[NEW]Chargeur/Déchargeur/Equalizer Hybrid Pro par Much More
Mer 18 Jan 2012 - 21:37
par Much More
Features
- All in one design
- Microprocessor controlled
- 2 kinds of charge cutoff system : Peak cut(Lithium Voltcut), temperature cut
- Blue back light LCD display with 16×2 characters
- 10A charging and 5A discharging with high capacity LiPo,LiFe batteries
- Individual voltage balancer for Lithium batteries inside
- Real time individual voltage monitoring (charging and discharging for Lithium batteries)
- Normal , Storage, Balance charge mode for Lithium batteries
- Delta-peak sensitivity(NiMh, NiCd)
- Time limit function
- Input voltage monitoring
- Data storage(store up to 5 packs in memory)
- Micro temp sensor
Specifications
Dimensions: 142 x 119 x 141mm
Weight: 1300g
NiCd, NiMh No. of cells: 1~18
LiPo, LiFe, Lilo No. of cells: 1~6
Pb Battery voltage: 2~24V
Charge current: 0.1~10.0A(adjustable) *Max 200Watt
Discharge current: 0.1~5.0A(adjustable) *Max 25Watt
DC Input: 11.0-18.0V
AC Input voltage: AC100-240ACV 50~60Hz (Auto adjusting)
Charging Capability: 0~9990mAh
Charging Modes: NiMh, NiCd, LiPo, LiFe, Lilo, Pb
Voltage Threshold/Delta Peak: Default・5~20mV/cell
Thermometer sensor: 20~80 Degrees celsius
Data store: 5 data of batteries
Keys: 4 button
LCD monitor: 16x2lines Blue LCD display
Much More
par Much More
Features
- All in one design
- Micro temp sensor
Specifications
Weight: 1300g
Keys: 4 button
Much More
