[New] Jantes Desperado 3.8" 1/2 et Zero OffSet par Pro-Line Empty [New] Jantes Desperado 3.8" 1/2 et Zero OffSet par Pro-Line
Mer 17 Aoû 2011 - 1:46
1/2 et Zero OffSet
par Pro-Line
[New] Jantes Desperado 3.8" 1/2 et Zero OffSet par Pro-Line Desperado38zerooffset
Features :
>Aggressive 6-spoke wheel design
>Molded in Bead-loc ring for scale look
>Works with all 3.8" Traxxas®️ Style Bead tires
>Zero offset wheel for your standard Monster Truck
Description :
This is a pair Desperado 3.8" (Traxxas®️ Style Bead) Black Zero Offset 17mm Wheels. Pro-Line’s highly anticipated new 6-spoke wheel will make your truck the toughest looking one on the block. The Desperado wheels are a one-piece glue wheel made out of extremely durable nylon material. The Desperado wheels feature a molded in bead-loc ring for an awesome scale look. This wheel will accept all Pro-Line 3.8" Traxxas®️ Style Bead tires along with all Stock Traxxas®️ 3.8" tires, giving you a ton of rubber options. This 17mm hex wheel, is sure to make your truck stand out from the rest, so get some today!
Arrow Lien Pro-Line
[New] Jantes Desperado 3.8" 1/2 et Zero OffSet par Pro-Line Desperado38demioffset
Features :
>½” offset wheel for all the Traxxas®️ Summit®️ fans
Description :
This is a pair Desperado 3.8" (Traxxas®️ Style Bead) Black ½” Offset 17mm Wheels. Pro-Line’s highly anticipated new 6-spoke wheel will make your truck the toughest looking one on the block. The Desperado wheels are a one-piece glue wheel made out of extremely durable nylon material. The Desperado wheels feature a molded in bead-loc ring for an awesome scale look. This wheel will accept all Pro-Line 3.8" Traxxas®️ Style Bead tires along with all Stock Traxxas®️ 3.8" tires, giving you a ton of rubber options. This 17mm hex wheel,is sure to make your truck stand out from the rest, so get some today!
Arrow Lien Pro-Line
[New] Jantes Desperado 3.8" 1/2 et Zero OffSet par Pro-Line Userba10
