui acceptait le 6S pour le brushed scratch
Ven 8 Juil 2011 - 19:37
charly76 a écrit: je n'ai pas trouvé de sidewindre qui acceptait le 6S
Non le sidewinder de castle est pour 3S max.
Mais c'est le même boitier.
Nombre de messages : 559
http://www.la-belle-etape.com
Ven 8 Juil 2011 - 19:58
ils ont tous les meme fournisseur chinois Razz , donc commande grouper ca coute encore moin cher .
Victor01
Victor01
Nombre de messages : 793
Ven 8 Juil 2011 - 20:01
mais un sidewinder c'est pour brushless non ? :kes°:
en tout cas , ca doit être parfait avec un dewalt en 6s comme ca , ca fait une motorisation puissante et waterproof Wink
ps: dans le titre c'est marqué "contro" , c'est pas un contro mais un variateur Laughing
Ven 8 Juil 2011 - 20:08
Justement.......mon futur dewalt devrait ètre géré par ce vario ......
Je vous tiendrai au courant (dès que j'ai mon Dewalt)
Ven 8 Juil 2011 - 21:47
@Victor01
Exact dans ce cas-ci même si le Sidewinder à la base est un contro.
J'édite.
Mer 13 Juil 2011 - 17:47
@Charly76
Je ne t'ai pas demandé; Le tien est Waterproofé ?
Mer 13 Juil 2011 - 18:24
ça vaut ce que ça vaut..... mais je l'ai fait moi-mème
Mer 13 Juil 2011 - 20:39
Plasti-Dip je suppose.
Mer 13 Juil 2011 - 21:35
c'est ça.....
plasti dip tout autour et au pied des cables.....j'ai aussi fabriqué une pièce en alu pour le fixer à la place de l'EVX2.....
plus tard , j'aurai besoin de toi pour une formation castle link Wink
Jeu 14 Juil 2011 - 2:20
C'est très simple. Il y a le post de Bowie de plus qui est superbe.
C'est sûr la console a évolué (disposition/option) mais les termes sont restés les mêmes. Wink
N'hésite pas à poser tes questions et surtout à présenter tes paramètres vis-à-vis de ta config.
[Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Empty Holmes Hobbies
Mer 27 Juil 2011 - 8:31
@ Gonzo
Tu veux mon Holmes Hobbies pour le tester ?????
Moi , tu te doutes que je ne vais pas avoir beaucoup le temps de m'occuper de ça Wink
Mer 27 Juil 2011 - 21:49
Je vais déjà essayer, à mon tour, de brancher le TrackStar au DeWalt.
Sinon pourquoi pas, je te le rachèterais même !...Il me tente bien...Tu le mettras sur ma note.... Laughing
D'ailleurs, tu l'as ouvert pour le WaterProofer ?
Mer 27 Juil 2011 - 22:02
négatif.....
j'ai découvert la vidéo montrant ça après........... :honte:
en plus j'ai une bombe de plasti dip Cool
au fait....le dewalt est en chemin Wink
Mer 27 Juil 2011 - 22:20
J'ai fusionné cette discussion sur le post de la new du BR-XL.
Comment tu l'as Waterproofé alors ? scratch
Si tu as ton DeWalt qui arrive, garde ton BR-XL !
Si le TrackStar ne fonctionne pas, je pense que je vais m'en commander un WaterProofé à l'Epoxy.
Mer 27 Juil 2011 - 22:28
effectivement.......l'option à 10euros.... ça vaut le cout
je l'ai waterproofé succintement...de l'extèrieur......mais , je vai reprendre ça
PS : j'ai fabriqué une pièce pour le fixer sur le chassis du summit.... je vai faire une photo et j'édite mon message
[img][Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Br_xl_10[/img]
[img][Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Br_xl_11[/img]
[img][Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Br_xl_12[/img]
Jeu 28 Juil 2011 - 0:57
Excellent et avec deux fois rien... :sagesse:
Par contre, oui, là, il faut mieux que tu reWaterproof ton BR-XL. Very Happy
Jeu 28 Juil 2011 - 19:39
Voilà chef ..........c'est mieux comme ça ??? :honte:
[img][Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Br_xl_13[/img]
[img][Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Br_xl_14[/img]
[img][Old/New]Vario Brushed 6s TorqueMaster BR-XL Holmes Hobbies Br_xl_15[/img]
Jeu 28 Juil 2011 - 19:42
Yes!
Mais avant de remonter, vérifie que des trous ne se forment pas dans la pellicule de Plasti et enlève ce qu'il ya sur le radiateur Wink
Jeu 28 Juil 2011 - 20:57
le radiateur est intact..... c'est du scotche de peintre....
j'ai juste peur d'avoir du mal à le refermer..... on vera demain... Smile
Dim 31 Juil 2011 - 16:09
J'ai rajouté un lien vers le post de Charly76, sur la P1, pour ceux qui voudraient suivre l'installe et test ! pirat
