[New] Chargeur Mega 200Wx2 par Turnigy Empty [New] Chargeur Mega 200Wx2 par Turnigy
Mar 21 Juin 2011 - 15:41
par Turnigy (Rebadgage du B6 Duo 2x200w)
[New] Chargeur Mega 200Wx2 par Turnigy Discharger400w
Tired of carrying two chargers to the field? Need serious charging power without the hassle of multiple chargers? Then the Turnigy Mega 200Wx2 is the charger you have been waiting for!
This charger features dual 200w outputs, that’s 400w of total charging power! Each output is independent and 2 JST-XH balance boards have been included for balancing Li-XX batteries. A temperature sensor has also been included for monitoring battery temperature during the charge process.
Just for something a little different a 5v/1A USB power output has been included, you can use this power output to charge phones or power any USB compatible device.
Spec.
Charging Output: 2 x 200w (400w Total)
Input voltage: 12~18v DC (500 Watt minimum)
Charge Current Range: 0.1~10.0A
Discharge Current: 0.1~5.0A
Discharge power: 25watt
Balance Current Drain: 200mAh/cell
Li-XX Cell Count: 1~6s
Ni-XX Cell Count: 1~18s
Pb battery voltage: 2~24v
Battery setup memories: 10
Intelligent temp control: Yes
PC Link: Mini USB
Cooling: Dual Fan
USB Power supply: 5v/1A
Weight: 900g
Dimensions: 195x125x54mm
Includes.
2 x JST-XH Balance boards
Temp Sensor
1 x Alligator clip charge lead
2 x 4mm Bullet connector pig tails (Custom fit your own connectors)
Arrow Lien HK
[New] Chargeur Mega 200Wx2 par Turnigy Userba10
