Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) Empty Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8)
Sam 15 Jan 2011 - 18:03
Moteur Contro Carte TrackStar pour 1/8
par Turnigy (Rebadgage Esc Toro 8 / Moteur / Carte SkyRC)
Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) Bannireattention
Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) 150axMoteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) 150a2.th
The Turnigy TrackStar 1/8th scale 150amp car ESC is the latest addition to Hobby Kings Car ESC range.
Using a Fast Silicon Labs MCU and high quality On-Semiconductor MOSFETs the TrackStar 150A ESC sets a new standard in high quality yet affordable car ESCs. With Intelligent MCU logic the TrackStar series ESCs allow extremely precise start up control and positioning feed back from the motor. This translates in to very smooth start up and acceleration.
The Turnigy TrackStar 150A ESC also boasts a host of programing options not usually found in a 1/8th scale ESC at this price and can be programmed with ease via the Turnigy TrackStar programing card (sold separately) The Turnigy TrackStar 150A ESC also included 3 x 10AWG Motor wires and 2 x 10AWG power input wires.
Specification:
Cont. Current: 150A
Burst Current: 250A
Car Size: 1/8th
Battery: 2-6 Cell Lipo
S-BEC: 5.7V / 3A Output
Motor Type: Sensorless Brushless
Size: 48.8 x 57.8 x 35.8mm
Weight: 88g
Battery Plug: Required
On/Off Switch: Yes
Reverse: Yes
Thermal Overload Protection: Yes
Battery Terminals: 10AWG size
Motor Terminals: 10AWG size
Données SkyRC
Specification:
# Controls : Fwd/Brk or Fwd/Brk/Rev
# Input Power(Cells): 2-6S LiPO
# Motor limits, TORO 8: Brushless KV ≤ 2400: Up to 6S (25.2 Volt), for 1/8 monster trucks and truggies
# Motor limits, TORO 8: Brushless KV ≥ 2400: Up to 4S (16.8 Volt), ideal for 1/8 buggies
# On resistance, brushless: 0.0002 Ohms per phase at 25°C (77°F) Trans. Temp.
# Continuous / Burst Current: 150Amp / 950Amp
# Switching BEC: 5.7 Volts, 3 Amp
# Status LED: 1 with 3 color (Red, Green & Orange)
# Thermal overload protection: Yes
# Dimension: 48.8*57.8*35.8mm (1.29*2.28*1.41in)
# Weight (without wires): 88g (3.1oz)
Arrow Lien HB / Contro
Arrow Lien A / B (Original) / C.
Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) 40682560Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) 406825602.th
[b]Specification:
Kv: 2560 > EXISTE AUSSI EN 2160 KV (non rebadgé pour l'instant)
Poles: 6
Max Amps: 120A
Max Volts: 21v
Max Watts: 2200w
Idle Current: 5.0A
Resistance (Ri): 5.8
Shaft size: 5mm
Arrow Lien HB / Moteur
Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) Ttsprog
Programming Options :
Voltage Cut off
Drag Brake
Brake Strength
Punch Control
Reverse type
Motor Timing
Arrow Lien HB / Carte
Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) Userba10
Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) Empty Re: Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8)
Sam 15 Jan 2011 - 20:17
De loin on aurait dit du Tekin :siffle:
Sam 15 Jan 2011 - 21:04
C'est le radiateur rouge et le dessus du support ventilateur qui rappelle le RX8.
En tout cas, on ne pourra plus dire que les combo 1/8 sont hors de prix surtout avec la politique des prix pratiqué chez HB.
djimbow
djimbow
Nombre de messages : 145
Dim 16 Jan 2011 - 7:45
En effet mais à voir l'utilisation à long terme... Car vu le prix vraiment très bas, il doit y avoir des raisons.
Dim 16 Jan 2011 - 14:57
Je l'ai commandé vu qu'il me manquer un ESC 1/8 mais je ne pourrais pas le tester avant Mars... :S
Je pourrais déjà vous donner mes premières impressions sur le contenue & finition.
