[NEW] Chargeur Turnigy MEGA 400W 20.0A Empty [NEW] Chargeur Turnigy MEGA 400W 20.0A
Lun 3 Mai 2010 - 23:39
Je sens qu'on va voir du big Rebadgage prochainement... Rolling Eyes
MEGA 400W 20.0A
par TURNIGY
[NEW] Chargeur Turnigy MEGA 400W 20.0A Mega4010
[NEW] Chargeur Turnigy MEGA 400W 20.0A Mega4011[NEW] Chargeur Turnigy MEGA 400W 20.0A Mega4012
Are you ready to charge your packs faster than ever before or are you
looking to take advantage of the new high C charge rate on the new Zippy
and Turnigy battery packs?
The touch sensitive Turnigy Mega 400W is a high power balancing
charger/discharger which can handle up to 6 cells/20A, LiPo/LiFe to 6S and
NiMH/NiCd up to 18S accurately. Bundled with the Turnigy Mega 400W is an
array of charging wires and plugs, suitable for most applications.
Features;
Microprocessor controlled
Delta-peak sensitivity (NiMH/NiCd)
Individual cell balancing charge & discharge
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
High-power and high-performance circuit
Store function, allows safe storage current
Data storage (Store up to 10 packs in memory)
Cyclic charging/discharging
Spec.
Input voltage: 11.0 – 18.0Volt
Charge current: 0.1 – 20.0A
Discharge current: 0.1 – 5.0A
Maximum charge capacity: 400W @ input voltage >15V
Maximum discharge capacity: 25W
Current drain for balancing Li-po: 200mAh/cell
Lithium (LiPo/LiIo/LiFe) battery cell count: 1 – 6 series
NiCd/NiMH battery cell count: 1 – 18 series
Pb battery voltage: 2 –24V
Battery setup memories: 10
Intelligent temperature control: Yes
Weight: 820g
Dimensions : 152X145X57mm
Including;
1 x Turnigy Mega 400W charger
1 x JST XH Adapter
1 x Banana plug w/ Female Mini JST
1 x Banana plug w/ Female Futaba
1 x Banana plug w/ Aligator clip
1 x Banana plug w/ Losen wires
1 pair Aligator clip
This charger has a JST-XH charge plug, which makes it compatible
with Zippy, HXT,TURNIGY and any pack with a JST adapter.
Note: Power supply not included.
Arrow Lien Hobby King
[NEW] Chargeur Turnigy MEGA 400W 20.0A Userba10
[NEW] Chargeur Turnigy MEGA 400W 20.0A Empty Re: [NEW] Chargeur Turnigy MEGA 400W 20.0A
Jeu 20 Mai 2010 - 17:22
voila les retours sur le chargeur, toujours dans les commentaires que l'on peut lire en bas de page
Vous avez mon chargeur aujourd'hui. Je l'ai branché et a commencé à l'équilibre de charge un LiPo 3s5000ma juste au-dessus 3 ampères. Tout à coup, après au bout deux minutes, le chargeur "explosé" avec un "big bang", et certains types de fibres volaient autour de lui ...
Le chargement d'une batterie 6S 3300mAh Turnigy à 1C (3.3A) le chargeur fonctionne bien, l'équilibre parfait, mais il ne l'odeur un peu chaud. Essayé la batterie prochain à 2C (6.6a) à partir d'un approvisionnement 25A/12V, et après 20 minutes, le chargeur est mort.
Plus de détails à l'adresse:
http://www.helifreak.com/showpost.php?p=2042263&postcount=7
WTF!
Brûlés immédiatement. A écrit un commentaire ici et HOBBYCITY éliminé, le.........
et ce ne sont pas les seuls
la plus part ont des odeurs de brulé ou ne chargent pas a plus de 1c ...
donc attention, a éviter pour le moment
Jeu 20 Mai 2010 - 17:46
Shocked :S
Jeu 20 Mai 2010 - 18:30
Ce n'est pas la première fois, cette marque ne m'inspire pas confiance.
