[NEW] Chargeur Turnigy Power Systems (4x6S)
Sam 24 Avr 2010 - 12:40
Jusqu'à 4 x 6S en lipo et 6A par port !
Chargeur Power Systems
par Turnigy
Turnigy 4x6S can charge four batteries packs simultaneously!
A quality designed charger with accurate balancing and a familiar,
intuitive menu system.
The Turnigy 4x6 is equipped with 4 high accuracy microprocessors
to charge each battery individually. Its efficient cooling system
ensures safe operation throughout the charge cycle.
With the Turnigy 4x6 you are able to balance charge a lipoly pack
on Port-1 while series charging a LiFePo4 or NiMH battery on Port-2.
All ports work independently of each other.
Specification:
Operating voltage range: DC 11~15V
Power source: 12V DC (car battery) / AC mains PSU (>200Watts)
Cell count : 1-15 Ni-xx / 1-6 Li-xx / 1-10 Lead acid cells (2~20V)
Current drain for balancing li-xx: 335mA
Charge termination Ni-xx: Automatic, negative Delta Peak method
Charge termination Lead acid & Li-xx: Automatic, voltage dependent, CC-CV process
Maximum Charge Current per port: 6A
Including;
1 x TQ4 charger
1 x JST XH Adapter
1 x TP/FP Adapter
1 x Banana plug w/ Male Tamiya
1 x Banana plug w/ Female Mini JST
1 x Banana plug w/ Female Futaba
1 x Banana plug w/ Aligator clip
1 x Banana plug w/ Losen wires
1 pair Aligator clip
Note: Power supply not included.
All accessories shown in image are included.
Lien HobbyKing
Re: [NEW] Chargeur Turnigy Power Systems (4x6S)
Sam 24 Avr 2010 - 17:03
6A c'est mieux l'autre faisait que 2.5A
encore un peut et on aura des 10A
je sent que mon projet va finir BL
Lun 26 Avr 2010 - 11:24
Il est en stock et il y en a 10 ! N'oubliez pas de prendre une alim de taille.
EDIT.
J'ai retiré le lien de l'alim 25A de chez HobbyKing. Merci Vrille.
EDIT.
Mar 27 Avr 2010 - 13:49
La suite de la question alimentation ICI
Mer 5 Mai 2010 - 1:57
j'ai trouvé ca
donc
4.4A par ports sur 4accus de 3S
en gros pas si génial que ca ....
a méditer ...
il m'intéresse beaucoup moins maintenant
le chargeur est donnée pour 200W
un lipo 6S a une charge de 6A, au max du chargeur
P=UxI donc 22.2x6=133.2W
donc il demande une sortie capable de délivrer 135W par sorties
hors le chargeur est donnée pour 200W, donc juste assez pour marger 1 seul 6S en comprenant les pertes
donc a vérifier de très prêt
si je trouve plus d'info je poste
Essayé le mien pour la première fois hier. Charged up 4 Turnigy 3S 5000 packs all at the same time. Chargé en hausse de 4 Turnigy 3S 5000 réunit toutes en même temps. Set all to 6A per port. Mettez tous les 6A par port. Bottom line is, It can only provide 4.4 amps per port at 13.8 volts. En fin de compte, il ne peut fournir 4,4 ampères par port à 13,8 volts. A little pokey for large packs, better than charging one at a time, internal fan is super loud. Un peu de taule de gros emballages, mieux que la charge un à la fois, le ventilateur interne est super fort. A good end of the day charger.
donc
a méditer ...
Mer 5 Mai 2010 - 2:13
La question est : Qu'est ce qu'il avait comme chargeur ?
Mer 5 Mai 2010 - 2:14
Et comme alim ...
Mer 5 Mai 2010 - 2:24
ben le chargeur ... chezoit .... si je post sur ce post c'est qu'il avais ce chargeur
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=11170&Product_Name=Turnigy_4x6S_Lithium_Polymer_Battery_Pack_Charger#
dans les reviews en bas
pour l'alim
si on lui en demande trop en général elle se met a en sécurité, ca m'est déjà arrivé et elle coupe tout
je pense qu'il l'aurais précisé
la il a demandé a son chargeur
11.1x6 donc 66.6W
et le chargeur lui a délivré
11.1x4.4 donc 48.84W par sorties
donc 48.84x4 = 195.36w
donc on est dans les 200W admissible par le chargeur ....
on est dans les caractéristiques du chargeur
en 6S il chargerais dans les 2.5A env sur les 4 sorties
c'est comme celui ci
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=10327
plus tu lui demande moins il donne
2S=5A, 3S=4.3A, 4S=3.3A, 5S=2.6A, 6S=2.2A
citation reviews
pour l'alim
11.1x6 donc 66.6W
citation reviews
Je n'ai accusé lipos avec elle, mais jusqu'à présent il fonctionne très bien. En réalité, la charge maximale LiPo courants (par port) sera d'environ: 2S = 5A, 3S = 4.3A, 3.3A = 4S, 5S = 2.6A, 6S = 2.2A qui fonctionne très bien pour la taille lipos que j'ai. Si vous avez les plus grands il faudra plus que la normale qui est d'environ 1 heure 45 minutes-en fonction si vous obéir à la règle de décharge de 80%.
Mer 5 Mai 2010 - 15:24
@Vrille
Alim je voulais dire...j'ai dû mal en ce moment.
@Gilou
Tu le sais bien que je voulais dire alim, on en avait discuter par MSN !
Pour revenir au sujet.
Combien son chargeur sort en ampérage ?
D'ou ce post que j'ai séparer pour discuter de ce point.