Sinon, on peut voir qu'il y a une sortie USB....Possibilité de paramétrer via ordi ?
Dim 16 Jan 2011 - 15:31
Bonjour Chezoit,
Un jours... je prévois passer au buggy 1/8 (RC8Be) ou SC 1/10(Slash 4x4). Peut-être un E-Revo.
J'aimerais bien en trouver un sans électro....
Lorsque tu le recevras peux-tu nous informer si la "program box" d'Hobbywing est compatible avec cet ESC.
Il semble super intéressant, pour le prix.
Dim 16 Jan 2011 - 20:15
J'ai mis les liens HB.
Vu que c'est du Rebadgage SkyRC (société des chargeurs Imax B6/B8/etc) je ne pense pas que la Program Box de chez HobbyWing...a moins que ça soit une filiale !? Sinon comme je l'ai noté; on peut voir que la carte de programmation a une entrée USB et donc surement peut-être (I Hope), un paramétrage via Ordi.
Le mien sera monté sur un B-Slayer avec moteur Lehner 1950 7 - 1791Kv en 6s
Et comme SkyRc préconise :
C'est parfait pour mon utilisation/Combo.
Je ferais déjà un topo complet sur le Pack et la finition dès que je le recevrais.
Victor01
Victor01
Nombre de messages : 793
Dim 16 Jan 2011 - 20:45
djimbow a écrit:En effet mais à voir l'utilisation à long terme... Car vu le prix vraiment très bas, il doit y avoir des raisons.
c'est normal sur hobby king c'est vraiment pas chère regarde ces batteries : http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=8587&Product_Name=ZIPPY_Flightmax_5000mAh_3S1P_30C_ . Elles ne font que 53€ les 2 . normalement des batteries avec les memes caracteristiques coutent + de 110€ l'une . et pourtant elles sont de bonne qualité, c'est celles que j'ai et je n'ai jamais eu de problemes avec.
pareil avec le IMAX B6 : http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=5548&Product_Name=IMAX_B6_Charger/Discharger_1-6_Cells . il ne fait que 18 € alors que dans les autres mag il fait + de 80€ : http://www.miniplanes.fr/batteries-chargeurs/chargeurs/imax-b6-chargeur-digital-balanceur-16s-p-17417.html
et pareil avec le IMAX B8
hobby king est le site le moins chère à ma connaissance
a Chezoit
il est donc plus puissant que le MMM car il fait 150A et le MMM fait 125A
Dim 16 Jan 2011 - 22:17
Personnellement, je peux pas trop parler du MMM, les informations lui concernant reste très flou pour moi.
Il est donné 120A mais certains (forum us) lui donne 125-130A voir + en continu...
Concernant le SkyRC Rebadgé Turnigy, là c'est autre chose, il est trop récent et donc pas assez de retour pour dire s'il est vraiment fiable.
Victor01
Victor01
Ven 21 Jan 2011 - 17:19
Ven 21 Jan 2011 - 19:48
Je n'avais pas vu le contro de Hobby King.
1080A en Burst....pffiouuu. Shocked
Sensorless et sensored.
Même la programmation avec la carte est un petit peu plus poussé.
Et les retours ont l'air bon.
En tout cas sur le papier, il est mieux que le TrackStar.
Post-le [Old New] que je le mette sur le portail. Wink
(tu peux le créer dans "tout et rien" et je le déplacerais)
Victor01
Victor01
Sam 22 Jan 2011 - 12:55
ok je vais le poster
en fait j'ai pas compris c'est quoi 1080Aen brust
Edit : c'est bon je vient de le poster
et j'ai trouvé ca aussi, ca a l'air pas mal et le contro a les memes caracteristiques (150A/1080A sensored et sensorless) et le moteur est un 2350 kv mais il fait seulement 76A : http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=9127
Sam 22 Jan 2011 - 17:31
Jeff4x4
Jeff4x4
Nombre de messages : 253
Mer 26 Jan 2011 - 20:31
un de mes ami l'a commander le TTS-150A/14635 Turnigy TrackStar .
des qu'il la ressu, c moi qui doit lui monter sur son E-maxx avec moteur novak 4.5t car il ne c pas le faire.
je vous tien au courent de se que sa donne.
mais si tu regarde bien le descriptif en bas de pages il l'annonce a [150amp continuous] [to 950amp burst]
vu qu'il y a une prise USB sur la carte il dois y avoir un logiciel de programation pour le PC, reste a le trouvé.
