[NEWS] Chargeur FMA Direct
+2
6 participants
Mar 26 Jan 2010 - 6:46
voila une nouveauté pour les BLiseurs
car tout le monde veut toujours plus puissant
Cliquez sur les photos pour aller sur le site
The Cellpro charger is designed to charge Cellpro and Cellpro Revolectrix battery packs directly. FMA currently sells adapters separately to interface with various manufacturer's battery packs up to 4s configurations. These adapters are used with the Cellpro 4s charger and may be used with the new 10s charger for packs up to 4s by connecting through the two 5S to 4S adapters that come standard with every Cellpro 10S charger
PowerLab 8 Specifications:
For Battery types: Lithium Polymer (1s to 8s balanced, 1s to 2s unbalanced), Lithium Ion (1s to 8s balanced, 1s to 2s unbalanced), Lithium Manganese (1s to 8s balanced, 1s to 2s unbalanced), A123 (LiFePO4) (1s to 8s balanced, 1s to 9s unbalanced), NiCd (1s to 21s), NiMH (1s to 21s), 6v, 12v, 24v Lead Acid batteries (Flooded, Gel, AGM, SLA)
Pack capacity: 20 mAh to 360Ah
Input voltage: 10-32VDC, reverse polarity protected
Input current: 1A to 50A, software limited
Output battery charge current: Adjustable range 10mA to 30A, limited by 50A input current*
Output battery discharge current: Internal discharge 10mA to 10A, 100W max
Regenerative discharge 10mA to 30A, 1000W max**
Continuous max output power: 516W @ +12VDC input, 1008W @ +24VDC
Cell balancing: Resolution 78uV (16 bit) for 1s-8s Li or A123 (LiFePO4) balanced charging
LCD: 2 line, 16 character, light grey/blue backlit
http://www.fmadirect.com/support_docs/item_1301.zip
Re: [NEWS] Chargeur FMA Direct
Mar 26 Jan 2010 - 9:49
Tout simplement énorme...50A !
Je ne trouve pas le prix du deuxième, tu aurais le lien direct sur le site, please.
Nombre de messages : 237
Mar 26 Jan 2010 - 17:18
Euk' !!
50A donc en gros on charge plus de pack dans l'heure que ce qu'on rouleras dans la journée
Mar 26 Jan 2010 - 17:36
humm pas sure je sera pres à parié que les 10 pack je les bouffe
5000ha en série qui fait 10amp ca va vite
Mar 26 Jan 2010 - 18:12
coool, on pourras charger a partir de batterie de camtar!!!
Mar 26 Jan 2010 - 18:58
j'ai rien trouvé non plus sur le siteChezoit a écrit:Tout simplement énorme...50A !
ca je le faisait déjànitrous a écrit:coool, on pourras charger a partir de batterie de camtar!!!
sur l'actros du beau pere qui avais 2x12v
sinon sur les tracteur agricole
Nombre de messages : 1124
Mar 26 Jan 2010 - 19:17
Oui, tracteur c'est 2x12V
30A de sortie maxi ... effectivement c'est énorme :shock par contre faut du 50A en entrée !