Même si c'est fait par de chinois, le prix des composants de bonne qualité ne doivent pas varier beaucoup. Alors pour arriver à tirer des prix au raz des paquerettes comme ils le font, ça ne doit pas être méga top à l'intérieur.
Quand tu vois que sur leur big chargeur à 4 sorties, il y a des pièces qui se baladent à l'intérieur, des vis dévissées etc, la qualité n'est pas au rendez-vous.
Il vaut mieux mettre un peu plus cher et avoir confiance dans son matos et qu'il soit de bonne facture!
Enfin ceci n'est que mon avis Neutral
Jeu 20 Mai 2010 - 18:33
c'est les alims qui ont les visses qui se baladent
les 4 sorties font 50w par sorties donc chargent pas assez fort
mais au moins ils explosent pas Laughing
Jeu 20 Mai 2010 - 18:40
Razz
Ouai ben c'est pas mieux! :cowboy:
Faut le faire quand même, imagines que tu aies ta main dessus à ce moment là pour vérifier ta charge de lipo .... plus de main
:siffle:
Invité
Invité
Jeu 20 Mai 2010 - 20:47
si je peux me permettre tous les chargeurs sont fabriqués aux mêmes endroits pour tous les fabricants et ont pratiquement les mêmes qualités de composants à l'intérieur par catégorie
ce qui change ce n'est que l'habillage. Donc mettre plus cher ne veux pas dire une meilleur qualité il suffit de prendre en exemple les cartes mémoires l'ensemble est le même par capacité il n'y a que l'étiquette qui change.
qui peux mettre 250€ dans une alim et 400€ dans le chargeur ?
Jeu 20 Mai 2010 - 21:32
le jours ou un robbe ou un graupner aura la qualité des turnigy il faudra s'inquiéter, j'arrêterais l'électrique car sinon je ferais cramer la baraque
une partie de ce que l'on a est peut être fabriqué dans les mêmes usines
mais la qualité des composants est largement autre chose Rolling Eyes
le jours ou tu trouvera un infinity 3 ou 4 chez HK tu me fera signe Rolling Eyes
Invité
Invité
Jeu 20 Mai 2010 - 23:23
car tu pense qu'a HK on ne trouve que du bas de gamme (voir l'origine de certain téléviseur haut de gamme de marque européenne). Effectivement il y a plusieurs qualités pour le même composant c'est pour cela qu'il existe des cahiers des charges pour les fabricants imposés par les constructeurs. tu parle d'infinity 3 ou 4 mais des chargeurs à 250 € ou 400 pour robbe c'est normal d'y trouver des composants au moins au 1/10 voir moindre et pour graupner et robbe d'où vient ses entrées de gamme si ce n'est pas de l'asie c'est de l'est donc bonnet blanc-blanc bonnet
fin du HS Laughing
Ven 21 Mai 2010 - 0:06
@Rboi3639
Tu n'as jamais gouté au Robbe Infinity III, sinon tu t'en souviendrais ! Very Happy
Plus sérieusement, comme la très bien dit Gilou : "Une partie de ce que l'on a est peut être fabriqué dans les mêmes usines mais la qualité des composants est largement autre chose Rolling Eyes "
Sinon niveau rebadgage, c'est surtout la spécialité des IMAX surtout.
Invité
Invité
Ven 21 Mai 2010 - 9:32
@Chezoit et Gilou depuis 1978 je n'étais que thermique donc pas la nécessité d’avoir des chargeurs hyper performants.
Avec la difficulté de pratiquer le thermique toutes discipline confondues dû aux interdictions au nom de l’environnement et suite à différentes lectures de post (merci revopowaaa) je me suis mis en début d’année à l’électrique avec le Mini et aux lipos. Préfèrent aux chargeurs haut de gamme des options sur mon Mini je n’ai pas mis trop cher dans mes chargeurs (iMax B6-TC1030 et Turnigy 80W (2)) et en plus achat à l’étranger par économies en suivant vos conseils. Donc j’ai peut être acheté des produits classés à 15 voir 25 % de défauts et une qualité moindre en composants c’est sur, mais je l’ai fais en étant conscient et maintenant je ne viendrais pas cracher dans la soupe en me plaignant que c’est de la daube.