@Gilou
Mer 5 Mai 2010 - 16:11
son chargeur ou son alim ???
je viens de le dire au dessus
il lui demande de charger 4 accus 3S a 6A et le chargeur les chargent a 4.4A
Mer 5 Mai 2010 - 16:34
Demande lui la ref de son Alim. Je pense que le problème vient de là.
Mer 5 Mai 2010 - 17:07
une alim en sur charge coupe, je l'ai dit plus haut
tu lui tire plus que la normale et ca coupe car elle encaisse pas
réponse d'un autre acheteur
et la réponse d'un autre
et des réponses de d'autres membres valident que c'est un imaxB6 qui a était monté en x4
donc le ImaxB6 fait 50W donc 200W total ....
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=5548
Vraiment l'aspect de celle-ci, mais si chaque port peut faire jusqu'à 6A, une batterie 6s faudrait 133watts @ 1C (taux de charge idéale), cela signifie la production totale doit être 532watts! de charger 4 batterys grande à la fois ... À 200 watts, ce qui est similaire compter que le Quattro HK à l'exception du fait qu'il apparaît de sortie à chaque port est variable. Toute chance de 400watt disponibles dès HK?
Exactement le même menu et les fonctions que Accucel 6 (50W). Le ventilateur de refroidissement est terriblement bruyant en raison de mur en plastique couvrant le ventilateur. Ne pas oublier de commander 3 tableaux ballancing et de tarification bouchons (un seul par type est inclus comme mentionné dans la description)
Mer 5 Mai 2010 - 18:52
Oui...on l'a compris.
Sinon c'est quel modèle son alim ?
Mer 5 Mai 2010 - 19:46
demande lui
mais quel que soit l'alim ca sera le même résultât, 50W par sorties
j'ai regardé sur gogol et j'ai les mêmes réponses quand a la qualité de ce chargeur
Mer 5 Mai 2010 - 23:36
mêmes résultats que l'autre avec une 300W
a regarder dans les discutions pour le lire au complet en anglais
une autre
Si c'est ce qu'il dit (carte) ...
4x6S chargeur équilibre (4 chargeur équilibre port) avec
max 50 Watt chaque port et max 6 ampères chacun port.
Ensemble, 200W et 24A à pleine charge de tous les 4 ports
en même temps (simultanément).
Quelques temps de charge par exemple:
4x 2S Lipo 2200mAh - 6.0A max> = 20 ~ 25 min
3S Lipo 2200mAh 4x - 4.5A max> = 30 ~ 35 min
4x 4S Lipo 2200mAh - 3.4A max> = 40 ~ 45 min
4x 5S Lipo 2200mAh - 2.7A max> = 50 ~ 55 min
4x 6S Lipo 2200mAh - 2.2A max> = 60 ~ 70 min
Peu importe si vous utilisez le port 1 ou tous les 4 ports ensemble. Le temps de charge est la même (si
vous branchez le batterys même). Bien sûr, vous pouvez également mélanger les différents packs sur les ports-> différents
temps de charge.
Si vous voulez savoir combien de temps cela prend pour charger
batterys avec capacitys autres:
Exemple 1. 6S 5000mAh Lipo:
5000mAh diviser par 2200mAh = 2,27 (voir exemple ci-dessus pour 6S). Multiplier par 2,3 70min = 159min
Exemple 2: 3S Lipo 3600mAh:
3600mAh 2200mAh = diviser par 1,64 (voir ci-dessus pour 3S). Multiplier par 1,64 = 35min 57min. et ainsi de suite ...
Remarque: l'écran de la photo montre "et 6.0A
22.2V (6S) ", mais il n'ya pas de prise de batterie à l'intérieur et personne ne poussez le bouton de démarrage ....( lol). Qu'elle
montrerait (environ) et 2.2A 22.2V (6S).
Quoi qu'il en soit, ce chargeur est un bon choix, vous obtenez 4 chargeurs pour le prix d'Allemagne two.In je dois payer 150 € pour ce bébé plus port.
Décharge: Je ne sais pas. peut-être 5 à 6 Watt
Semble plus petit par rapport à la Quattro HK, peut-être de 180mm x 160mm.
Alimentation AC: 11 ~ 15Volt.If vous voulez être sur la sécurité du site pour trouver un appareil capable de gérer
300W et 30A, parce que les pièces électriques sont grands
pertes (effectivité). Vous trouverez ici de HK.
J'espère que cela a été un peu utile.
HK s'il vous plaît me corriger en cas d'erreur de GI et d'afficher les vraies espèces. Désolé pour les fautes ...
salue à tous ...
une autre
Spec doit indiquer:
1.
Puissance admissible par port = .. Watts
2.
Peut-être tous les ports utilisés à leur puissance maximale en même temps?
4 ports * 6S * 6A = 600Watts>. Vous et moi savons que ce chargeur ne peut pas gérer que ....
Je pense 60W max par port. Ai-je raison?
- Les fous du volantsRevoiste Padawaaa super motivé
- Nombre de messages : 110
Jeu 7 Oct 2010 - 21:26
Comme je ne m'y connais pas trop, est ce qu'avec ce chargeur, je peux charger 3 ou 4 lipo 4S, 5000mah en même temps sans problème
Si je met par exemple 3 lipos, en charge de 5A est ce possible?
Car j'ai 6 lipos à charger j'aimerais savoir si je peux les charger en 2 fois (2series de 3) en 1 heure environ chaque serie
Jeu 7 Oct 2010 - 23:37
Gilou a écrit:......
Ce n'est pas top pour les 4 sorties.
Prends plutôt un Duo, tu auras des meilleurs résultats.
Si tu veux poser plus de questions, post ici.