Mer 26 Jan 2011 - 22:42
SkyRC lui donne 950A en Burst mais HobbyKing à l'air prudent et note 250A.
Je devrais recevoir le contro et la carte bientôt, je te dirais s'il y a un soft de linkage ...(I Hope..)
Jeu 27 Jan 2011 - 0:22
Chezoit a écrit:SkyRC lui donne 950A en Burst mais HobbyKing à l'air prudent est note 250A...
Lorsqu'on parle de "Burst", il faut connaître le durée de celui-ci ? 0.0001sec à 950A ou 5sec à 250A ? Wink
Jeu 27 Jan 2011 - 0:27
Exact ! Jolie ! :sagesse:
Mer 2 Fév 2011 - 1:00
Reçu hier.
Alors pour le contro.
Il vient avec un petit manuel en anglais...of course...très simple. D'ailleurs, on peut y lire qu'il est compatible Brushed mais il faut respecter une install.
Vu d'extérieur, il vraiment pas mal, esthétiquement même très classe, un peu comme le RX8.
Juste un peu large.
Pour la carte de programmation.
Petite explication à l'arrière du packaging; comment le connecter et son fonctionnement.
Et ce que tout le monde veut savoir : Eh non, il n'y a pas de logiciel pour faire Office de Link comme le Link de chez Castle ou le HotWire de chez Tekin.
Première impression, Finition très propre.
Jeu 3 Fév 2011 - 2:40
savage69
savage69
Nombre de messages : 215
Jeu 3 Fév 2011 - 11:56
Salut !
J'ai cramé mon MMMv3 il y a 1 mois et j'hésite a prendre se contro qui semble pas mal du tout ! J'attend tes retours avec impatience Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) 36875
Jeu 3 Fév 2011 - 12:07
Mieux vaut attendre les retours de Jeff4x4 car personnellement je ne pourrais pas en donner avant mi Mars...(Déménagement oblige)... :S
Sinon les retours ont l'air bon.
Après tu peux toujours attendre la sortie du Toro 1/8 Sensor. Very Happy
Juste par curiosité, comment as-tu cramé ton MMMv3 ?
savage69
savage69
Jeu 3 Fév 2011 - 12:26
En fait je ne l'est pas vraiment cramé ! Mais le résultat est le même ! Je l'est démonter pour le rendre étanche; et y est mis du plasti dip !Le problème est que j'ai pendu avec les petites fils qui vont au récepteur ! Bilant il se sont dénudé et avait des faux contact ! J'ai essayer de les ressouder et deux petit morceau du circuit se sont enlever ! Je l'est filer a un pote qui a sont père qui est électronicien et mas dit que sa n'était pas réparable voila Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) 05072301
Jeu 3 Fév 2011 - 20:59
:S
Ven 4 Fév 2011 - 0:34
savage69 a écrit:... il se sont dénudé et avait des faux contact ! J'ai essayer de les ressouder et deux petit morceau du circuit se sont enlever ! ... que sa n'était pas réparable voila Moteur Contro Carte TrackStar 1/8 par Turnigy (Toro 8) 05072301
As-tu des photos de "ce qui n'est pas réparable" ? Parce que d'après ta description, ça semble réparable ?
Peut-être auront nous des idées à te suggérer.
J'ai travaillé, il y a quelques années, dans la conception de circuit électronique (design et PCB), disons qu'il y a certains protos et "retour de client" qui y ont goutés et ont dû être réparé et modifier à plusieurs reprise...
Bonne chance et A+
Mar 15 Fév 2011 - 10:30
@Jeff4x4
Vous avez pu le tester ?