La vie est une succession de choix à chacun les siens d’après ses possibilités et ses moyens
:cowboy:
Ven 21 Mai 2010 - 11:17
Ce n'est pas histoire de cracher dans la soupe, mais comme tu viens de le dire il y a plusieurs niveaux de composants. Même si c'est fait dans la même usine, ça tout le monde le sait (rapport aux TV)
Maintenant, je n'ai pas non plus un budget phénoménal à dépenser, mais quand il s'agit de lipo, j'essaie de faire attention. Déjà que ce sont des batteries plus "instables" et quand j'entends des chargeurs exploser, des odeurs de brûlé et des alim dans lesquelles il y a des courts-circuit, ça n'inspire pas confiance.
Les imax ont des problèmes apparemment de balance..., après ça reste un bon petit chargeur pas cher du tout, quand tu peux le trouver à 30 euros fdpin sur ebay, ça donne envie!! J'ai même pensé en prendre un et de finir la balance avec mon premier chargeur.
Pas la peine de se prendre la tête donc, tout le monde pense pareil.
Ensuite voilà, tu le fais en connaissance de cause.
:nickelcool:
Invité
Invité
Ven 21 Mai 2010 - 12:10
il y a peut être un minimum de précautions à prendre lors des charges d'accus. pour moi je mets il y a peut être un mini de précautions à prendre lors des charges genre mettre des ventilateurs d’ancienne unité centrale (PC) en fonctionnement en même temps que l’alim et le(s) chargeur(s) ce que je fais
- un très gros qui pulse de l’air frais sur les accus
- un autre de taille moyenne qui extrait l’air chaud des accus
- le troisième identique au second réservé à l’extraction de l’air chaud des chargeurs
Quand la température extérieure est très chaude j’ai des pochettes souples jetables remplies de gel prévues pour aller au congélateur que j’ai récupérées auprès d’hôpitaux et qui servent au transport de certains médicaments ou au transport de sang
Pour l’instant pas de problèmes que cela dure silent
Ven 21 Mai 2010 - 16:39
rboi3639 a écrit:Préfèrent aux chargeurs haut de gamme des options sur mon Mini je n’ai pas mis trop cher dans mes chargeurs (iMax B6-TC1030 et Turnigy 80W (2)) et en plus achat à l’étranger par économies en suivant vos conseils.
tu n'est pas obligé de les suivre
et perso je recommande pas les chargeurs chinois, j'en ai jamais eu
la preuve flo65 voulais en prendre et je lui ai fait prendre des graupner il y a 2 ans
les lipo ont jamais était plus dangereux que les nicd ou nimh
le nimh si c'est mal utilisé, ça explose aussi et beaucoup plus violemment et avec plus de dégâts
la seule différence, c'est que depuis le les lipo sont sortie, plus de monde fait de l'électrique
avant c'etait réservé a une élite qui avais envie de se prendre la tête avec 50 pack pour rouler 20minutes
et avoir 10kg d'accus a transporter partout
et long a charger
et ou les chargeurs coutais un bras de plus de 150euros
MAIS CE N'EST PAS LE SUJET, la on parle d'un chargeur qui ne marche pas et deviens dangereux a l'utilisation
pas besoin de le défendre, il a fait sa B A
Ven 21 Mai 2010 - 19:16
Doucement doucement mon Gilou...Je crois que tout le monde à compris ! Very Happy
Ps. 3PK c'est pas terrible...M11 c'est beaucoup mieux...
Invité
Invité
Ven 21 Mai 2010 - 19:23
OK je retire mes billes et vous souhaites longue vie
cordialement
